Problems of telemetry using detectnet_v2 using tao toolkit
guille@usuario-pc:/etc/docker$ docker --version
Docker version 23.0.1, build a5ee5b1
guille@usuario-pc:/etc/docker$ docker version
Client: Docker Engine - Community
Version: 23.0.1
API version: 1.42
Go version: go1.19.5
Git commit: a5ee5b1
Built: Thu Feb 9 19:46:56 2023
OS/Arch: linux/amd64
Context: default
Server: Docker Engine - Community
Engine:
Version: 23.0.1
API version: 1.42 (minimum version 1.12)
Git commit: bc3805a
Experimental: false
containerd:
Version: 1.6.18
GitCommit: 2456e983eb9e37e47538f59ea18f2043c9a73640
runc:
Version: 1.1.4
GitCommit: v1.1.4-0-g5fd4c4d
docker-init:
Version: 0.19.0
GitCommit: de40ad0
Could you run below to uninstall old driver and install new driver? It is not needed to do others.
sudo apt purge nvidia-driver-525
sudo apt autoremove
sudo apt autoclean
sudo apt install nvidia-driver-520
this is the result, the same
guille@usuario-pc:~/Descargas$ sudo apt install nvidia-driver-520
[sudo] contraseña para guille:
Leyendo lista de paquetes… Hecho
Creando árbol de dependencias
Leyendo la información de estado… Hecho
nvidia-driver-520 ya está en su versión más reciente (525.85.05-0ubuntu0.20.04.1).
0 actualizados, 0 nuevos se instalarán, 0 para eliminar y 0 no actualizados.
guille@usuario-pc:~/Descargas$ nvidia-smi
No devices were found
Can you share the log when run below?
sudo apt autoremove
sudo apt autoclean
BTW, could you set default language to English in Ubuntu for better understanding for the logs? Many thanks!
guille@usuario-pc:~$ sudo apt install nvidia-driver-520
[sudo] password for guille:
Reading package lists… Done
Building dependency tree
Reading state information… Done
nvidia-driver-520 is already the newest version (525.85.05-0ubuntu0.20.04.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
guille@usuario-pc:~$ nvidia-smi
Morgang, I’m sorry, where is the localization of log.
sudo apt autoremove
sudo apt autoclean
guille@usuario-pc:~$ sudo apt purge nvidia-driver-525
The following packages were automatically installed and are no longer required:
dctrl-tools dkms libatomic1:i386 libbsd0:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386 libelf1:i386 libexpat1:i386 libffi7:i386
libgl1:i386 libgl1-mesa-dri:i386 libglapi-mesa:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386 libllvm12:i386 libnvidia-cfg1-525 libnvidia-common-525 libnvidia-compute-525:i386 libnvidia-decode-525
libnvidia-decode-525:i386 libnvidia-encode-525 libnvidia-encode-525:i386 libnvidia-extra-525 libnvidia-fbc1-525 libnvidia-fbc1-525:i386 libnvidia-gl-525 libnvidia-gl-525:i386 libpciaccess0:i386
libsensors5:i386 libstdc++6:i386 libvulkan1:i386 libwayland-client0:i386 libx11-6:i386 libx11-xcb1:i386 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386
libxcb-randr0:i386 libxcb-shm0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386 libxcb1:i386 libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxnvctrl0 libxshmfence1:i386 libxxf86vm1:i386
mesa-vulkan-drivers:i386 nvidia-compute-utils-525 nvidia-dkms-525 nvidia-kernel-source-525 nvidia-settings nvidia-utils-525 screen-resolution-extra xserver-xorg-video-nvidia-525
Use ‘sudo apt autoremove’ to remove them.
The following packages will be REMOVED:
nvidia-driver-520* nvidia-driver-525*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 1.691 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database … 168146 files and directories currently installed.)
Removing nvidia-driver-520 (525.85.05-0ubuntu0.20.04.1) …
Removing nvidia-driver-525 (525.85.05-0ubuntu0.20.04.1) …
guille@usuario-pc:~$ sudo apt autoremove
0 upgraded, 0 newly installed, 63 to remove and 0 not upgraded.
After this operation, 1.408 MB disk space will be freed.
(Reading database … 168072 files and directories currently installed.)
Removing nvidia-dkms-525 (525.85.05-0ubuntu0.20.04.1) …
Removing all DKMS Modules
rmdir: failed to remove ‘’: No such file or directory
Done.
