Hello.
I need to get an image from a sensor with a parallel interface in TX2. To do this, I want to use the serializer and deserializer kit max9295\max9296. I have already connected the test pattern generator to the serializer, made changes to the max9295\max9296 drivers and received a mipi signal at the deserializer output.
My test pattern generator generates 640x512 50fps 12bit images, PCLK = 20mHz.
I changed the imx390 driver, namely removed part of the i2c, because my test generator emits a signal continuously and it does not need initialization.
I tried to capture the image with the command:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=640,height=512,pixelformat=Y12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=30 --stream-to=video0.raw --verbose
but I always get the following errors in the system log:
[ 65.619554] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 65.833161] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 65.839613] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 66.053126] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 66.059590] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 66.273168] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 66.279629] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 66.493290] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 66.499769] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 66.713483] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 66.720008] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 66.933489] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 66.939917] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 66.950097] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 66.958016] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 67.169450] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 67.175943] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 67.389627] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 67.396088] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 67.609676] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 67.616287] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 67.829648] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 67.836148] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 68.049698] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 68.056212] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 68.269813] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 68.276348] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
the trace has the form:
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-8639 [000] .... 126.186694: tegra_channel_open: vi-output, imx390 30-001b v4l2-ctl-8639 [000] .... 126.188872: tegra_channel_set_power: imx390 30-001b : 0x1 v4l2-ctl-8639 [000] .... 126.188882: camera_common_s_power: status : 0x1 v4l2-ctl-8639 [000] .... 126.189260: tegra_channel_set_power: 150c0000.nvcsi--3 : 0x1 v4l2-ctl-8639 [000] .... 126.189263: csi_s_power: enable : 0x1 v4l2-ctl-8639 [000] .... 126.219800: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 126.220033: tegra_channel_set_stream: enable : 0x1
vi-output, imx3-8640 [000] … 126.233655: tegra_channel_set_stream: 150c0000.nvcsi–3 : 0x1
vi-output, imx3-8640 [000] … 126.233663: csi_s_stream: enable : 0x1
vi-output, imx3-8640 [000] … 126.233696: tegra_channel_set_stream: imx390 30-001b : 0x1
kworker/5:4-5487 [005] … 126.245193: rtos_queue_peek_from_isr_failed: tstamp:4336537104 queue:0x0b4b4500
kworker/5:4-5487 [005] … 126.245196: rtcpu_start: tstamp:4336542266
kworker/5:4-5487 [005] … 126.245198: rtos_queue_send_from_isr_failed: tstamp:4336613393 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.245200: rtos_queue_send_from_isr_failed: tstamp:4336613577 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.245201: rtos_queue_send_from_isr_failed: tstamp:4336613753 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.245202: rtos_queue_send_from_isr_failed: tstamp:4336613930 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.245203: rtos_queue_send_from_isr_failed: tstamp:4336614102 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.245204: rtos_queue_send_from_isr_failed: tstamp:4336614276 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.245205: rtos_queue_send_from_isr_failed: tstamp:4336614451 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.245206: rtos_queue_send_from_isr_failed: tstamp:4336614627 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.245208: rtos_queue_send_failed: tstamp:4336615486 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.245209: rtos_queue_send_from_isr_failed: tstamp:4336620190 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.245210: rtos_queue_send_from_isr_failed: tstamp:4336620365 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.245211: rtos_queue_send_from_isr_failed: tstamp:4336620540 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.245212: rtos_queue_send_from_isr_failed: tstamp:4336620717 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.245213: rtos_queue_send_from_isr_failed: tstamp:4336620890 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.245214: rtos_queue_send_from_isr_failed: tstamp:4336621064 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.245214: rtos_queue_send_from_isr_failed: tstamp:4336621238 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.245215: rtos_queue_send_from_isr_failed: tstamp:4336621418 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.245216: rtos_queue_send_failed: tstamp:4336623406 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.357278: rtcpu_vinotify_event: tstamp:4339495557 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4339494961 data:0x00000001
kworker/5:4-5487 [005] … 126.357284: rtcpu_vinotify_event: tstamp:4339495740 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4339494962 data:0x00000001
kworker/5:4-5487 [005] … 126.413323: rtos_queue_peek_from_isr_failed: tstamp:4341537466 queue:0x0b4b4500
vi-output, imx3-8640 [000] … 126.490143: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [000] … 126.490180: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 126.525305: rtos_queue_send_from_isr_failed: tstamp:4345053428 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525311: rtos_queue_send_from_isr_failed: tstamp:4345053574 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.525313: rtos_queue_send_from_isr_failed: tstamp:4345053716 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.525316: rtos_queue_send_from_isr_failed: tstamp:4345053856 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.525318: rtos_queue_send_from_isr_failed: tstamp:4345053992 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.525320: rtos_queue_send_from_isr_failed: tstamp:4345054129 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.525323: rtos_queue_send_from_isr_failed: tstamp:4345054267 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.525325: rtos_queue_send_from_isr_failed: tstamp:4345054403 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.525328: rtos_queue_send_failed: tstamp:4345055129 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525331: rtos_queue_send_from_isr_failed: tstamp:4345059483 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525333: rtos_queue_send_from_isr_failed: tstamp:4345059623 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.525336: rtos_queue_send_from_isr_failed: tstamp:4345059766 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.525338: rtos_queue_send_from_isr_failed: tstamp:4345059905 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.525341: rtos_queue_send_from_isr_failed: tstamp:4345060042 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.525343: rtos_queue_send_from_isr_failed: tstamp:4345060178 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.525345: rtos_queue_send_from_isr_failed: tstamp:4345060316 