Problem with wifi on TX2
Hi
I’m new to the forum.
My TX2 can use and configure a wired network. It was okay a few days ago, and I didn’t know what was set, now it can’t connect to wifi.
The wifi login option cannot be found in the upper right corner of the interface;
Enter “iwconfig” display “wlan0 no wireless extensions”;
Enter “sudo ifconfig wlan0 up” and password display Nothing.
When I enter “rfkill unblock all” and restart , wifi is also not working.
Can you help?
Thanks in advance
This statement seems not give out much info here. You configured a “wired” network and it was okay few days. Then the wifi is not working. It sounds like wifi is not able to work in the beginning?
  1. Do you see wlan0 in ifconfig?
  2. Could you share the result of “rfkill list”
  3. Could you paste the kernel log by command “dmesg”? Please make sure the forum system does not truncate your log.
  1. I have always been able to use a wired network. I used to use wifi, but now it doesn’t work.I have configured a wired network to make the balser camera work, but I have not modified the wireless settings.
  2. I enter “ifconfig” and I cannot see wlan0.
  3. I enter “rfkill list” and the result is as follows.
  4. Do you have a detailed log operation method, I have not used Ubuntu for a long time.
nvidia@tegra-ubuntu:~$ ifconfig
docker0 Link encap:Ethernet HWaddr 02:42:1b:d9:7f:30
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr 00:04:4b:8c:d1:3b
collisions:0 txqueuelen:1000
Interrupt:42
l4tbr0 Link encap:Ethernet HWaddr c6:f3:5f:1b:2b:2d
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::10d4:adff:fee5:67d6/64 Scope:Link
TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:595 (595.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:7140 errors:0 dropped:0 overruns:0 frame:0
TX packets:7140 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:432240 (432.2 KB) TX bytes:432240 (432.2 KB)
usb0 Link encap:Ethernet HWaddr ca:80:46:3b:30:5a
usb1 Link encap:Ethernet HWaddr c6:f3:5f:1b:2b:2d
nvidia@tegra-ubuntu:~$ iwconfig
usb0 no wireless extensions.
lo no wireless extensions.
dummy0 no wireless extensions.
wlan0 no wireless extensions.
l4tbr0 no wireless extensions.
usb1 no wireless extensions.
docker0 no wireless extensions.
tunl0 no wireless extensions.
eth0 no wireless extensions.
nvidia@tegra-ubuntu:~$ rfkill list
0: bluedroid_pm: Bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: brcmfmac-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
Looks like wlan0 is gone.
  1. Do you have a detailed log operation method, I have not used Ubuntu for a long time.
Please boot up your tegra and then type command “dmesg” and then share the result here. Please make sure the forum system does not truncate your log.
Attached is the content of dmesg.
The problem was that before the Spring Festival, I didn’t use the equipment during the Spring Festival.
The timing of the device was wrong and I didn’t fix it.
dmesg.txt (74.6 KB)
Below log looks weird. Could you try to reflash your board and see if wlan0 could get back?
[    9.946446] wifi_platform_bus_enumerate device present 1
[    9.964232] wifi_platform_bus_enumerate device present 0
[    9.964589] F1 signature read @0x18000000=0x17214354
[    9.968022] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[    9.968512] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[    9.968566] wifi_platform_prealloc: failed to alloc static mem section 7
[    9.968572] wifi_platform_get_mac_addr
[   10.009548] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[   10.010946] wl_create_event_handler(): thread:wl_event_handler:35d started
[   10.011083] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1dfe41a70
[   10.011266] dhd_attach(): thread:dhd_watchdog_thread:35e started
[   10.011289] dhd_attach(): thread:dhd_dpc:35f started
[   10.011313] dhd_attach(): thread:dhd_rxf:360 started
[   10.011320] dhd_deferred_work_init: work queue initialized
[   10.016426] Dongle Host Driver, version 1.201.82 (r)
               Compiled in drivers/net/wireless/bcmdhd on Jul  6 2018 at 15:42:55
[   10.018252] tegra_sysfs_register
[   10.018286] Register interface [wlan0]  MAC: 00:04:4b:8c:d1:39
[   10.018289] dhd_prot_ioctl : bus is down. we have nothing to do
[   10.018390] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 64
[   10.021460] wifi_platform_set_power = 0
How can I reflash my board? I only have a windows pc and TX2 at now.
Will it break existing software and program code?
  1. Please try to find a ubutnu host to do the reflash.
  2. Please make a backup if anything important.
We have to make sure whether your wifi problem is a hardware issue or not. Re-flash is the fastest method.
To avoid pneumonia, we have to work from home, so there is no ubuntu computer.
I have a wifi device with a usb interface, but nothing happens when I plug it in.
Can I use it to verify software or hardware, or use it to get online.