INFO:Disable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
update-initramfs: deferring update (trigger activated)
Removing dkms (2.8.1-5ubuntu2) …
Removing dctrl-tools (2.24-3) …
Removing mesa-vulkan-drivers:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Removing libnvidia-fbc1-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Removing libgl1:i386 (1.3.2-1~ubuntu0.20.04.2) …
Removing libglx0:i386 (1.3.2-1~ubuntu0.20.04.2) …
Removing libglx-mesa0:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Removing libgl1-mesa-dri:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Removing libllvm12:i386 (1:12.0.0-3ubuntu1~20.04.5) …
Removing libatomic1:i386 (10.3.0-1ubuntu1~20.04) …
Removing libedit2:i386 (3.1-20191231-1) …
Removing libnvidia-gl-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Removing libdrm-amdgpu1:i386 (2.4.107-8ubuntu1~20.04.2) …
Removing libdrm-intel1:i386 (2.4.107-8ubuntu1~20.04.2) …
Removing libdrm-nouveau2:i386 (2.4.107-8ubuntu1~20.04.2) …
Removing libdrm-radeon1:i386 (2.4.107-8ubuntu1~20.04.2) …
Removing libdrm2:i386 (2.4.107-8ubuntu1~20.04.2) …
Removing libelf1:i386 (0.176-1.1build1) …
Removing libexpat1:i386 (2.2.9-1ubuntu0.6) …
Removing libwayland-client0:i386 (1.18.0-1ubuntu0.1) …
Removing libffi7:i386 (3.3-4) …
Removing libglapi-mesa:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Removing libglvnd0:i386 (1.3.2-1~ubuntu0.20.04.2) …
Removing xserver-xorg-video-nvidia-525 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-cfg1-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-gl-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-common-525 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-encode-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-decode-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-compute-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-encode-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-decode-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-extra-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Removing libnvidia-fbc1-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Removing libpciaccess0:i386 (0.16-0ubuntu1) …
Removing libsensors5:i386 (1:3.6.0-2ubuntu1.1) …
Removing libstdc++6:i386 (10.3.0-1ubuntu1~20.04) …
Removing libvulkan1:i386 (1.2.131.2-1) …
Removing libxxf86vm1:i386 (1:1.1.4-1build1) …
Removing libx11-xcb1:i386 (2:1.6.9-2ubuntu1.2) …
Removing libxcb-dri3-0:i386 (1.14-2) …
Removing libxcb-dri2-0:i386 (1.14-2) …
Removing libxcb-glx0:i386 (1.14-2) …
Removing libxcb-present0:i386 (1.14-2) …
Removing libxcb-randr0:i386 (1.14-2) …
Removing libxcb-shm0:i386 (1.14-2) …
Removing libxcb-sync1:i386 (1.14-2) …
Removing libxcb-xfixes0:i386 (1.14-2) …
Removing libxext6:i386 (2:1.3.4-0ubuntu1) …
Removing libxfixes3:i386 (1:5.0.3-2) …
Removing nvidia-settings (470.57.01-0ubuntu0.20.04.3) …
Removing libxnvctrl0:amd64 (470.57.01-0ubuntu0.20.04.3) …
Removing libxshmfence1:i386 (1.3-1) …
Removing nvidia-compute-utils-525 (525.85.05-0ubuntu0.20.04.1) …
Removing nvidia-kernel-source-525 (525.85.05-0ubuntu0.20.04.1) …
Removing nvidia-utils-525 (525.85.05-0ubuntu0.20.04.1) …
Removing screen-resolution-extra (0.18build1) …
Removing libx11-6:i386 (2:1.6.9-2ubuntu1.2) …
Removing libxcb1:i386 (1.14-2) …
Removing libxdmcp6:i386 (1:1.1.3-0ubuntu1) …
Removing libbsd0:i386 (0.10.0-1) …
Removing libxau6:i386 (1:1.0.9-0ubuntu1) …
Processing triggers for mime-support (3.64ubuntu1) …
Processing triggers for initramfs-tools (0.136ubuntu6.7) …
update-initramfs: Generating /boot/initrd.img-5.15.0-67-generic
Processing triggers for gnome-menus (3.36.0-1ubuntu1) …
Processing triggers for libc-bin (2.31-0ubuntu9.9) …
Processing triggers for man-db (2.9.1-1) …
Processing triggers for desktop-file-utils (0.24-1ubuntu3) …
guille@usuario-pc:~$ sudo apt autoclean
The following additional packages will be installed:
mesa-vulkan-drivers:i386 nvidia-compute-utils-525 nvidia-dkms-525 nvidia-driver-525 nvidia-kernel-source-525 nvidia-settings nvidia-utils-525 screen-resolution-extra xserver-xorg-video-nvidia-525
Suggested packages:
debtags menu lm-sensors:i386
The following NEW packages will be installed:
mesa-vulkan-drivers:i386 nvidia-compute-utils-525 nvidia-dkms-525 nvidia-driver-520 nvidia-driver-525 nvidia-kernel-source-525 nvidia-settings nvidia-utils-525 screen-resolution-extra
0 upgraded, 65 newly installed, 0 to remove and 0 not upgraded.
