Hello
I tried for a long time to install imgaug on a jetson AGX xavier, but with no success.
I tried installing it with:
pip install imgaug
And pretty much anything else i have found when searching around.
The error i get is:
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: imgaug in ./.local/lib/python3.6/site-packages (0.4.0)
Collecting numpy>=1.15
Using cached numpy-1.18.1.zip (5.4 MB)
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-aogsx35f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools wheel 'Cython>=0.29.14'
cwd: None
Complete output (39 lines):
File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.6/dist-packages/pip/__main__.py", line 16, in <module>
from pip._internal.cli.main import main as _main # isort:skip # noqa
File "/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/main.py", line 5, in <module>
import locale
File "/usr/lib/python3.6/locale.py", line 16, in <module>
import re
File "/usr/lib/python3.6/re.py", line 142, in <module>
class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 53, in apport_excepthook
if not enabled():
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 24, in enabled
import re
Original exception was:
import locale
import re
ERROR: Command errored out with exit status 1: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-aogsx35f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools wheel 'Cython>=0.29.14' Check the logs for full command output.
Thanks for replay!
