Problems building the various examples
Also I am German, but OS is English. There could be some German settings for something in the OS, but I doubt anything relevant here. From what I gather this shouldn’t be a new combination in your team
As for the output. Sure, here.
C:\Optix7\OptiX_Apps>3rdparty.cmd
C:\Optix7\OptiX_Apps>"C:\Program Files\cmake\bin\cmake.exe" -P 3rdparty.cmake -DCMAKE_INSTALL_PREFIX="3rdparty"
cl_version = 19.27
cl_architecture = x64
Creating 3rdparty library folder for Visual Studio 16 2019 x64
Install prefix: C:/Optix7/OptiX_Apps/3rdparty
GLEW
  removing C:/Optix7/OptiX_Apps/3rdparty/glew
  extracting
  renaming
GLFW
  removing C:/Optix7/OptiX_Apps/3rdparty/glfw
  extracting
  renaming
ASSIMP
  extracting
  creating C:/Optix7/OptiX_Apps/temp/build/msvc-14.2/assimp
  generating
-- Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.18363.
-- The C compiler identification is MSVC 19.27.29112.0
-- The CXX compiler identification is MSVC 19.27.29112.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/VC/Tools/MSVC/14.27.29110/bin/Hostx64/x64/cl.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/VC/Tools/MSVC/14.27.29110/bin/Hostx64/x64/cl.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Shared libraries enabled
CMake Warning (dev) at CMakeLists.txt:257 (IF):
  Policy CMP0054 is not set: Only interpret if() arguments as variables or
  keywords when unquoted.  Run "cmake --help-policy CMP0054" for policy
  details.  Use the cmake_policy command to set the policy and suppress this
  warning.
  Quoted variables like "MSVC" will no longer be dereferenced when the policy
  is set to NEW.  Since the policy is not set the OLD behavior will be used.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Looking for ZLIB...
-- Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
-- Could not locate ZLIB
-- compiling zlib from sources
CMake Deprecation Warning at contrib/zlib/CMakeLists.txt:1 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of off64_t
-- Check size of off64_t - failed
-- Looking for fseeko
-- Looking for fseeko - not found
-- Looking for unistd.h
-- Looking for unistd.h - not found
-- Enabled importer formats: AMF 3DS AC ASE ASSBIN B3D BVH COLLADA DXF CSM HMP IRRMESH IRR LWO LWS M3D MD2 MD3 MD5 MDC MDL NFF NDO OFF OBJ OGRE OPENGEX PLY MS3D COB BLEND IFC XGL FBX Q3D Q3BSP RAW SIB SMD STL TERRAGEN 3D X X3D GLTF 3MF MMD
-- Disabled importer formats:
-- Enabled exporter formats: OBJ OPENGEX PLY 3DS ASSBIN ASSXML M3D COLLADA FBX STL X X3D GLTF 3MF ASSJSON STEP
-- Disabled exporter formats:
CMake Warning (dev) at test/CMakeLists.txt:223 (target_sources):
  Policy CMP0076 is not set: target_sources() command converts relative paths
  to absolute.  Run "cmake --help-policy CMP0076" for policy details.  Use
  the cmake_policy command to set the policy and suppress this warning.
  An interface source of target "unit" has a relative path.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Optix7/OptiX_Apps/temp/build/msvc-14.2/assimp
  compiling
Microsoft Visual Studio 2019 Version 16.7.7.
Copyright (C) Microsoft Corp. All rights reserved.
------ Build started: Project: ZERO_CHECK, Configuration: Release x64 ------
Checking Build System
------ Build started: Project: zlibstatic, Configuration: Release x64 ------
Building Custom Rule C:/Optix7/OptiX_Apps/temp/sources/assimp-master/contrib/zlib/CMakeLists.txt
adler32.c
compress.c
crc32.c
deflate.c
gzclose.c
gzlib.c
gzread.c
gzwrite.c
inflate.c
infback.c
inftrees.c
inffast.c
trees.c
uncompr.c
zutil.c
Generating Code...