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.525348: rtos_queue_send_from_isr_failed: tstamp:4345060475 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.525350: rtos_queue_send_failed: tstamp:4345061033 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525352: rtos_queue_send_from_isr_failed: tstamp:4345066169 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525355: rtos_queue_send_from_isr_failed: tstamp:4345066309 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.525357: rtos_queue_send_from_isr_failed: tstamp:4345066446 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.525359: rtos_queue_send_from_isr_failed: tstamp:4345066586 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.525362: rtos_queue_send_from_isr_failed: tstamp:4345066725 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.525364: rtos_queue_send_from_isr_failed: tstamp:4345066864 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.525367: rtos_queue_send_from_isr_failed: tstamp:4345067003 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.525369: rtos_queue_send_from_isr_failed: tstamp:4345067139 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.525371: rtos_queue_send_failed: tstamp:4345067778 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525374: rtos_queue_send_from_isr_failed: tstamp:4345070331 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525376: rtos_queue_send_from_isr_failed: tstamp:4345070473 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.525379: rtos_queue_send_from_isr_failed: tstamp:4345070611 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.525381: rtos_queue_send_from_isr_failed: tstamp:4345070751 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.525383: rtos_queue_send_from_isr_failed: tstamp:4345070889 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.525386: rtos_queue_send_from_isr_failed: tstamp:4345071028 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.525388: rtos_queue_send_from_isr_failed: tstamp:4345071165 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.525390: rtos_queue_send_from_isr_failed: tstamp:4345071304 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.525393: rtos_queue_send_failed: tstamp:4345072699 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.525398: rtcpu_vinotify_event: tstamp:4345074168 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4345072878 data:0x00000001
kworker/5:4-5487 [005] … 126.525400: rtcpu_vinotify_event: tstamp:4346016189 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4346015587 data:0x00000001
kworker/5:4-5487 [005] … 126.525402: rtcpu_vinotify_event: tstamp:4346016365 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4346015588 data:0x00000001
kworker/5:4-5487 [005] … 126.581273: rtos_queue_peek_from_isr_failed: tstamp:4346537478 queue:0x0b4b4500
vi-output, imx3-8640 [005] … 126.710206: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [005] … 126.710239: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 126.749354: rtos_queue_peek_from_isr_failed: tstamp:4351537475 queue:0x0b4b4500
kworker/5:4-5487 [005] … 126.749364: rtos_queue_send_from_isr_failed: tstamp:4351929232 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749366: rtos_queue_send_from_isr_failed: tstamp:4351929400 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.749368: rtos_queue_send_from_isr_failed: tstamp:4351929560 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.749370: rtos_queue_send_from_isr_failed: tstamp:4351929699 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.749372: rtos_queue_send_from_isr_failed: tstamp:4351929835 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.749373: rtos_queue_send_from_isr_failed: tstamp:4351929974 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.749375: rtos_queue_send_from_isr_failed: tstamp:4351930111 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.749377: rtos_queue_send_from_isr_failed: tstamp:4351930249 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.749380: rtos_queue_send_failed: tstamp:4351930985 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749382: rtos_queue_send_from_isr_failed: tstamp:4351936433 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749384: rtos_queue_send_from_isr_failed: tstamp:4351936573 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.749386: rtos_queue_send_from_isr_failed: tstamp:4351936713 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.749387: rtos_queue_send_from_isr_failed: tstamp:4351936853 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.749389: rtos_queue_send_from_isr_failed: tstamp:4351936990 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.749391: rtos_queue_send_from_isr_failed: tstamp:4351937128 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.749393: rtos_queue_send_from_isr_failed: tstamp:4351937265 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.749395: rtos_queue_send_from_isr_failed: tstamp:4351937404 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.749396: rtos_queue_send_failed: tstamp:4351937997 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749398: rtos_queue_send_from_isr_failed: tstamp:4351943450 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749400: rtos_queue_send_from_isr_failed: tstamp:4351943592 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.749402: rtos_queue_send_from_isr_failed: tstamp:4351943729 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.749404: rtos_queue_send_from_isr_failed: tstamp:4351943872 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.749405: rtos_queue_send_from_isr_failed: tstamp:4351944009 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.749407: rtos_queue_send_from_isr_failed: tstamp:4351944148 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.749409: rtos_queue_send_from_isr_failed: tstamp:4351944284 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.749411: rtos_queue_send_from_isr_failed: tstamp:4351944423 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.749413: rtos_queue_send_failed: tstamp:4351944992 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749415: rtos_queue_send_from_isr_failed: tstamp:4351947540 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749417: rtos_queue_send_from_isr_failed: tstamp:4351947679 queue:0x0b4aad68
kworker/5:4-5487 [005] .n… 126.749420: rtos_queue_send_from_isr_failed: tstamp:4351947818 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.749460: rtos_queue_send_from_isr_failed: tstamp:4351947956 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.749463: rtos_queue_send_from_isr_failed: tstamp:4351948094 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.749465: rtos_queue_send_from_isr_failed: tstamp:4351948231 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.749467: rtos_queue_send_from_isr_failed: tstamp:4351948369 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.749469: rtos_queue_send_from_isr_failed: tstamp:4351948511 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.749471: rtos_queue_send_failed: tstamp:4351949896 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.749474: rtcpu_vinotify_event: tstamp:4351951335 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4351950481 data:0x00000001
kworker/5:4-5487 [005] … 126.805287: rtcpu_vinotify_event: tstamp:4353261318 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4353260727 data:0x00000001
kworker/5:4-5487 [005] … 126.805295: rtcpu_vinotify_event: tstamp:4353261495 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4353260727 data:0x00000001
kworker/5:4-5487 [005] … 126.861300: rtos_queue_peek_from_isr_failed: tstamp:4356537489 queue:0x0b4b4500
