Problems linking multiple demuxers to a Tee'd batched stream on dGPU
GPU
• DeepStream Version
6.2
• TensorRT Version
Problem linking/playing a Pipeline on dGPU with two DeepStream demuxer plugins… seems to work well on Jetson.
I have a user of my DSL work here… that is trying to build a multi-source Pipeline that splits the batched output stream with a Tee so that each new batched stream can be processed differently. After processing, each batched stream is to be demuxed so that the individual streams can be rendered, encoded, or dropped… depending on the downstream sink that is linked to each demuxed branch.
We’ve simplified the Pipeline down to a single URI-Source Bin, Streammuxer, Tee, 2-Demuxers and 2-Window-Sink Bins.
The Pipeline links and plays well on Jetson, but fails on dGPU.
Here is the Pipeline graph for dGPU. I’ve cutoff the source-bin to minimize the size of the file. You can see clearly that the top branch connected to the first demuxer is not linked correctly, however, the lower (identical) branch is.
Here is the Pipeline graph for Jetson and you can see that both demuxers and branches have linked correctly.
The one difference between the two cases above is in the implementation of the Window-Sink Bin.
For dGPU we have
queue->nvvideoconvert->capsfilter->nveglglessink
and for Jetson we have
queue->nvegltransform->nveglglessink
Perhaps this is related to the issue? Any help will be greatly appreciated.
Thanks,
Robert
  1. the pictures are not clear, could you upload a zip file?
  2. about your “but fails on dGPU.”, is there any error log?
My apologies for the blurry images @fanzh … here are the complete images zipped
jetson_and_dgpu_pipelines.zip (2.0 MB)
Here’s an image of the bad link from Demuxer-1 to branch-1
Here’s an image of the what I think is a correct link for the other demuxer and branch.
… and here’s the log for the failing case
multi-demuxer.log (346.9 KB)
There are a number of messages indicating that the Pipeline is failing to transition state.
0:00:20.128480540 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstbin.c:2115:gst_bin_get_state_func:<pipeline1>e[00m getting state
0:00:20.128516494 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2485:gst_element_get_state_func:<pipeline1>e[00m waiting for element to commit state
0:00:20.128561509 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2500:gst_element_get_state_func:<pipeline1>e[00m timed out
0:00:20.128659318 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstbin.c:2115:gst_bin_get_state_func:<splitter>e[00m getting state
0:00:20.128683317 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2485:gst_element_get_state_func:<splitter>e[00m waiting for element to commit state
0:00:20.128702912 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2500:gst_element_get_state_func:<splitter>e[00m timed out
0:00:20.128877026 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstbin.c:2115:gst_bin_get_state_func:<branchB>e[00m getting state
0:00:20.128909861 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2485:gst_element_get_state_func:<branchB>e[00m waiting for element to commit state
0:00:20.128930475 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2500:gst_element_get_state_func:<branchB>e[00m timed out
0:00:20.129039727 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstbin.c:2115:gst_bin_get_state_func:<demuxer2>e[00m getting state
0:00:20.129063116 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2485:gst_element_get_state_func:<demuxer2>e[00m waiting for element to commit state
0:00:20.129082793 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2500:gst_element_get_state_func:<demuxer2>e[00m timed out
0:00:20.129184439 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstbin.c:2115:gst_bin_get_state_func:<wdemuxer21>e[00m getting state
0:00:20.129207163 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2485:gst_element_get_state_func:<wdemuxer21>e[00m waiting for element to commit state
0:00:20.129226750 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2500:gst_element_get_state_func:<wdemuxer21>e[00m timed out
0:00:20.129323859 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2485:gst_element_get_state_func:<wdemuxer21-nveglglessink>e[00m waiting for element to commit state
0:00:20.129346434 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstelement.c:2500:gst_element_get_state_func:<wdemuxer21-nveglglessink>e[00m timed out
0:00:20.131370699 e[35m90994e[00m      0x21b4600 e[36mINFO   e[00m e[00;01;31m          GST_STATES gstbin.c:2115:gst_bin_get_state_func:<branchA>e[00m getting state
And my user sent me a video of how the windows look when the Pipeline is played… on the chance it helps
Thanks again,
Robert.
please refer to Gst-nvstreamdemux — DeepStream 6.3 Release documentation, here is nvstreamdemux sample for dgpu and jetson.
@fanzh the examples use only a single demuxer which I have no problem with… as mentioned above, the problem is specific to running two demuxers from a split-batched stream on dGPU with Window-sinks.
Again, single demuxer on dGPU and Jetson… no problem
Two demuxers with split stream on Jetson… no problem
Two demuxers with split stream on dGPU… one of the Demuxers fails to link correctly.
