Hello!
I already have a Jetpack installed on the Jetson nano and all tests passed.
When I was preparing to perform convolutional computations using torch.nn.conv2d, I noticed that the first calculation was very slow, whereas subsequent calculations were normal. I would like to know how to solve this problem.
And here is my test code:
import torch
import torch.nn as nn
import time
device = torch.device('cuda' if torch.cuda.is_available() else 'cpu')
epoch = 0
while epoch < 3:
start_time = time.time()
input_tensor = torch.randn([1, 3, 256, 256]).float().to(device)
conv_layer = nn.Conv2d(3, 3, kernel_size=3, bias=True).to(device)
output = conv_layer(input_tensor)
# print(output)
print(time.time() - start_time) # first epoch took 5 minutes, and later epoch took 5 ms.
epoch += 1