Need to get 64,9 MB/357 MB of archives.
After this operation, 1.410 MB of additional disk space will be used.
Get:1 Index of /ubuntu focal/main amd64 dctrl-tools amd64 2.24-3 [61,5 kB]
Get:2 Index of /ubuntu focal-updates/main amd64 dkms all 2.8.1-5ubuntu2 [66,8 kB]
Get:3 Index of /ubuntu focal/main i386 libbsd0 i386 0.10.0-1 [49,8 kB]
Get:4 Index of /ubuntu focal/main i386 libelf1 i386 0.176-1.1build1 [50,5 kB]
Get:5 Index of /ubuntu focal/main i386 libffi7 i386 3.3-4 [17,9 kB]
Get:6 Index of /ubuntu focal-updates/main i386 libstdc++6 i386 10.3.0-1ubuntu1~20.04 [541 kB]
Get:7 Index of /ubuntu focal-updates/main i386 libdrm2 i386 2.4.107-8ubuntu1~20.04.2 [37,5 kB]
Get:8 Index of /ubuntu focal/main i386 libedit2 i386 3.1-20191231-1 [90,9 kB]
Get:9 Index of /ubuntu focal/main i386 libxau6 i386 1:1.0.9-0ubuntu1 [7.804 B]
Get:10 Index of /ubuntu focal/main i386 libxdmcp6 i386 1:1.1.3-0ubuntu1 [11,0 kB]
Get:11 Index of /ubuntu focal/main i386 libxcb1 i386 1.14-2 [49,2 kB]
Get:12 Index of /ubuntu focal-updates/main i386 libx11-6 i386 2:1.6.9-2ubuntu1.2 [599 kB]
Get:13 Index of /ubuntu focal/main i386 libxext6 i386 2:1.3.4-0ubuntu1 [31,5 kB]
Get:14 Index of /ubuntu focal-updates/main i386 libatomic1 i386 10.3.0-1ubuntu1~20.04 [9.864 B]
Get:15 Index of /ubuntu focal-updates/main i386 libdrm-amdgpu1 i386 2.4.107-8ubuntu1~20.04.2 [21,6 kB]
Get:16 Index of /ubuntu focal/main i386 libpciaccess0 i386 0.16-0ubuntu1 [20,0 kB]
Get:17 Index of /ubuntu focal-updates/main i386 libdrm-intel1 i386 2.4.107-8ubuntu1~20.04.2 [63,2 kB]
Get:18 Index of /ubuntu focal-updates/main i386 libdrm-nouveau2 i386 2.4.107-8ubuntu1~20.04.2 [18,3 kB]
Get:19 Index of /ubuntu focal-updates/main i386 libdrm-radeon1 i386 2.4.107-8ubuntu1~20.04.2 [21,2 kB]
Get:20 Index of /ubuntu focal-updates/main i386 libglapi-mesa i386 21.2.6-0ubuntu0.1~20.04.2 [27,3 kB]
Get:21 Index of /ubuntu focal-updates/main i386 libsensors5 i386 1:3.6.0-2ubuntu1.1 [28,1 kB]
Get:22 Index of /ubuntu focal/main i386 libvulkan1 i386 1.2.131.2-1 [101 kB]
Get:23 Index of /ubuntu focal-updates/main i386 libgl1-mesa-dri i386 21.2.6-0ubuntu0.1~20.04.2 [11,3 MB]
Get:24 Index of /ubuntu focal-updates/main i386 libx11-xcb1 i386 2:1.6.9-2ubuntu1.2 [9.392 B]
Get:25 Index of /ubuntu focal/main i386 libxcb-dri2-0 i386 1.14-2 [7.268 B]
Get:26 Index of /ubuntu focal/main i386 libxcb-dri3-0 i386 1.14-2 [7.048 B]
Get:27 Index of /ubuntu focal/main i386 libxcb-glx0 i386 1.14-2 [23,8 kB]
Get:28 Index of /ubuntu focal/main i386 libxcb-present0 i386 1.14-2 [5.748 B]
Get:29 Index of /ubuntu focal/main i386 libxcb-sync1 i386 1.14-2 [9.268 B]
Get:30 Index of /ubuntu focal/main i386 libxfixes3 i386 1:5.0.3-2 [11,5 kB]
Get:31 Index of /ubuntu focal/main i386 libxshmfence1 i386 1.3-1 [5.180 B]
Get:32 Index of /ubuntu focal/main i386 libxxf86vm1 i386 1:1.1.4-1build1 [11,0 kB]