vi-output, imx3-8640 [005] … 126.930296: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [005] … 126.930332: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 126.973298: rtos_queue_send_from_isr_failed: tstamp:4358805523 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973305: rtos_queue_send_from_isr_failed: tstamp:4358805670 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.973307: rtos_queue_send_from_isr_failed: tstamp:4358805811 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.973309: rtos_queue_send_from_isr_failed: tstamp:4358805951 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.973312: rtos_queue_send_from_isr_failed: tstamp:4358806088 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.973314: rtos_queue_send_from_isr_failed: tstamp:4358806226 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.973317: rtos_queue_send_from_isr_failed: tstamp:4358806363 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.973319: rtos_queue_send_from_isr_failed: tstamp:4358806501 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.973324: rtos_queue_send_failed: tstamp:4358807215 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973326: rtos_queue_send_from_isr_failed: tstamp:4358812778 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973329: rtos_queue_send_from_isr_failed: tstamp:4358812922 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.973331: rtos_queue_send_from_isr_failed: tstamp:4358813061 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.973333: rtos_queue_send_from_isr_failed: tstamp:4358813201 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.973336: rtos_queue_send_from_isr_failed: tstamp:4358813342 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.973338: rtos_queue_send_from_isr_failed: tstamp:4358813478 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.973340: rtos_queue_send_from_isr_failed: tstamp:4358813617 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.973343: rtos_queue_send_from_isr_failed: tstamp:4358813753 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.973345: rtos_queue_send_failed: tstamp:4358814312 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973348: rtos_queue_send_from_isr_failed: tstamp:4358819335 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973350: rtos_queue_send_from_isr_failed: tstamp:4358819474 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.973353: rtos_queue_send_from_isr_failed: tstamp:4358819614 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.973355: rtos_queue_send_from_isr_failed: tstamp:4358819753 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.973357: rtos_queue_send_from_isr_failed: tstamp:4358819894 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.973360: rtos_queue_send_from_isr_failed: tstamp:4358820032 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.973362: rtos_queue_send_from_isr_failed: tstamp:4358820190 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.973364: rtos_queue_send_from_isr_failed: tstamp:4358820327 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.973367: rtos_queue_send_failed: tstamp:4358820925 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973369: rtos_queue_send_from_isr_failed: tstamp:4358825122 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973372: rtos_queue_send_from_isr_failed: tstamp:4358825262 queue:0x0b4aad68
kworker/5:4-5487 [005] … 126.973374: rtos_queue_send_from_isr_failed: tstamp:4358825401 queue:0x0b4ac998
kworker/5:4-5487 [005] … 126.973377: rtos_queue_send_from_isr_failed: tstamp:4358825541 queue:0x0b4ae518
kworker/5:4-5487 [005] … 126.973379: rtos_queue_send_from_isr_failed: tstamp:4358825680 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 126.973384: rtos_queue_send_from_isr_failed: tstamp:4358825820 queue:0x0b4b0098
kworker/5:4-5487 [005] … 126.973387: rtos_queue_send_from_isr_failed: tstamp:4358825957 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 126.973390: rtos_queue_send_from_isr_failed: tstamp:4358826095 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 126.973393: rtos_queue_send_failed: tstamp:4358827486 queue:0x0b4a7258
kworker/5:4-5487 [005] … 126.973398: rtcpu_vinotify_event: tstamp:4358828889 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4358828125 data:0x00000001
kworker/5:4-5487 [005] … 126.973400: rtcpu_vinotify_event: tstamp:4359781954 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4359781353 data:0x00000001
kworker/5:4-5487 [005] … 126.973402: rtcpu_vinotify_event: tstamp:4359782130 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4359781353 data:0x00000001
kworker/5:4-5487 [005] … 127.029266: rtos_queue_peek_from_isr_failed: tstamp:4361537506 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 127.149912: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 127.149950: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 127.197303: rtos_queue_send_from_isr_failed: tstamp:4365674691 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197312: rtos_queue_send_from_isr_failed: tstamp:4365674838 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.197315: rtos_queue_send_from_isr_failed: tstamp:4365674983 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.197318: rtos_queue_send_from_isr_failed: tstamp:4365675122 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.197320: rtos_queue_send_from_isr_failed: tstamp:4365675259 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.197323: rtos_queue_send_from_isr_failed: tstamp:4365675395 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.197325: rtos_queue_send_from_isr_failed: tstamp:4365675533 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.197327: rtos_queue_send_from_isr_failed: tstamp:4365675670 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.197332: rtos_queue_send_failed: tstamp:4365676420 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197334: rtos_queue_send_from_isr_failed: tstamp:4365678793 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197337: rtos_queue_send_from_isr_failed: tstamp:4365678930 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.197339: rtos_queue_send_from_isr_failed: tstamp:4365679069 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.197341: rtos_queue_send_from_isr_failed: tstamp:4365679209 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.197344: rtos_queue_send_from_isr_failed: tstamp:4365679346 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.197346: rtos_queue_send_from_isr_failed: tstamp:4365679484 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.197349: rtos_queue_send_from_isr_failed: tstamp:4365679621 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.197351: rtos_queue_send_from_isr_failed: tstamp:4365679759 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.197353: rtos_queue_send_failed: tstamp:4365680347 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197356: rtos_queue_send_from_isr_failed: tstamp:4365684258 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197358: rtos_queue_send_from_isr_failed: tstamp:4365684397 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.197361: rtos_queue_send_from_isr_failed: tstamp:4365684536 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.197363: rtos_queue_send_from_isr_failed: tstamp:4365684674 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.197365: rtos_queue_send_from_isr_failed: tstamp:4365684813 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.197368: rtos_queue_send_from_isr_failed: tstamp:4365684951 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.197370: rtos_queue_send_from_isr_failed: tstamp:4365685088 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.197373: rtos_queue_send_from_isr_failed: tstamp:4365685225 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.197375: rtos_queue_send_failed: tstamp:4365685801 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197378: rtos_queue_send_from_isr_failed: tstamp:4365687974 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197380: rtos_queue_send_from_isr_failed: tstamp:4365688113 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.197382: rtos_queue_send_from_isr_failed: tstamp:4365688252 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.197385: rtos_queue_send_from_isr_failed: tstamp:4365688391 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.197387: rtos_queue_send_from_isr_failed: tstamp:4365688528 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.197389: rtos_queue_send_from_isr_failed: tstamp:4365688664 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.197392: rtos_queue_send_from_isr_failed: tstamp:4365688803 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.197394: rtos_queue_send_from_isr_failed: tstamp:4365688944 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.197397: rtos_queue_send_failed: tstamp:4365690358 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.197401: rtos_queue_peek_from_isr_failed: tstamp:4366537516 queue:0x0b4b4500
