Hi All.
I’m hoping someone can help me.
I have a Jetson and a few other computers on a router. All other the computers (including the Jetson) are set to use DHCP. I can boot the Jeston, ping the other computers on the router from it and have other computers log into the Jetson.
However, I am unable to go online or ping any external networks from the Jetson. It has its wired connection set not to use additional DNS and its nm-tool and ifconfig outputs are shown below:
Device: eth0 [Wired connection 1] -------------------------------------------
Type: Wired
Driver: r8169
State: connected
Default: yes
HW Address: 00:04:4B:21:29:42Capabilities:
Carrier Detect: yes
Speed: 100 Mb/sWired Properties
Carrier: onIPv4 Settings:
Address: 192.168.0.106
Prefix: 24 (255.255.255.0)
Gateway: 192.168.0.1DNS: 192.168.0.1
With ifconfig looking like:
eth0 Link encap:Ethernet HWaddr 00:04:4b:21:29:42
inet addr:192.168.0.106 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::204:4bff:fe21:2942/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2477 errors:0 dropped:7 overruns:0 frame:0
TX packets:1139 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:189588 (189.5 KB) TX bytes:141308 (141.3 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:94 errors:0 dropped:0 overruns:0 frame:0
TX packets:94 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:9972 (9.9 KB) TX bytes:9972 (9.9 KB)
One of the computers on the router is also running Ubuntu 14.04 and has it’s network connections set up in the same way as the jetson and can access the internet with no problems.
Has anyone seen this and if so, what am I doing wrong?
Many thanks,
Trefor