Get:33 Index of /ubuntu focal-updates/main i386 libglx-mesa0 i386 21.2.6-0ubuntu0.1~20.04.2 [145 kB]
Get:34 Index of /ubuntu focal-updates/main i386 libglvnd0 i386 1.3.2-1~ubuntu0.20.04.2 [40,8 kB]
Get:35 Index of /ubuntu focal-updates/main i386 libglx0 i386 1.3.2-1~ubuntu0.20.04.2 [37,4 kB]
Get:36 Index of /ubuntu focal-updates/main i386 libgl1 i386 1.3.2-1~ubuntu0.20.04.2 [80,4 kB]
Get:37 Index of /ubuntu focal/main i386 libxcb-randr0 i386 1.14-2 [18,0 kB]
Get:38 Index of /ubuntu focal-updates/main amd64 libxnvctrl0 amd64 470.57.01-0ubuntu0.20.04.3 [10,9 kB]
Get:39 Index of /ubuntu focal-updates/main i386 mesa-vulkan-drivers i386 21.2.6-0ubuntu0.1~20.04.2 [5.911 kB]
Get:40 Index of /ubuntu focal-updates/restricted amd64 nvidia-kernel-source-525 amd64 525.85.05-0ubuntu0.20.04.1 [43,9 MB]
Get:41 Index of /ubuntu focal-updates/restricted amd64 nvidia-dkms-525 amd64 525.85.05-0ubuntu0.20.04.1 [29,2 kB]
Get:42 Index of /ubuntu focal-updates/restricted amd64 nvidia-driver-525 amd64 525.85.05-0ubuntu0.20.04.1 [466 kB]
Get:43 Index of /ubuntu focal-updates/restricted amd64 nvidia-driver-520 amd64 525.85.05-0ubuntu0.20.04.1 [6.772 B]
Get:44 Index of /ubuntu focal/main amd64 screen-resolution-extra all 0.18build1 [4.456 B]
Get:45 Index of /ubuntu focal-updates/main amd64 nvidia-settings amd64 470.57.01-0ubuntu0.20.04.3 [886 kB]
Fetched 64,9 MB in 19s (3.467 kB/s)
Extracting templates from packages: 100%
Selecting previously unselected package dctrl-tools.
(Reading database … 167296 files and directories currently installed.)
Preparing to unpack …/00-dctrl-tools_2.24-3_amd64.deb …
Unpacking dctrl-tools (2.24-3) …
Selecting previously unselected package dkms.
Preparing to unpack …/01-dkms_2.8.1-5ubuntu2_all.deb …
Unpacking dkms (2.8.1-5ubuntu2) …
Selecting previously unselected package libbsd0:i386.
Preparing to unpack …/02-libbsd0_0.10.0-1_i386.deb …
Unpacking libbsd0:i386 (0.10.0-1) …
Selecting previously unselected package libelf1:i386.
Preparing to unpack …/03-libelf1_0.176-1.1build1_i386.deb …
Unpacking libelf1:i386 (0.176-1.1build1) …
Selecting previously unselected package libexpat1:i386.
Preparing to unpack …/04-libexpat1_2.2.9-1ubuntu0.6_i386.deb …
Unpacking libexpat1:i386 (2.2.9-1ubuntu0.6) …
Selecting previously unselected package libffi7:i386.
Preparing to unpack …/05-libffi7_3.3-4_i386.deb …
Unpacking libffi7:i386 (3.3-4) …
Selecting previously unselected package libstdc++6:i386.
Preparing to unpack …/06-libstdc++6_10.3.0-1ubuntu1~20.04_i386.deb …
Unpacking libstdc++6:i386 (10.3.0-1ubuntu1~20.04) …
Selecting previously unselected package libdrm2:i386.
Preparing to unpack …/07-libdrm2_2.4.107-8ubuntu1~20.04.2_i386.deb …
Unpacking libdrm2:i386 (2.4.107-8ubuntu1~20.04.2) …
Selecting previously unselected package libedit2:i386.