zlibstatic.vcxproj -> C:\Optix7\OptiX_Apps\temp\build\msvc-14.2\assimp\contrib\zlib\Release\zlibstatic.lib
------ Build started: Project: assimp, Configuration: Release x64 ------
Building Custom Rule C:/Optix7/OptiX_Apps/temp/sources/assimp-master/code/CMakeLists.txt
Assimp.cpp
CInterfaceIOWrapper.cpp
BaseImporter.cpp
BaseProcess.cpp
PostStepRegistry.cpp
ImporterRegistry.cpp
DefaultIOStream.cpp
DefaultIOSystem.cpp
ZipArchiveIOSystem.cpp
Importer.cpp
SGSpatialSort.cpp
VertexTriangleAdjacency.cpp
SpatialSort.cpp
SceneCombiner.cpp
ScenePreprocessor.cpp
SkeletonMeshBuilder.cpp
StandardShapes.cpp
TargetAnimation.cpp
RemoveComments.cpp
Subdivision.cpp
Generating Code...
Compiling...
scene.cpp
Bitmap.cpp
Version.cpp
CreateAnimMesh.cpp
simd.cpp
material.cpp
AssertHandler.cpp
Exceptional.cpp
DefaultLogger.cpp
Exporter.cpp
AssimpCExport.cpp
CalcTangentsProcess.cpp
ComputeUVMappingProcess.cpp
ConvertToLHProcess.cpp
EmbedTexturesProcess.cpp
FindDegenerates.cpp
FindInstancesProcess.cpp
FindInvalidDataProcess.cpp
FixNormalsStep.cpp
DropFaceNormalsProcess.cpp
Generating Code...
Compiling...
GenFaceNormalsProcess.cpp
GenVertexNormalsProcess.cpp
PretransformVertices.cpp
ImproveCacheLocality.cpp
JoinVerticesProcess.cpp
LimitBoneWeightsProcess.cpp
RemoveRedundantMaterials.cpp
RemoveVCProcess.cpp
SortByPTypeProcess.cpp
SplitLargeMeshes.cpp
TextureTransform.cpp
TriangulateProcess.cpp
ValidateDataStructure.cpp
OptimizeGraph.cpp
OptimizeMeshes.cpp
DeboneProcess.cpp
ProcessHelper.cpp
MakeVerboseFormat.cpp
ScaleProcess.cpp
ArmaturePopulate.cpp
Generating Code...
Compiling...
GenBoundingBoxesProcess.cpp
SplitByBoneCountProcess.cpp
MaterialSystem.cpp
STEPFileReader.cpp
STEPFileEncoding.cpp
AMFImporter.cpp
AMFImporter_Geometry.cpp
AMFImporter_Material.cpp
AMFImporter_Postprocess.cpp
3DSConverter.cpp
3DSLoader.cpp
ACLoader.cpp
ASELoader.cpp
ASEParser.cpp
AssbinLoader.cpp
B3DImporter.cpp
BVHLoader.cpp
ColladaHelper.cpp
ColladaLoader.cpp
ColladaParser.cpp
Generating Code...
Compiling...
DXFLoader.cpp
CSMLoader.cpp
HMPLoader.cpp
IRRMeshLoader.cpp
IRRShared.cpp
IRRLoader.cpp
LWOAnimation.cpp
LWOBLoader.cpp
LWOLoader.cpp
LWOMaterial.cpp
LWSLoader.cpp
M3DImporter.cpp
M3DWrapper.cpp
MD2Loader.cpp
MD3Loader.cpp
MD5Loader.cpp
MD5Parser.cpp
MDCLoader.cpp
MDLLoader.cpp
MDLMaterialLoader.cpp
Generating Code...
Compiling...
HL1MDLLoader.cpp
UniqueNameGenerator.cpp
NFFLoader.cpp
NDOLoader.cpp
OFFLoader.cpp
ObjFileImporter.cpp
ObjFileMtlImporter.cpp
ObjFileParser.cpp
OgreImporter.cpp
OgreStructs.cpp
OgreBinarySerializer.cpp
OgreXmlSerializer.cpp
OgreMaterial.cpp
OpenGEXImporter.cpp
PlyLoader.cpp
PlyParser.cpp
MS3DLoader.cpp
COBLoader.cpp
BlenderLoader.cpp
BlenderDNA.cpp
Generating Code...
