I am trying to write a piece of fortran using modules instead of common variables in order to increase the voulme of data that can be passed between the files,
However when i try to do that ,the fortran programme takes corrupt values for one of the variables from my input file.
Quote:
subroutine delta_twist(over_cut,contact_cutoff,rep_cutoff,next,nclose,overs,fstar,fact,kb,kt,time,Astar,decatt)
!Use the module blocks
!use fibernumber
use rspsqs
use fric_forces
use rep_forces
use ucm
use ambient
use AandC
use params
use contact1
use contact2
use rateofstrain
use rotation
use equilrot
use constants
use joints
use specbend
implicit none
integer :: kb,kt,over_cut,Astar,decatt,contact_cutoff,fstar,fact,time,rep_cutoff,overs
This file takes this value from here
Quote:
contact_cutoff = (contact_cutoff + 2.D0)**2 in another file
which in turn takes its value from the input file