Preparing to unpack …/08-libedit2_3.1-20191231-1_i386.deb …
Unpacking libedit2:i386 (3.1-20191231-1) …
Selecting previously unselected package libxau6:i386.
Preparing to unpack …/09-libxau6_1%3a1.0.9-0ubuntu1_i386.deb …
Unpacking libxau6:i386 (1:1.0.9-0ubuntu1) …
Selecting previously unselected package libxdmcp6:i386.
Preparing to unpack …/10-libxdmcp6_1%3a1.1.3-0ubuntu1_i386.deb …
Unpacking libxdmcp6:i386 (1:1.1.3-0ubuntu1) …
Selecting previously unselected package libxcb1:i386.
Preparing to unpack …/11-libxcb1_1.14-2_i386.deb …
Unpacking libxcb1:i386 (1.14-2) …
Selecting previously unselected package libx11-6:i386.
Preparing to unpack …/12-libx11-6_2%3a1.6.9-2ubuntu1.2_i386.deb …
Unpacking libx11-6:i386 (2:1.6.9-2ubuntu1.2) …
Selecting previously unselected package libxext6:i386.
Preparing to unpack …/13-libxext6_2%3a1.3.4-0ubuntu1_i386.deb …
Unpacking libxext6:i386 (2:1.3.4-0ubuntu1) …
Selecting previously unselected package libatomic1:i386.
Preparing to unpack …/14-libatomic1_10.3.0-1ubuntu1~20.04_i386.deb …
Unpacking libatomic1:i386 (10.3.0-1ubuntu1~20.04) …
Selecting previously unselected package libdrm-amdgpu1:i386.
Preparing to unpack …/15-libdrm-amdgpu1_2.4.107-8ubuntu1~20.04.2_i386.deb …
Unpacking libdrm-amdgpu1:i386 (2.4.107-8ubuntu1~20.04.2) …
Selecting previously unselected package libpciaccess0:i386.
Preparing to unpack …/16-libpciaccess0_0.16-0ubuntu1_i386.deb …
Unpacking libpciaccess0:i386 (0.16-0ubuntu1) …
Selecting previously unselected package libdrm-intel1:i386.
Preparing to unpack …/17-libdrm-intel1_2.4.107-8ubuntu1~20.04.2_i386.deb …
Unpacking libdrm-intel1:i386 (2.4.107-8ubuntu1~20.04.2) …
Selecting previously unselected package libdrm-nouveau2:i386.
Preparing to unpack …/18-libdrm-nouveau2_2.4.107-8ubuntu1~20.04.2_i386.deb …
Unpacking libdrm-nouveau2:i386 (2.4.107-8ubuntu1~20.04.2) …
Selecting previously unselected package libdrm-radeon1:i386.
Preparing to unpack …/19-libdrm-radeon1_2.4.107-8ubuntu1~20.04.2_i386.deb …
Unpacking libdrm-radeon1:i386 (2.4.107-8ubuntu1~20.04.2) …
Selecting previously unselected package libglapi-mesa:i386.
Preparing to unpack …/20-libglapi-mesa_21.2.6-0ubuntu0.1~20.04.2_i386.deb …
Unpacking libglapi-mesa:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Selecting previously unselected package libllvm12:i386.
Preparing to unpack …/21-libllvm12_1%3a12.0.0-3ubuntu1~20.04.5_i386.deb …
Unpacking libllvm12:i386 (1:12.0.0-3ubuntu1~20.04.5) …
Selecting previously unselected package libsensors5:i386.
Preparing to unpack …/22-libsensors5_1%3a3.6.0-2ubuntu1.1_i386.deb …
Unpacking libsensors5:i386 (1:3.6.0-2ubuntu1.1) …
Selecting previously unselected package libvulkan1:i386.
Preparing to unpack …/23-libvulkan1_1.2.131.2-1_i386.deb …
Unpacking libvulkan1:i386 (1.2.131.2-1) …
Selecting previously unselected package libgl1-mesa-dri:i386.
Preparing to unpack …/24-libgl1-mesa-dri_21.2.6-0ubuntu0.1~20.04.2_i386.deb …
Unpacking libgl1-mesa-dri:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Selecting previously unselected package libx11-xcb1:i386.
Preparing to unpack …/25-libx11-xcb1_2%3a1.6.9-2ubuntu1.2_i386.deb …
Unpacking libx11-xcb1:i386 (2:1.6.9-2ubuntu1.2) …
Selecting previously unselected package libxcb-dri2-0:i386.
