Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.0.10363
other
Host Machine Version
native Ubuntu 18.04
other
Hi!
We are trying to initialise a custom GMSL camera connected to camera port A0 on the drive AGX by writing to its registers via i2c. I have a few questions regarding this and would appreciate any inputs or clues.
I noticed that the nvmedia sample application img_cc uses i2c config files to enable streaming for the Sekronix SF3325 camera which came with the Drive AGX kit. I would like to take a look at the source code to figure out how they are managing this i2c communication but the source code is missing, both on the host and the target. Could someone please let me know where the .cpp or .c source code is?
When I modify a sample config file to include the proper serialiser and sensor register values for our custom camera and leave the deserialiser config values as it is, running the sample with this modified config file with our custom camera connected results in the error
nvmedia: ERROR: ProcessCommands: Failed to write to I2C 29 0c08 25
This error doesn’t appear with the Sekronix camera and the sample runs properly. I would like to know what device this address belongs to or what role it plays in the sample application, because following the error no values are written to the camera, serdes registers via i2c. -
According to the sample config files, the deserialisers reside on address 0x52 on the i2c devices 0, 1 and 7. But when I poll the i2c bus, I see no devices on this address on any i2c device.
Trying to use linux commandsi2cget
andi2cset
to write to deserialiser registers on address 0x52 in the i2c bus manually result in errors. Could you let me know whether something needs to be done with the deserialisers before trying to write to it via i2c?
My goal is basically to enable streaming for the custom GMSL camera and capture the frames for some processing. We went with this camera because it supports GMSL with the max 96712 des just like the Sekronix sample camera and we assumed this would be the most similar way to capture frames from a camera connected to the nvidia drive AGX kit.