kworker/5:4-5487 [005] … 127.197406: rtcpu_vinotify_event: tstamp:4367027085 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4367026492 data:0x00000001
kworker/5:4-5487 [005] … 127.197408: rtcpu_vinotify_event: tstamp:4367027262 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4367026492 data:0x00000001
kworker/5:4-5487 [005] … 127.365305: rtos_queue_peek_from_isr_failed: tstamp:4371537510 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 127.370236: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 127.370274: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 127.421289: rtos_queue_send_from_isr_failed: tstamp:4372553076 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421297: rtos_queue_send_from_isr_failed: tstamp:4372553228 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.421300: rtos_queue_send_from_isr_failed: tstamp:4372553368 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.421302: rtos_queue_send_from_isr_failed: tstamp:4372553508 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.421305: rtos_queue_send_from_isr_failed: tstamp:4372553644 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.421307: rtos_queue_send_from_isr_failed: tstamp:4372553780 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.421309: rtos_queue_send_from_isr_failed: tstamp:4372553918 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.421312: rtos_queue_send_from_isr_failed: tstamp:4372554054 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.421315: rtos_queue_send_failed: tstamp:4372554766 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421317: rtos_queue_send_from_isr_failed: tstamp:4372558905 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421320: rtos_queue_send_from_isr_failed: tstamp:4372559064 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.421322: rtos_queue_send_from_isr_failed: tstamp:4372559204 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.421324: rtos_queue_send_from_isr_failed: tstamp:4372559344 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.421327: rtos_queue_send_from_isr_failed: tstamp:4372559482 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.421329: rtos_queue_send_from_isr_failed: tstamp:4372559619 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.421332: rtos_queue_send_from_isr_failed: tstamp:4372559758 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.421334: rtos_queue_send_from_isr_failed: tstamp:4372559895 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.421337: rtos_queue_send_failed: tstamp:4372560476 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421339: rtos_queue_send_from_isr_failed: tstamp:4372567366 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421342: rtos_queue_send_from_isr_failed: tstamp:4372567504 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.421344: rtos_queue_send_from_isr_failed: tstamp:4372567648 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.421346: rtos_queue_send_from_isr_failed: tstamp:4372567788 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.421349: rtos_queue_send_from_isr_failed: tstamp:4372567926 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.421351: rtos_queue_send_from_isr_failed: tstamp:4372568062 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.421354: rtos_queue_send_from_isr_failed: tstamp:4372568199 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.421356: rtos_queue_send_from_isr_failed: tstamp:4372568335 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.421358: rtos_queue_send_failed: tstamp:4372568968 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421361: rtos_queue_send_from_isr_failed: tstamp:4372572629 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421363: rtos_queue_send_from_isr_failed: tstamp:4372572769 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.421366: rtos_queue_send_from_isr_failed: tstamp:4372572909 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.421368: rtos_queue_send_from_isr_failed: tstamp:4372573048 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.421370: rtos_queue_send_from_isr_failed: tstamp:4372573185 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.421373: rtos_queue_send_from_isr_failed: tstamp:4372573323 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.421375: rtos_queue_send_from_isr_failed: tstamp:4372573460 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.421378: rtos_queue_send_from_isr_failed: tstamp:4372573596 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.421380: rtos_queue_send_failed: tstamp:4372575004 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.421385: rtcpu_vinotify_event: tstamp:4372576463 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4372575503 data:0x00000001
kworker/5:4-5487 [005] … 127.421387: rtcpu_vinotify_event: tstamp:4373547720 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4373547118 data:0x00000001
kworker/5:4-5487 [005] … 127.421390: rtcpu_vinotify_event: tstamp:4373547896 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4373547118 data:0x00000001
kworker/5:4-5487 [005] … 127.533283: rtos_queue_peek_from_isr_failed: tstamp:4376537514 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 127.590201: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 127.590236: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 127.593266: rtos_queue_send_from_isr_failed: tstamp:4379427081 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.593270: rtos_queue_send_from_isr_failed: tstamp:4379427227 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.593271: rtos_queue_send_from_isr_failed: tstamp:4379427373 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.593272: rtos_queue_send_from_isr_failed: tstamp:4379427511 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.593274: rtos_queue_send_from_isr_failed: tstamp:4379427649 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.593275: rtos_queue_send_from_isr_failed: tstamp:4379427786 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.593277: rtos_queue_send_from_isr_failed: tstamp:4379427929 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.593278: rtos_queue_send_from_isr_failed: tstamp:4379428066 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.593280: rtos_queue_send_failed: tstamp:4379428795 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.593282: rtos_queue_send_from_isr_failed: tstamp:4379433990 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.593283: rtos_queue_send_from_isr_failed: tstamp:4379434128 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.593285: rtos_queue_send_from_isr_failed: tstamp:4379434267 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.593286: rtos_queue_send_from_isr_failed: tstamp:4379434407 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.593288: rtos_queue_send_from_isr_failed: tstamp:4379434546 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.593289: rtos_queue_send_from_isr_failed: tstamp:4379434684 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.593291: rtos_queue_send_from_isr_failed: tstamp:4379434821 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.593292: rtos_queue_send_from_isr_failed: tstamp:4379434958 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.593294: rtos_queue_send_failed: tstamp:4379435538 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.593295: rtos_queue_send_from_isr_failed: tstamp:4379442746 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.593297: rtos_queue_send_from_isr_failed: tstamp:4379442885 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.593298: rtos_queue_send_from_isr_failed: tstamp:4379443025 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.593300: rtos_queue_send_from_isr_failed: tstamp:4379443165 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.593301: rtos_queue_send_from_isr_failed: tstamp:4379443304 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.593303: rtos_queue_send_from_isr_failed: tstamp:4379443441 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.593304: rtos_queue_send_from_isr_failed: tstamp:4379443580 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.593306: rtos_queue_send_from_isr_failed: tstamp:4379443717 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.593307: rtos_queue_send_failed: tstamp:4379444292 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.593309: rtos_queue_send_from_isr_failed: tstamp:4379447100 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.593310: rtos_queue_send_from_isr_failed: tstamp:4379447241 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.593312: rtos_queue_send_from_isr_failed: tstamp:4379447379 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.593313: rtos_queue_send_from_isr_failed: tstamp:4379447519 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.593315: rtos_queue_send_from_isr_failed: tstamp:4379447658 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.593316: rtos_queue_send_from_isr_failed: tstamp:4379447815 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.593318: rtos_queue_send_from_isr_failed: tstamp:4379447952 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.593319: rtos_queue_send_from_isr_failed: tstamp:4379448101 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.593321: rtos_queue_send_failed: tstamp:4379449493 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.649268: rtcpu_vinotify_event: tstamp:4380792851 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4380792258 data:0x00000001
kworker/5:4-5487 [005] … 127.649274: rtcpu_vinotify_event: tstamp:4380793050 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4380792258 data:0x00000001
kworker/5:4-5487 [005] … 127.705267: rtos_queue_peek_from_isr_failed: tstamp:4381537546 queue:0x0b4b4500
kworker/5:4-5487 [005] … 127.817595: rtos_queue_send_from_isr_failed: tstamp:4386300782 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.817599: rtos_queue_send_from_isr_failed: tstamp:4386300928 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.817601: rtos_queue_send_from_isr_failed: tstamp:4386301066 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.817602: rtos_queue_send_from_isr_failed: tstamp:4386301206 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.817604: rtos_queue_send_from_isr_failed: tstamp:4386301344 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.817605: rtos_queue_send_from_isr_failed: tstamp:4386301480 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.817607: rtos_queue_send_from_isr_failed: tstamp:4386301617 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.817609: rtos_queue_send_from_isr_failed: tstamp:4386301755 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.817611: rtos_queue_send_failed: tstamp:4386302495 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.817612: rtos_queue_send_from_isr_failed: tstamp:4386304978 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.817614: rtos_queue_send_from_isr_failed: tstamp:4386305117 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.817615: rtos_queue_send_from_isr_failed: tstamp:4386305261 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.817619: rtos_queue_send_from_isr_failed: tstamp:4386305400 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.817621: rtos_queue_send_from_isr_failed: tstamp:4386305537 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.817622: rtos_queue_send_from_isr_failed: tstamp:4386305676 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.817624: rtos_queue_send_from_isr_failed: tstamp:4386305813 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.817626: rtos_queue_send_from_isr_failed: tstamp:4386305951 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.817628: rtos_queue_send_failed: tstamp:4386306516 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.817631: rtos_queue_peek_from_isr_failed: tstamp:4386537526 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 127.826335: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 127.826366: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 127.873298: rtos_queue_send_from_isr_failed: tstamp:4386821630 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.873306: rtos_queue_send_from_isr_failed: tstamp:4386821776 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.873308: rtos_queue_send_from_isr_failed: tstamp:4386821916 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.873311: rtos_queue_send_from_isr_failed: tstamp:4386822054 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.873313: rtos_queue_send_from_isr_failed: tstamp:4386822201 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.873316: rtos_queue_send_from_isr_failed: tstamp:4386822338 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.873318: rtos_queue_send_from_isr_failed: tstamp:4386822476 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.873320: rtos_queue_send_from_isr_failed: tstamp:4386822613 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.873324: rtos_queue_send_failed: tstamp:4386823231 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.873326: rtos_queue_send_from_isr_failed: tstamp:4386826930 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.873328: rtos_queue_send_from_isr_failed: tstamp:4386827069 queue:0x0b4aad68
kworker/5:4-5487 [005] … 127.873331: rtos_queue_send_from_isr_failed: tstamp:4386827207 queue:0x0b4ac998
kworker/5:4-5487 [005] … 127.873333: rtos_queue_send_from_isr_failed: tstamp:4386827346 queue:0x0b4ae518
kworker/5:4-5487 [005] … 127.873335: rtos_queue_send_from_isr_failed: tstamp:4386827485 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 127.873338: rtos_queue_send_from_isr_failed: tstamp:4386827622 queue:0x0b4b0098
kworker/5:4-5487 [005] … 127.873340: rtos_queue_send_from_isr_failed: tstamp:4386827760 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 127.873343: rtos_queue_send_from_isr_failed: tstamp:4386827897 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 127.873345: rtos_queue_send_failed: tstamp:4386829289 queue:0x0b4a7258
kworker/5:4-5487 [005] … 127.873349: rtcpu_vinotify_event: tstamp:4386830686 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4386829528 data:0x00000001
kworker/5:4-5487 [005] … 127.873352: rtcpu_vinotify_event: tstamp:4388037991 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4388037398 data:0x00000001
kworker/5:4-5487 [005] … 127.873354: rtcpu_vinotify_event: tstamp:4388038166 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4388037398 data:0x00000001