And again, this might very well be do to my Window Sink bin implementation that is not negotiating caps correctly with the demuxer upstream… and not a demuxer issue.
Thanks,
Robert.
p.s. perhaps you’re confused by all of the pre-allocated request pads for each demuxer in the image above?? This is done to support the dynamic addition/removal of branches while the Pipeline is playing… This logic all works correctly, it is just the double demuxer link issue that is holding us back.
from the pipeline picture on dgpu, one sink negotiated while the other did not negotiated.
  1. could you share more logs? Thanks! both working and no working logs. please do “export GST_DEBUG=6” first to modify Gstreamer’s log level, then run again, you can redirect the logs to a file.
  2. could you provide a simplified code to reproduce this issue? Thanks!
I am using two demuxers with the same issue . when we set export GST_DEBUG=6, the log is:
dsl.txt (21.0 MB)
@fanzh here’s the dGPU failure log…
dgpu_failure_log_level_6.txt (21.0 MB)
I should have the passing case for Jetson shortly
the two files above are the same.
there is an error “0:00:13.607738749 e[31m230676e[00m 0x1b82800 e[31;01mERROR e[00m e[00m DSL src/DslNodetr.h:958:SetState:e[00m : FAILURE occured waiting for state to change to ‘PLAYING’ for GstNotetr ‘pipeline1’” is this DslNodetr.h your custom code?
why do you need “tee + two demuxer” method? if only want to view, I sugget using “one demuxer + tee”.
if want to do inference parallelly, please refer to GitHub - NVIDIA-AI-IOT/deepstream_parallel_inference_app: A project demonstrating how to use nvmetamux to run multiple models in parallel.
The user @446073615 – who is using my DeepStream Services Library – wants to do a lot more than just view each. The Pipeline was just simplified to show the problem.
Yes, parallel inference is some of what the user is trying to do. I will refer to the link… on first look, I see that that each demuxer is linked directly to another streammuxer vs. individual branches… interesting.
Just FYI, we tried with other types of sink bins… fake-sink, file-sink, rtsp-sink… same issue.
Sorry for the late reply. Thanks for the sharing. Is this still an DeepStream issue to support? Thanks
@fanzh here’s an image of roughly the kind of parallel inference that @446073615 is trying to do.
As you can see, it is far simpler than the deepstream_parallel_inference_app examples linked above.
I managed to hack up the deepstream_test3_app to run with a single uri-source, nvstreammux, tee, 2-nvstreamdemuxs, and 2-sinks, one connected to each demuxer. There is no inference or osd.
deepstream_test3_app.c (16.1 KB)
Here’s the pipeline graph produced from the provided c-code.
The same file zipped
pipeline (1).zip (283.1 KB)
It could easily be a mistake in my example, but this pipeline fails to play.
Thanks,
Robert.
here are two problems in your pipline.
  1. as you know, tee will not duplicate gstbuffer, and only send gstbuffer to each branch by turn. the effect of your pipeline is the same with “nvstreammux + yolov4 + bodypose”, there is no parallel inferencing effect.
  2. if queues are added after tee, multiple branchs will processing the same gstbuffer at the same time, there will be a problem of multiple threads operating.
@fanzh sorry but your remarks do not make any sense to me… there are plenty of deepstream examples that split/duplicate the stream after the osd with a tee so that one can both render as well as encode to file. How is this any different than splitting a batched stream??
All of the examples for the parallel inference use a tee to duplicate the stream ??? What am I missing here.
re: if queues are added after tee, multiple branchs will processing the same gstbuffer at the same time, there will be a problem of multiple threads operating.
This is the basic rule for using a tee… from the GStreamer documentation… “One needs to use separate queue elements (or a multiqueue) in each branch to provide separate threads for each branch. Otherwise a blocked dataflow in one branch would stall the other branches.” … see tee
@fanzh please forgive my confusion… after reviewing the gstreamer tee implementation I now have a much better understanding… and yes clearly the same buffers are being pushed to all pads with the buffer reference count updated accordingly (actually, I must have known this, thinking back to the secondary inference graph implementation).
Anyway, I now see why the extra demuxers are needed and why each is connected to an additional Streamuxer.
Thanks again for the help.
Regards,
Robert.
@fanzh sorry, one last question related to using tees… if I have the following
...->osd->tee->queue->nvvideoconvert->caps-filter->some-sink-bin
            ╰->queue->nvvideoconvert->caps-filter->some-sink-bin
Similar to how the deepstream_app is implemented to support multiple sink bins.
I’m assuming that, although the tee is pushing the same buffer to multiple branches, each branch can convert the buffers (using the nvvideoconvert plugin) to a different format and scale as needed… and that the nvvideoconvert plugin is making a copy of the buffer before transposing?
Thanks again.
