Problems doing shared memory test
I am trying to run the following code:
__global__ void
testKernel( float* g_idata, int data_size, unsigned int block_size)
  // access thread id
  const unsigned int tid = (blockIdx.x * blockDim.x) + threadIdx.x;
  // access number of threads in this block
  //const unsigned int num_threads = blockDim.x;
  const unsigned int num_threads = block_size;
 int slices = data_size / num_threads;
  int js;
 __shared__ float shared_data[2048];
 for(int i = 0; i < 2048; i++){
   shared_data[i] = g_idata[i];
 __syncthreads();
 for(int i = 0; i < slices; i++){
	js = (tid*slices) + i;
	for(int j = 0; j < 200000; j++){
  //g_idata[js] = g_idata[js] + 2;
  //g_idata[js] = g_idata[js] - 1;
  shared_data[js] = shared_data[js] + 2;
  shared_data[js] = shared_data[js] - 1;
   g_idata[i] = shared_data[i];
My previous code using g_idata worked fine but now with shared memory only about the last half gets set to the right numbers. What am I doing wrong?
I guess you’re using shared memory in a wrong way.
When you declare shared float shared_data[2048]; this means that those 2048 of floats will be shared among threads of a single block, not each thread getting its 2048 floats from shared memory pool.
So, when you copy data from global to shared memory all of your threads read the same data from global memory and write to same shared memory address.
Also it will be a good idea to insert __syncthreads() somewhere after you update shared memory, i.e. after the inner loop bacause without it you really may get incorrect results.