kworker/5:4-5487 [005] … 127.985257: rtos_queue_peek_from_isr_failed: tstamp:4391537544 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 128.046312: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 128.046350: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 128.097295: rtos_queue_send_from_isr_failed: tstamp:4393680630 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097302: rtos_queue_send_from_isr_failed: tstamp:4393680777 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.097304: rtos_queue_send_from_isr_failed: tstamp:4393680922 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.097306: rtos_queue_send_from_isr_failed: tstamp:4393681062 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.097309: rtos_queue_send_from_isr_failed: tstamp:4393681206 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.097311: rtos_queue_send_from_isr_failed: tstamp:4393681343 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.097314: rtos_queue_send_from_isr_failed: tstamp:4393681482 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.097316: rtos_queue_send_from_isr_failed: tstamp:4393681619 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.097319: rtos_queue_send_failed: tstamp:4393682396 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097321: rtos_queue_send_from_isr_failed: tstamp:4393687768 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097324: rtos_queue_send_from_isr_failed: tstamp:4393687908 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.097326: rtos_queue_send_from_isr_failed: tstamp:4393688047 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.097329: rtos_queue_send_from_isr_failed: tstamp:4393688187 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.097331: rtos_queue_send_from_isr_failed: tstamp:4393688326 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.097333: rtos_queue_send_from_isr_failed: tstamp:4393688463 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.097336: rtos_queue_send_from_isr_failed: tstamp:4393688601 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.097338: rtos_queue_send_from_isr_failed: tstamp:4393688738 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.097340: rtos_queue_send_failed: tstamp:4393689296 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097343: rtos_queue_send_from_isr_failed: tstamp:4393695635 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097345: rtos_queue_send_from_isr_failed: tstamp:4393695776 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.097348: rtos_queue_send_from_isr_failed: tstamp:4393695915 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.097350: rtos_queue_send_from_isr_failed: tstamp:4393696055 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.097353: rtos_queue_send_from_isr_failed: tstamp:4393696193 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.097355: rtos_queue_send_from_isr_failed: tstamp:4393696330 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.097357: rtos_queue_send_from_isr_failed: tstamp:4393696468 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.097360: rtos_queue_send_from_isr_failed: tstamp:4393696606 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.097362: rtos_queue_send_failed: tstamp:4393697174 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097365: rtos_queue_send_from_isr_failed: tstamp:4393700345 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097367: rtos_queue_send_from_isr_failed: tstamp:4393700485 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.097369: rtos_queue_send_from_isr_failed: tstamp:4393700624 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.097372: rtos_queue_send_from_isr_failed: tstamp:4393700764 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.097374: rtos_queue_send_from_isr_failed: tstamp:4393700904 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.097376: rtos_queue_send_from_isr_failed: tstamp:4393701041 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.097379: rtos_queue_send_from_isr_failed: tstamp:4393701181 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.097381: rtos_queue_send_from_isr_failed: tstamp:4393701326 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.097384: rtos_queue_send_failed: tstamp:4393702714 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.097387: rtcpu_vinotify_event: tstamp:4393704180 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4393703235 data:0x00000001
kworker/5:4-5487 [005] … 128.097389: rtcpu_vinotify_event: tstamp:4394558621 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4394558023 data:0x00000001
kworker/5:4-5487 [005] … 128.097391: rtcpu_vinotify_event: tstamp:4394558798 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4394558023 data:0x00000001
kworker/5:4-5487 [005] … 128.153284: rtos_queue_peek_from_isr_failed: tstamp:4396537540 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 128.266273: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 128.266312: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 128.321322: rtos_queue_send_from_isr_failed: tstamp:4400553220 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321330: rtos_queue_send_from_isr_failed: tstamp:4400553368 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.321333: rtos_queue_send_from_isr_failed: tstamp:4400553509 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.321335: rtos_queue_send_from_isr_failed: tstamp:4400553650 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.321338: rtos_queue_send_from_isr_failed: tstamp:4400553787 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.321341: rtos_queue_send_from_isr_failed: tstamp:4400553931 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.321343: rtos_queue_send_from_isr_failed: tstamp:4400554068 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.321346: rtos_queue_send_from_isr_failed: tstamp:4400554206 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.321349: rtos_queue_send_failed: tstamp:4400554943 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321351: rtos_queue_send_from_isr_failed: tstamp:4400561698 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321354: rtos_queue_send_from_isr_failed: tstamp:4400561842 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.321356: rtos_queue_send_from_isr_failed: tstamp:4400561982 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.321359: rtos_queue_send_from_isr_failed: tstamp:4400562122 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.321361: rtos_queue_send_from_isr_failed: tstamp:4400562259 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.321364: rtos_queue_send_from_isr_failed: tstamp:4400562397 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.321366: rtos_queue_send_from_isr_failed: tstamp:4400562561 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.321368: rtos_queue_send_from_isr_failed: tstamp:4400562699 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.321371: rtos_queue_send_failed: tstamp:4400563266 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321374: rtos_queue_send_from_isr_failed: tstamp:4400568981 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321376: rtos_queue_send_from_isr_failed: tstamp:4400569138 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.321378: rtos_queue_send_from_isr_failed: tstamp:4400569277 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.321381: rtos_queue_send_from_isr_failed: tstamp:4400569417 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.321383: rtos_queue_send_from_isr_failed: tstamp:4400569554 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.321386: rtos_queue_send_from_isr_failed: tstamp:4400569697 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.321388: rtos_queue_send_from_isr_failed: tstamp:4400569834 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.321390: rtos_queue_send_from_isr_failed: tstamp:4400569973 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.321393: rtos_queue_send_failed: tstamp:4400570544 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321395: rtos_queue_send_from_isr_failed: tstamp:4400574005 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321398: rtos_queue_send_from_isr_failed: tstamp:4400574143 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.321400: rtos_queue_send_from_isr_failed: tstamp:4400574282 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.321402: rtos_queue_send_from_isr_failed: tstamp:4400574421 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.321405: rtos_queue_send_from_isr_failed: tstamp:4400574558 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.321407: rtos_queue_send_from_isr_failed: tstamp:4400574696 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.321409: rtos_queue_send_from_isr_failed: tstamp:4400574833 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.321412: rtos_queue_send_from_isr_failed: tstamp:4400574972 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.321414: rtos_queue_send_failed: tstamp:4400576358 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.321418: rtcpu_vinotify_event: tstamp:4400577787 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4400576948 data:0x00000001