Preparing to unpack …/26-libxcb-dri2-0_1.14-2_i386.deb …
Unpacking libxcb-dri2-0:i386 (1.14-2) …
Selecting previously unselected package libxcb-dri3-0:i386.
Preparing to unpack …/27-libxcb-dri3-0_1.14-2_i386.deb …
Unpacking libxcb-dri3-0:i386 (1.14-2) …
Selecting previously unselected package libxcb-glx0:i386.
Preparing to unpack …/28-libxcb-glx0_1.14-2_i386.deb …
Unpacking libxcb-glx0:i386 (1.14-2) …
Selecting previously unselected package libxcb-present0:i386.
Preparing to unpack …/29-libxcb-present0_1.14-2_i386.deb …
Unpacking libxcb-present0:i386 (1.14-2) …
Selecting previously unselected package libxcb-shm0:i386.
Preparing to unpack …/30-libxcb-shm0_1.14-2_i386.deb …
Unpacking libxcb-shm0:i386 (1.14-2) …
Selecting previously unselected package libxcb-sync1:i386.
Preparing to unpack …/31-libxcb-sync1_1.14-2_i386.deb …
Unpacking libxcb-sync1:i386 (1.14-2) …
Selecting previously unselected package libxcb-xfixes0:i386.
Preparing to unpack …/32-libxcb-xfixes0_1.14-2_i386.deb …
Unpacking libxcb-xfixes0:i386 (1.14-2) …
Selecting previously unselected package libxfixes3:i386.
Preparing to unpack …/33-libxfixes3_1%3a5.0.3-2_i386.deb …
Unpacking libxfixes3:i386 (1:5.0.3-2) …
Selecting previously unselected package libxshmfence1:i386.
Preparing to unpack …/34-libxshmfence1_1.3-1_i386.deb …
Unpacking libxshmfence1:i386 (1.3-1) …
Selecting previously unselected package libxxf86vm1:i386.
Preparing to unpack …/35-libxxf86vm1_1%3a1.1.4-1build1_i386.deb …
Unpacking libxxf86vm1:i386 (1:1.1.4-1build1) …
Selecting previously unselected package libglx-mesa0:i386.
Preparing to unpack …/36-libglx-mesa0_21.2.6-0ubuntu0.1~20.04.2_i386.deb …
Unpacking libglx-mesa0:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Selecting previously unselected package libnvidia-cfg1-525:amd64.
Preparing to unpack …/37-libnvidia-cfg1-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking libnvidia-cfg1-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-common-525.
Preparing to unpack …/38-libnvidia-common-525_525.85.05-0ubuntu0.20.04.1_all.deb …
Unpacking libnvidia-common-525 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-compute-525:i386.
Preparing to unpack …/39-libnvidia-compute-525_525.85.05-0ubuntu0.20.04.1_i386.deb …
Unpacking libnvidia-compute-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-decode-525:i386.
Preparing to unpack …/40-libnvidia-decode-525_525.85.05-0ubuntu0.20.04.1_i386.deb …
Unpacking libnvidia-decode-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-decode-525:amd64.
Preparing to unpack …/41-libnvidia-decode-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking libnvidia-decode-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-encode-525:i386.
Preparing to unpack …/42-libnvidia-encode-525_525.85.05-0ubuntu0.20.04.1_i386.deb …
Unpacking libnvidia-encode-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-encode-525:amd64.
Preparing to unpack …/43-libnvidia-encode-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking libnvidia-encode-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-extra-525:amd64.
Preparing to unpack …/44-libnvidia-extra-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking libnvidia-extra-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libglvnd0:i386.
Preparing to unpack …/45-libglvnd0_1.3.2-1~ubuntu0.20.04.2_i386.deb …
Unpacking libglvnd0:i386 (1.3.2-1~ubuntu0.20.04.2) …
Selecting previously unselected package libglx0:i386.
Preparing to unpack …/46-libglx0_1.3.2-1~ubuntu0.20.04.2_i386.deb …
Unpacking libglx0:i386 (1.3.2-1~ubuntu0.20.04.2) …
Selecting previously unselected package libgl1:i386.
Preparing to unpack …/47-libgl1_1.3.2-1~ubuntu0.20.04.2_i386.deb …
Unpacking libgl1:i386 (1.3.2-1~ubuntu0.20.04.2) …
Selecting previously unselected package libnvidia-fbc1-525:i386.