Compiling...
BlenderScene.cpp
BlenderModifier.cpp
BlenderBMesh.cpp
BlenderTessellator.cpp
BlenderCustomData.cpp
IFCLoader.cpp
IFCReaderGen1_2x3.cpp
IFCReaderGen2_2x3.cpp
IFCUtil.cpp
IFCGeometry.cpp
IFCMaterial.cpp
IFCProfile.cpp
IFCCurve.cpp
IFCBoolean.cpp
IFCOpenings.cpp
XGLLoader.cpp
FBXImporter.cpp
FBXParser.cpp
FBXTokenizer.cpp
FBXConverter.cpp
Generating Code...
Compiling...
FBXUtil.cpp
FBXDocument.cpp
FBXProperties.cpp
FBXMeshGeometry.cpp
FBXMaterial.cpp
FBXModel.cpp
FBXAnimation.cpp
FBXNodeAttribute.cpp
FBXDeformer.cpp
FBXBinaryTokenizer.cpp
FBXDocumentUtil.cpp
Q3DLoader.cpp
Q3BSPFileParser.cpp
Q3BSPFileImporter.cpp
RawLoader.cpp
SIBImporter.cpp
SMDLoader.cpp
STLLoader.cpp
TerragenLoader.cpp
UnrealLoader.cpp
Generating Code...
Compiling...
XFileImporter.cpp
XFileParser.cpp
X3DImporter.cpp
glTFCommon.cpp
glTFImporter.cpp
glTF2Importer.cpp
D3MFImporter.cpp
D3MFOpcPackage.cpp
MMDImporter.cpp
MMDPmxParser.cpp
ObjExporter.cpp
OpenGEXExporter.cpp
PlyExporter.cpp
3DSExporter.cpp
AssbinExporter.cpp
AssbinFileWriter.cpp
AssxmlExporter.cpp
AssxmlFileWriter.cpp
M3DExporter.cpp
ColladaExporter.cpp
Generating Code...
Compiling...
FBXExporter.cpp
FBXExportNode.cpp
FBXExportProperty.cpp
STLExporter.cpp
XFileExporter.cpp
X3DExporter.cpp
glTFExporter.cpp
glTF2Exporter.cpp
D3MFExporter.cpp
json_exporter.cpp
mesh_splitter.cpp
StepExporter.cpp
shapes.cc
advancing_front.cc
cdt.cc
sweep.cc
sweep_context.cc
clipper.cpp
OpenDDLParser.cpp
DDLNode.cpp
Generating Code...
Compiling...
OpenDDLCommon.cpp
OpenDDLExport.cpp
Value.cpp
OpenDDLStream.cpp
o3dgcArithmeticCodec.cpp
o3dgcDynamicVectorDecoder.cpp
o3dgcDynamicVectorEncoder.cpp
o3dgcTools.cpp
o3dgcTriangleFans.cpp
Generating Code...
cencode.c
ioapi.c
unzip.c
zip.c
Generating Code...
   Creating library C:/Optix7/OptiX_Apps/temp/build/msvc-14.2/assimp/lib/Release/assimp-vc142-mt.lib and object C:/Optix7/OptiX_Apps/temp/build/msvc-14.2/assimp/lib/Release/assimp-vc142-mt.exp
assimp.vcxproj -> C:\Optix7\OptiX_Apps\temp\build\msvc-14.2\assimp\bin\Release\assimp-vc142-mt.dll
------ Build started: Project: assimp_cmd, Configuration: Release x64 ------
Building Custom Rule C:/Optix7/OptiX_Apps/temp/sources/assimp-master/tools/assimp_cmd/CMakeLists.txt
CompareDump.cpp
ImageExtractor.cpp
Main.cpp
WriteDump.cpp
Info.cpp
Export.cpp
Generating Code...