kworker/5:4-5487 [005] … 128.321421: rtos_queue_peek_from_isr_failed: tstamp:4401537559 queue:0x0b4b4500
kworker/5:4-5487 [005] … 128.321423: rtcpu_vinotify_event: tstamp:4401803751 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4401803163 data:0x00000001
kworker/5:4-5487 [005] … 128.321425: rtcpu_vinotify_event: tstamp:4401803929 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4401803163 data:0x00000001
vi-output, imx3-8640 [004] … 128.486153: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 128.486188: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 128.489256: rtos_queue_peek_from_isr_failed: tstamp:4406537554 queue:0x0b4b4500
kworker/5:4-5487 [005] … 128.489260: rtos_queue_send_from_isr_failed: tstamp:4407426110 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489263: rtos_queue_send_from_isr_failed: tstamp:4407426276 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.489265: rtos_queue_send_from_isr_failed: tstamp:4407426417 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.489267: rtos_queue_send_from_isr_failed: tstamp:4407426557 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.489268: rtos_queue_send_from_isr_failed: tstamp:4407426695 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.489270: rtos_queue_send_from_isr_failed: tstamp:4407426833 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.489272: rtos_queue_send_from_isr_failed: tstamp:4407426971 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.489274: rtos_queue_send_from_isr_failed: tstamp:4407427108 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.489276: rtos_queue_send_failed: tstamp:4407427850 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489278: rtos_queue_send_from_isr_failed: tstamp:4407431802 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489280: rtos_queue_send_from_isr_failed: tstamp:4407431942 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.489281: rtos_queue_send_from_isr_failed: tstamp:4407432082 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.489283: rtos_queue_send_from_isr_failed: tstamp:4407432222 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.489285: rtos_queue_send_from_isr_failed: tstamp:4407432362 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.489287: rtos_queue_send_from_isr_failed: tstamp:4407432500 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.489289: rtos_queue_send_from_isr_failed: tstamp:4407432639 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.489290: rtos_queue_send_from_isr_failed: tstamp:4407432776 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.489292: rtos_queue_send_failed: tstamp:4407433339 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489294: rtos_queue_send_from_isr_failed: tstamp:4407440319 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489296: rtos_queue_send_from_isr_failed: tstamp:4407440458 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.489298: rtos_queue_send_from_isr_failed: tstamp:4407440596 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.489300: rtos_queue_send_from_isr_failed: tstamp:4407440736 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.489301: rtos_queue_send_from_isr_failed: tstamp:4407440874 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.489303: rtos_queue_send_from_isr_failed: tstamp:4407441011 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.489305: rtos_queue_send_from_isr_failed: tstamp:4407441150 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.489307: rtos_queue_send_from_isr_failed: tstamp:4407441290 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.489309: rtos_queue_send_failed: tstamp:4407441851 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489310: rtos_queue_send_from_isr_failed: tstamp:4407445181 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489312: rtos_queue_send_from_isr_failed: tstamp:4407445321 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.489314: rtos_queue_send_from_isr_failed: tstamp:4407445464 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.489318: rtos_queue_send_from_isr_failed: tstamp:4407445605 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.489320: rtos_queue_send_from_isr_failed: tstamp:4407445745 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.489322: rtos_queue_send_from_isr_failed: tstamp:4407445885 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.489324: rtos_queue_send_from_isr_failed: tstamp:4407446032 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.489326: rtos_queue_send_from_isr_failed: tstamp:4407446169 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.489328: rtos_queue_send_failed: tstamp:4407447544 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.489331: rtcpu_vinotify_event: tstamp:4407448972 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4407448018 data:0x00000001
kworker/5:4-5487 [005] … 128.545297: rtcpu_vinotify_event: tstamp:4408324382 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4408323788 data:0x00000001
kworker/5:4-5487 [005] … 128.545303: rtcpu_vinotify_event: tstamp:4408324558 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4408323788 data:0x00000001
kworker/5:4-5487 [005] … 128.657286: rtos_queue_peek_from_isr_failed: tstamp:4411537597 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 128.706130: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 128.706167: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 128.713299: rtos_queue_send_from_isr_failed: tstamp:4414301017 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.713304: rtos_queue_send_from_isr_failed: tstamp:4414301165 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.713307: rtos_queue_send_from_isr_failed: tstamp:4414301306 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.713309: rtos_queue_send_from_isr_failed: tstamp:4414301446 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.713311: rtos_queue_send_from_isr_failed: tstamp:4414301586 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.713314: rtos_queue_send_from_isr_failed: tstamp:4414301725 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.713316: rtos_queue_send_from_isr_failed: tstamp:4414301861 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.713319: rtos_queue_send_from_isr_failed: tstamp:4414301999 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.713322: rtos_queue_send_failed: tstamp:4414302725 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.713324: rtos_queue_send_from_isr_failed: tstamp:4414307145 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.713327: rtos_queue_send_from_isr_failed: tstamp:4414307286 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.713329: rtos_queue_send_from_isr_failed: tstamp:4414307425 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.713331: rtos_queue_send_from_isr_failed: tstamp:4414307565 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.713334: rtos_queue_send_from_isr_failed: tstamp:4414307703 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.713336: rtos_queue_send_from_isr_failed: tstamp:4414307840 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.713339: rtos_queue_send_from_isr_failed: tstamp:4414307978 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.713341: rtos_queue_send_from_isr_failed: tstamp:4414308116 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.713344: rtos_queue_send_failed: tstamp:4414308678 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.713346: rtos_queue_send_from_isr_failed: tstamp:4414314876 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.713348: rtos_queue_send_from_isr_failed: tstamp:4414315020 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.713351: rtos_queue_send_from_isr_failed: tstamp:4414315159 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.713353: rtos_queue_send_from_isr_failed: tstamp:4414315297 queue:0x0b4ae518