Preparing to unpack …/48-libnvidia-fbc1-525_525.85.05-0ubuntu0.20.04.1_i386.deb …
Unpacking libnvidia-fbc1-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-fbc1-525:amd64.
Preparing to unpack …/49-libnvidia-fbc1-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking libnvidia-fbc1-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-gl-525:i386.
Preparing to unpack …/50-libnvidia-gl-525_525.85.05-0ubuntu0.20.04.1_i386.deb …
Unpacking libnvidia-gl-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libnvidia-gl-525:amd64.
Preparing to unpack …/51-libnvidia-gl-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking libnvidia-gl-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package libwayland-client0:i386.
Preparing to unpack …/52-libwayland-client0_1.18.0-1ubuntu0.1_i386.deb …
Unpacking libwayland-client0:i386 (1.18.0-1ubuntu0.1) …
Selecting previously unselected package libxcb-randr0:i386.
Preparing to unpack …/53-libxcb-randr0_1.14-2_i386.deb …
Unpacking libxcb-randr0:i386 (1.14-2) …
Selecting previously unselected package libxnvctrl0:amd64.
Preparing to unpack …/54-libxnvctrl0_470.57.01-0ubuntu0.20.04.3_amd64.deb …
Unpacking libxnvctrl0:amd64 (470.57.01-0ubuntu0.20.04.3) …
Selecting previously unselected package mesa-vulkan-drivers:i386.
Preparing to unpack …/55-mesa-vulkan-drivers_21.2.6-0ubuntu0.1~20.04.2_i386.deb …
Unpacking mesa-vulkan-drivers:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Selecting previously unselected package nvidia-compute-utils-525.
Preparing to unpack …/56-nvidia-compute-utils-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking nvidia-compute-utils-525 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package nvidia-kernel-source-525.
Preparing to unpack …/57-nvidia-kernel-source-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking nvidia-kernel-source-525 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package nvidia-dkms-525.
Preparing to unpack …/58-nvidia-dkms-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking nvidia-dkms-525 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package nvidia-utils-525.
Preparing to unpack …/59-nvidia-utils-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking nvidia-utils-525 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package xserver-xorg-video-nvidia-525.
Preparing to unpack …/60-xserver-xorg-video-nvidia-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking xserver-xorg-video-nvidia-525 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package nvidia-driver-525.
Preparing to unpack …/61-nvidia-driver-525_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking nvidia-driver-525 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package nvidia-driver-520.
Preparing to unpack …/62-nvidia-driver-520_525.85.05-0ubuntu0.20.04.1_amd64.deb …
Unpacking nvidia-driver-520 (525.85.05-0ubuntu0.20.04.1) …
Selecting previously unselected package screen-resolution-extra.
Preparing to unpack …/63-screen-resolution-extra_0.18build1_all.deb …
Unpacking screen-resolution-extra (0.18build1) …
Selecting previously unselected package nvidia-settings.
Preparing to unpack …/64-nvidia-settings_470.57.01-0ubuntu0.20.04.3_amd64.deb …
Unpacking nvidia-settings (470.57.01-0ubuntu0.20.04.3) …
Setting up libexpat1:i386 (2.2.9-1ubuntu0.6) …
Setting up nvidia-utils-525 (525.85.05-0ubuntu0.20.04.1) …
Setting up libx11-xcb1:i386 (2:1.6.9-2ubuntu1.2) …
Setting up libpciaccess0:i386 (0.16-0ubuntu1) …
Setting up libxau6:i386 (1:1.0.9-0ubuntu1) …
Setting up libnvidia-fbc1-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Setting up nvidia-compute-utils-525 (525.85.05-0ubuntu0.20.04.1) …
Warning: The home dir /nonexistent you specified can’t be accessed: No such file or directory
Adding system user nvidia-persistenced' (UID 127) ... Adding new group nvidia-persistenced’ (GID 134) …
Adding new user nvidia-persistenced' (UID 127) with group nvidia-persistenced’ …
Not creating home directory `/nonexistent’.