assimp_cmd.vcxproj -> C:\Optix7\OptiX_Apps\temp\build\msvc-14.2\assimp\bin\Release\assimp.exe
------ Build started: Project: unit, Configuration: Release x64 ------
Building Custom Rule C:/Optix7/OptiX_Apps/temp/sources/assimp-master/test/CMakeLists.txt
CCompilerTest.c
Main.cpp
Version.cpp
utSimd.cpp
utIOSystem.cpp
utIOStreamBuffer.cpp
utIssues.cpp
utAnim.cpp
AssimpAPITest.cpp
AssimpAPITest_aiMatrix3x3.cpp
AssimpAPITest_aiMatrix4x4.cpp
AssimpAPITest_aiQuaternion.cpp
AssimpAPITest_aiVector2D.cpp
AssimpAPITest_aiVector3D.cpp
MathTest.cpp
utBatchLoader.cpp
utDefaultIOStream.cpp
utFastAtof.cpp
utMetadata.cpp
SceneDiffer.cpp
AbstractImportExportBase.cpp
Generating Code...
Compiling...
utTypes.cpp
utVersion.cpp
utProfiler.cpp
utSharedPPData.cpp
utStringUtils.cpp
utStandardShapes.cpp
uiScene.cpp
utLineSplitter.cpp
utSpatialSort.cpp
utAssertHandler.cpp
utXmlParser.cpp
utAssxmlImportExport.cpp
utLWSImportExport.cpp
utLWOImportExport.cpp
utSMDImportExport.cpp
utglTFImportExport.cpp
utglTF2ImportExport.cpp
utHMPImportExport.cpp
utIFCImportExport.cpp
utFBXImporterExporter.cpp
Generating Code...
Compiling...
utImporter.cpp
utExporter.cpp
ut3DImportExport.cpp
ut3DSImportExport.cpp
utACImportExport.cpp
utAMFImportExport.cpp
utASEImportExport.cpp
utD3MFImportExport.cpp
utQ3DImportExport.cpp
utSTLImportExport.cpp
utXImporterExporter.cpp
utX3DImportExport.cpp
utDXFImporterExporter.cpp
utPMXImporter.cpp
utPLYImportExport.cpp
utObjImportExport.cpp
utObjTools.cpp
utOpenGEXImportExport.cpp
utSIBImporter.cpp
utBlenderIntermediate.cpp
Generating Code...
Compiling...
utBlendImportAreaLight.cpp
utBlenderImportExport.cpp
utBlendImportMaterials.cpp
utBlenderWork.cpp
utBVHImportExport.cpp
utColladaExport.cpp
utColladaImportExport.cpp
utCSMImportExport.cpp
utB3DImportExport.cpp
utM3DImportExport.cpp
utMDCImportExport.cpp
utAssbinImportExport.cpp
utAssjsonImportExport.cpp
utCOBImportExport.cpp
utOgreImportExport.cpp
utQ3BSPFileImportExport.cpp
utOFFImportExport.cpp
utNFFImportExport.cpp
utXGLImportExport.cpp
utMD2Importer.cpp
Generating Code...
Compiling...
utMD3Importer.cpp
utMD5Importer.cpp
utMDLImporter.cpp
utMDLImporter_HL1_ImportSettings.cpp
utMDLImporter_HL1_Materials.cpp
utMDLImporter_HL1_Nodes.cpp
utRAWImportExport.cpp
utTerragenImportExport.cpp
utMaterialSystem.cpp
utMatrix3x3.cpp
utMatrix4x4.cpp
utVector3.cpp
utImproveCacheLocality.cpp
utFixInfacingNormals.cpp
utGenNormals.cpp
utTriangulate.cpp
utTextureTransform.cpp
utRemoveRedundantMaterials.cpp
utRemoveVCProcess.cpp
utScaleProcess.cpp
Generating Code...
