How should the following error to be handled?
[ 3.727587] tegra-snd-t186ref-mobile-rt565x sound: Can't retrieve clk clk_m
[ 3.727661] tegra-snd-t186ref-mobile-rt565x: probe of sound failed with error -2
thanks.
thanks.
Hi igal.kroyter,
Which L4T version you used on your TX2? R28.1 or R28.2 DP?
How to get the error you mentioned?
Please elaborate the step to get that log.
Hi kayccc,
I am using the TX2 with R28.1.
This is the the sound card definition which I utilize:
sound {
compatible = "nvidia,tegra-audio-t186ref-mobile-rt565x";
nvidia,model = "tegra-snd-t186ref-mobile-rt565x";
status = "okay";
nvidia,clk-rates = <0x10266000 0xac4400 0x2b11000 0x2b11000 0xea60000 0xbb8000 0x2ee0000 0x2ee0000>;
nvidia,num-clk = <0x8>;
clock-names = "pll_a", "pll_a_out0", "ahub", "clk_m", "extern1";
nvidia,xbar = <0xce>;
nvidia,audio-routing = "Headphone-z", "HPL", "Headphone-z", "HPR", "Headphone-z", "LOL", "Headphone-z", "LOR","IN1_L", "LineIn-z", "IN1_R", "LineIn-z","IN2_L", "LineIn-z", "IN2_R", "LineIn-z","IN3_L", "LineIn-z", "IN3_R", "LineIn-z";
nvidia,num-codec-link = <0x2>;
nvidia,dai-link-1 {
link-name = "ti-capture-z";
cpu-dai = <0xcf>;
codec-dai = <&aic32x4>;
cpu-dai-name = "I2S1";
codec-dai-name = "tlv320aic32x4-hifi";
tx-mask = <0xFF>;
rx-mask = <0xFF>;
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
bclk_ratio = <1>;
srate = <48000>;
num-channel = <2>;
name-prefix = "z";
nvidia,dai-link-2 {
link-name = "ti-playback-x";
cpu-dai = <0xcf>;
tx-mask = <0xFF>;
rx-mask = <0xFF>;
format = "i2s";
bitclock-slave;
frame-slave;
frame-noninversion;
bclk_ratio = <1>;
srate = <48000>;
num-channel = <2>;
name-prefix = "x";
and this is the i2c driver that I utilize:
i2c@c240000 {
reg = <0x0 0xc240000 0x0 0x100>;
dmas = <0x19 0x16 0x19 0x16>;
interrupts = <0x0 0x1a 0x4>;
compatible = "nvidia,tegra186-i2c";
clock-names = "div-clk", "parent", "slow-clk";
reset-names = "i2c";
clock-frequency = <0x61a80>;
scl-gpio = <0x1c 0x30 0x0>;
sda-gpio = <0x1c 0x31 0x0>;
clocks = <0xd 0xda 0xd 0x10d 0xd 0xdd>;
resets = <0xd 0x14>;
status = "okay";
#address-cells = <0x1>;
phandle = <0x8b>;
#stream-id-cells = <0x1>;
#size-cells = <0x0>;
dma-names = "rx", "tx";
linux,phandle = <0x8b>;
[b] aic32x4: tlv320aic32x4.1-0018@18 {
compatible = "ti,tlv320aic32x4";
status = "okay";
reg = <0x18>;
//clocks = <&clks 201>;
clock-names = "mclk";
[/b]
I understand that the function that fails is from within:
int tegra_alt_asoc_utils_init(struct tegra_asoc_audio_clock_info *data,struct device *dev, struct snd_soc_card *card) function ; from tegra_asoc_utils_alt.c file:
data->clk_m = devm_clk_get(dev, "clk_m");
if (IS_ERR(data->clk_m)) {
dev_err(data->dev, "Can't retrieve clk clk_m\n");
ret = PTR_ERR(data->clk_m);
goto err;
any suggestions?