kworker/5:4-5487 [005] .n… 128.713356: rtos_queue_send_from_isr_failed: tstamp:4414315435 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.713401: rtos_queue_send_from_isr_failed: tstamp:4414315592 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.713403: rtos_queue_send_from_isr_failed: tstamp:4414315734 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.713406: rtos_queue_send_from_isr_failed: tstamp:4414315882 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.713408: rtos_queue_send_failed: tstamp:4414316449 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.713411: rtos_queue_send_from_isr_failed: tstamp:4414319663 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.713413: rtos_queue_send_from_isr_failed: tstamp:4414319803 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.713415: rtos_queue_send_from_isr_failed: tstamp:4414319943 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.713418: rtos_queue_send_from_isr_failed: tstamp:4414320083 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.713420: rtos_queue_send_from_isr_failed: tstamp:4414320221 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.713423: rtos_queue_send_from_isr_failed: tstamp:4414320358 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.713425: rtos_queue_send_from_isr_failed: tstamp:4414320496 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.713427: rtos_queue_send_from_isr_failed: tstamp:4414320632 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.713430: rtos_queue_send_failed: tstamp:4414322045 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.769263: rtcpu_vinotify_event: tstamp:4415569519 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4415568928 data:0x00000001
kworker/5:4-5487 [005] … 128.769268: rtcpu_vinotify_event: tstamp:4415569720 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4415568928 data:0x00000001
kworker/5:4-5487 [005] … 128.825295: rtos_queue_peek_from_isr_failed: tstamp:4416537580 queue:0x0b4b4500
vi-output, imx3-8640 [004] … 128.926039: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1024 fmt 20
vi-output, imx3-8640 [004] … 128.926075: tegra_channel_capture_frame: sof:-549620695332.-268101481408
kworker/5:4-5487 [005] … 128.937270: rtos_queue_send_from_isr_failed: tstamp:4421176381 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937277: rtos_queue_send_from_isr_failed: tstamp:4421176526 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.937279: rtos_queue_send_from_isr_failed: tstamp:4421176670 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.937282: rtos_queue_send_from_isr_failed: tstamp:4421176810 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.937284: rtos_queue_send_from_isr_failed: tstamp:4421176947 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.937286: rtos_queue_send_from_isr_failed: tstamp:4421177085 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.937289: rtos_queue_send_from_isr_failed: tstamp:4421177222 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.937291: rtos_queue_send_from_isr_failed: tstamp:4421177360 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.937295: rtos_queue_send_failed: tstamp:4421178095 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937297: rtos_queue_send_from_isr_failed: tstamp:4421181208 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937300: rtos_queue_send_from_isr_failed: tstamp:4421181348 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.937302: rtos_queue_send_from_isr_failed: tstamp:4421181487 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.937304: rtos_queue_send_from_isr_failed: tstamp:4421181626 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.937307: rtos_queue_send_from_isr_failed: tstamp:4421181763 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.937309: rtos_queue_send_from_isr_failed: tstamp:4421181902 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.937312: rtos_queue_send_from_isr_failed: tstamp:4421182039 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.937314: rtos_queue_send_from_isr_failed: tstamp:4421182178 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.937317: rtos_queue_send_failed: tstamp:4421182759 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937319: rtos_queue_send_from_isr_failed: tstamp:4421188196 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937322: rtos_queue_send_from_isr_failed: tstamp:4421188335 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.937324: rtos_queue_send_from_isr_failed: tstamp:4421188473 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.937326: rtos_queue_send_from_isr_failed: tstamp:4421188614 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.937329: rtos_queue_send_from_isr_failed: tstamp:4421188751 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.937331: rtos_queue_send_from_isr_failed: tstamp:4421188890 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.937334: rtos_queue_send_from_isr_failed: tstamp:4421189027 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.937336: rtos_queue_send_from_isr_failed: tstamp:4421189165 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.937338: rtos_queue_send_failed: tstamp:4421189757 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937341: rtos_queue_send_from_isr_failed: tstamp:4421192170 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937343: rtos_queue_send_from_isr_failed: tstamp:4421192310 queue:0x0b4aad68
kworker/5:4-5487 [005] … 128.937345: rtos_queue_send_from_isr_failed: tstamp:4421192449 queue:0x0b4ac998
kworker/5:4-5487 [005] … 128.937348: rtos_queue_send_from_isr_failed: tstamp:4421192588 queue:0x0b4ae518
kworker/5:4-5487 [005] … 128.937350: rtos_queue_send_from_isr_failed: tstamp:4421192725 queue:0x0b4af2d8
kworker/5:4-5487 [005] … 128.937353: rtos_queue_send_from_isr_failed: tstamp:4421192865 queue:0x0b4b0098
kworker/5:4-5487 [005] … 128.937355: rtos_queue_send_from_isr_failed: tstamp:4421193004 queue:0x0b4b0e58
kworker/5:4-5487 [005] … 128.937357: rtos_queue_send_from_isr_failed: tstamp:4421193145 queue:0x0b4b1c18
kworker/5:4-5487 [005] … 128.937360: rtos_queue_send_failed: tstamp:4421194595 queue:0x0b4a7258
kworker/5:4-5487 [005] … 128.937363: rtos_queue_peek_from_isr_failed: tstamp:4421537574 queue:0x0b4b4500
kworker/5:4-5487 [005] … 128.993298: rtcpu_vinotify_event: tstamp:4422090148 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4422089553 data:0x00000001
kworker/5:4-5487 [005] … 128.993304: rtcpu_vinotify_event: tstamp:4422090328 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4422089553 data:0x00000001
kworker/5:4-5487 [005] … 129.105293: rtos_queue_peek_from_isr_failed: tstamp:4426537583 queue:0x0b4b4500
kworker/5:4-5487 [005] … 129.161242: rtos_queue_send_from_isr_failed: tstamp:4428051905 queue:0x0b4a7258
kworker/5:4-5487 [005] … 129.161250: rtos_queue_send_from_isr_failed: tstamp:4428052053 queue:0x0b4aad68
kworker/5:4-5487 [005] … 129.161252: rtos_queue_send_from_isr_failed: tstamp:4428052194 queue:0x0b4ac998
the part of dts which I changed has a look:
active_w = “640”;
active_h = “512”;
line_length = “900”;
pix_clk_hz = “20000000”;
I have already tried to reduce the image size in DTS but it does not give any effect.
Can you tell me where I’m making a mistake?
Is there any software grabber mipi bus so I can see what exactly the TX2 gets?
Can I somehow find out what frame size I get TX2 directly?