Compiling...
utArmaturePopulate.cpp
utJoinVertices.cpp
utRemoveComments.cpp
utRemoveComponent.cpp
utVertexTriangleAdjacency.cpp
utSplitLargeMeshes.cpp
utFindDegenerates.cpp
utFindInvalidData.cpp
utLimitBoneWeights.cpp
utPretransformVertices.cpp
utScenePreprocessor.cpp
utTargetAnimation.cpp
utSortByPType.cpp
utSceneCombiner.cpp
utGenBoundingBoxesProcess.cpp
gtest-all.cc
Generating Code...
unit.vcxproj -> C:\Optix7\OptiX_Apps\temp\build\msvc-14.2\assimp\bin\Release\unit.exe
------ Build started: Project: ALL_BUILD, Configuration: Release x64 ------
Building Custom Rule C:/Optix7/OptiX_Apps/temp/sources/assimp-master/CMakeLists.txt
------ Skipped Build: Project: INSTALL, Configuration: Release x64 ------
Project not selected to build for this solution configuration
------ Skipped Build: Project: UpdateAssimpLibsDebugSymbolsAndDLLs, Configuration: Release x64 ------
------ Skipped Build: Project: uninstall, Configuration: Release x64 ------
========== Build: 6 succeeded, 0 failed, 0 up-to-date, 3 skipped ==========
  installing
------ Build started: Project: INSTALL, Configuration: Release x64 ------
-- Install configuration: "Release"
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/cmake/assimp-5.0/assimp-config.cmake
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/cmake/assimp-5.0/assimp-config-version.cmake
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/cmake/assimp-5.0/assimpTargets.cmake
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/cmake/assimp-5.0/assimpTargets-debug.cmake
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/cmake/assimp-5.0/assimpTargets-release.cmake
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/pkgconfig/assimp.pc
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/zlibstatic.lib
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/lib/assimp-vc142-mt.lib
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/bin/assimp-vc142-mt.dll
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/anim.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/aabb.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/ai_assert.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/camera.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/color4.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/color4.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/config.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/ColladaMetaData.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/commonMetaData.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/defs.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Defines.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/cfileio.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/light.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/material.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/material.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/matrix3x3.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/matrix3x3.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/matrix4x4.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/matrix4x4.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/mesh.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/pbrmaterial.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/postprocess.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/quaternion.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/quaternion.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/scene.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/metadata.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/texture.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/types.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/vector2.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/vector2.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/vector3.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/vector3.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/version.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/cimport.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/importerdesc.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Importer.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/DefaultLogger.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/ProgressHandler.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/IOStream.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/IOSystem.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Logger.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/LogStream.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/NullLogger.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/cexport.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Exporter.hpp
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/DefaultIOStream.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/DefaultIOSystem.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/ZipArchiveIOSystem.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/SceneCombiner.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/fast_atof.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/qnan.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/BaseImporter.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Hash.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/MemoryIOWrapper.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/ParsingUtils.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/StreamReader.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/StreamWriter.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/StringComparison.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/StringUtils.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/SGSpatialSort.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/GenericProperty.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/SpatialSort.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/SkeletonMeshBuilder.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/SmallVector.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/SmoothingGroups.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/SmoothingGroups.inl
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/StandardShapes.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/RemoveComments.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Subdivision.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Vertex.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/LineSplitter.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/TinyFormatter.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Profiler.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/LogAux.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Bitmap.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/XMLTools.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/IOStreamBuffer.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/CreateAnimMesh.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/XmlParser.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/BlobIOSystem.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/MathFunctions.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Exceptional.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/ByteSwapper.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Compiler/pushpack1.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Compiler/poppack1.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/include/assimp/Compiler/pstdint.h
-- Installing: C:/Optix7/OptiX_Apps/3rdparty/assimp/bin/assimp.exe
========== Build: 1 succeeded, 0 failed, 6 up-to-date, 0 skipped ==========
deleting temp folder
Thanks. Me too, and yes, English OS versions.
This looks perfectly fine for an x64 MSVS 2019 command prompt and doesn’t explain at all why you could only build assimp-vc141-mt.lib/.dll versions from that at some times.
cl_version = 19.27
It should have always picked this generator and toolset:
  # MSVS 2019 with VC toolset 14.2
  set(GENERATOR "Visual Studio 16 2019")
  set(MSVC_TOOLSET "msvc-14.2")
The only difference between your and my system is the line
Nothing more I can do about this.
Again thanks.
It’s working now and it doesn’t seem to problem in your scripts either. I guess the SDK is something to keep in mind in the future.