Not sure is it cause by lost the clocks statement like below.
tegra_sound: sound {
nvidia,num-codec-link = <13>;
nvidia,num-clk = <8>;
nvidia,clk-rates = < 270950400 /* PLLA_x11025_RATE */
11289600 /* AUD_MCLK_x11025_RATE */
45158400 /* PLLA_OUT0_x11025_RATE */
45158400 /* AHUB_x11025_RATE */
245760000 /* PLLA_x8000_RATE */
12288000 /* AUD_MCLK_x8000_RATE */
49152000 /* PLLA_OUT0_x8000_RATE */
49152000 >;/* AHUB_x8000_RATE */
clocks = <&tegra_car TEGRA186_CLK_PLLP_OUT0>,
<&tegra_car TEGRA186_CLK_PLLA>,
<&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
<&tegra_car TEGRA186_CLK_AHUB>,
<&tegra_car TEGRA186_CLK_CLK_M>,
<&tegra_car TEGRA186_CLK_AUD_MCLK>;
clock-names = "pll_p_out1", "pll_a", "pll_a_out0", "ahub",
"clk_m", "extern1";
resets = <&tegra_car TEGRA186_RESET_AUD_MCLK>;
reset-names = "extern1_rst";
ShaneCCC,
When trying to compile the tree, I get that the
is syntax error.
Moreover, the resets token also produces a syntax error.
do you know the reason?
Those declaration were in the …/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-platforms/tegra186-quill-common.dtsi file shouldn’t have compile issue.
I have searched the whole drive where I installed the Jetpack and could not find this file (tegra186-quill-common.dtsi) did I miss some installation?
Please ignore my previous message (#7)…
how should then this file be included in the compilation environment?
thanks.
This file should default include.
until now was compiling the DT on a remote machine and flashing it remotely. So I though that it is possible that not all dependent TDs are included so I have followed the procedure to compile the device tree on the target machine (Jetson TX2) per https://devtalk.nvidia.com/default/topic/1023007/jetson-tx2/how-to-use-uart0-as-normal-uart-port-on-r28-1-/post/5206235/
and again I have a syntax error that pointing 8021.36-37, I guess it is where the TEGRA186_CLK_PLLP_OUT0 is.
any suggestions?
any suggestions?
If you follow the l4t-document chapter “Kernel Customization” to sync and build the DT and kernel image that shouldn’t have this problem.
I’m sorry but I could not find anything there that explains how to compile a device tree.
What should I find in the L4T documents?
Go to download center to find it.
My bad. I was not clear enough, I was reading the L4T document, but I could not find a procedure for compiling a device tree and then flashing. I have found these procedures in the current forum. I guess that there are device tree source files which #include the common dts files. but I am not aware of such a procedure.
I am actually de-compile the current device tree modify it and compile it again, and I assume that this is an incorrect procedure.
Please advise.
Did you see below from document? The command “$ make O=$TEGRA_KERNEL_OUT dtbs” to build dtb file from the source code.
2. Execute the following commands to create the .config:
$ cd <myworkspace>/<kernel_source>
$ mkdir $TEGRA_KERNEL_OUT
Where:
• <kernel_source> directory contains the kernel sources.
$ make O=$TEGRA_KERNEL_OUT <defconfig>
• <myworkspace> is the parent of the Git root.
• <defconfig> is:
• Jetson TX1: tegra21_defconfig
• Jetson TX2: tegra18_defconfig
3. Execute the following commands to build the kernel:
$ make O=$TEGRA_KERNEL_OUT zImage
4. Execute the following command to create the kernel device tree components:
ShaneCCC,
so I have run the following:
make dtbs
but I got some error that requested me to run:
make xconfig
and it looks as if I have to update the configuration, i.e. add any previous modules to the kernel.
I added : the following:
note: What is strange that I think that they were supposed to be there…
anyway I have run
make dtbs
and it has successfully completed the compilation.
The following questions were raised:
Please advise.
@igal.kroyter
Did you follow the document step by step to build the DTB. BTW, looks like you need make config first.
• <defconfig> is:
ShaneCCC,
I have rewritten my reply.
Please advise.
