Problems after driver Solaris Display Driver update
Hi, I want to update nvidia driver on Solaris X86(Solaris Display Driver – x64/x86,Version: 460.39). I got message that driver was installed successfully, but when I rebooted my computer only console mode is working, X-server is broken.
How can I fix the problem?Thanks!
here have an xorg.log with some crash informationXorg.0.log (14.4 KB)
dlopen: ld.so.1: Xorg: fatal: /usr/X11/lib/modules/extensions//libglx.so: open failed: No such file or directory
(EE) Failed to load /usr/X11/lib/modules/extensions//libglx.so
(EE) Failed to load module “glx” (loader failed, 7)
(EE) Failed to load module “nvidia” (module does not exist, 0)
(EE) No drivers available.
Xerrors (29.7 KB)
pci.txt (2.1 KB)
Did you ever find a resolution to this issue. I have the same issue as you.
