When I followed the manual to flash AGX Orin 64G, I encountered some problems. I used sdkmanager to download all the components, and then started to install, and then the interface popped up, and I entered recovery again, selected the mode to install manually, and created a user. After clicking flash, it showed that the nvidia usb driver was removed, and then the installation failed. I’ve tried many times with the same result.
The USB-typec cable I used was original. At first I thought it was a problem with the cable, and then replaced it with a non-original cable, but the same result remained. I don’t know why this is happening and I can’t fix it.
Thank you very much for the reminder, I repeated the same process, the result is still showing “nvidia usb driver was removed” during the installation phase, and then the installation failed. There are two lines of error messages on the terminal interface as follows:
ERROR: Flash Jetson AGX Orin - flash: command terminated with error
SUMMARY: DateTime Target Setup - target: Depends on failed component