Setting up libnvidia-extra-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Setting up libglvnd0:i386 (1.3.2-1~ubuntu0.20.04.2) …
Setting up libffi7:i386 (3.3-4) …
Setting up libxnvctrl0:amd64 (470.57.01-0ubuntu0.20.04.3) …
Setting up libatomic1:i386 (10.3.0-1ubuntu1~20.04) …
Setting up libsensors5:i386 (1:3.6.0-2ubuntu1.1) …
Setting up libnvidia-cfg1-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Setting up libglapi-mesa:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Setting up libvulkan1:i386 (1.2.131.2-1) …
Setting up screen-resolution-extra (0.18build1) …
Setting up libdrm2:i386 (2.4.107-8ubuntu1~20.04.2) …
Setting up libxshmfence1:i386 (1.3-1) …
Setting up nvidia-kernel-source-525 (525.85.05-0ubuntu0.20.04.1) …
Setting up libnvidia-common-525 (525.85.05-0ubuntu0.20.04.1) …
Setting up nvidia-settings (470.57.01-0ubuntu0.20.04.3) …
Setting up libnvidia-compute-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Setting up libnvidia-decode-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Setting up libbsd0:i386 (0.10.0-1) …
Setting up libelf1:i386 (0.176-1.1build1) …
Setting up libstdc++6:i386 (10.3.0-1ubuntu1~20.04) …
Setting up dctrl-tools (2.24-3) …
Setting up libdrm-amdgpu1:i386 (2.4.107-8ubuntu1~20.04.2) …
Setting up libwayland-client0:i386 (1.18.0-1ubuntu0.1) …
Setting up xserver-xorg-video-nvidia-525 (525.85.05-0ubuntu0.20.04.1) …
Setting up libxdmcp6:i386 (1:1.1.3-0ubuntu1) …
Setting up libdrm-nouveau2:i386 (2.4.107-8ubuntu1~20.04.2) …
Setting up libxcb1:i386 (1.14-2) …
Setting up libxcb-xfixes0:i386 (1.14-2) …
Setting up libdrm-radeon1:i386 (2.4.107-8ubuntu1~20.04.2) …
Setting up libxcb-glx0:i386 (1.14-2) …
Setting up libedit2:i386 (3.1-20191231-1) …
Setting up libdrm-intel1:i386 (2.4.107-8ubuntu1~20.04.2) …
Setting up libnvidia-gl-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Setting up libxcb-shm0:i386 (1.14-2) …
Setting up dkms (2.8.1-5ubuntu2) …
Setting up libxcb-present0:i386 (1.14-2) …
Setting up libxcb-sync1:i386 (1.14-2) …
Setting up libllvm12:i386 (1:12.0.0-3ubuntu1~20.04.5) …
Setting up libxcb-dri2-0:i386 (1.14-2) …
Setting up libxcb-randr0:i386 (1.14-2) …
Setting up nvidia-dkms-525 (525.85.05-0ubuntu0.20.04.1) …
INFO:Enable nvidia
Loading new nvidia-525.85.05 DKMS files…
Building for 5.15.0-67-generic
Building for architecture x86_64
Building initial module for 5.15.0-67-generic
Secure Boot not enabled on this system.
Done.
nvidia.ko:
Running module version sanity check.
Error! Module version 525.85.05 for nvidia.ko
is not newer than what is already found in kernel 5.15.0-67-generic (525.85.05).
You may override by specifying --force.
nvidia-modeset.ko:
Error! Module version 525.85.05 for nvidia-modeset.ko
nvidia-drm.ko:
Error! Module version 525.85.05 for nvidia-drm.ko
nvidia-uvm.ko:
Error! Module version 525.85.05 for nvidia-uvm.ko
nvidia-peermem.ko:
Good news! Module version 525.85.05 for nvidia-peermem.ko
exactly matches what is already found in kernel 5.15.0-67-generic.
DKMS will not replace this module.
depmod…
DKMS: install completed.
Setting up libnvidia-encode-525:amd64 (525.85.05-0ubuntu0.20.04.1) …
Setting up libx11-6:i386 (2:1.6.9-2ubuntu1.2) …
Setting up libxcb-dri3-0:i386 (1.14-2) …
Setting up mesa-vulkan-drivers:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Setting up libgl1-mesa-dri:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Setting up libxext6:i386 (2:1.3.4-0ubuntu1) …
Setting up libxxf86vm1:i386 (1:1.1.4-1build1) …
Setting up libxfixes3:i386 (1:5.0.3-2) …
Setting up nvidia-driver-525 (525.85.05-0ubuntu0.20.04.1) …
Setting up libnvidia-decode-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Setting up nvidia-driver-520 (525.85.05-0ubuntu0.20.04.1) …
Setting up libglx-mesa0:i386 (21.2.6-0ubuntu0.1~20.04.2) …
Setting up libglx0:i386 (1.3.2-1~ubuntu0.20.04.2) …
Setting up libnvidia-gl-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Setting up libgl1:i386 (1.3.2-1~ubuntu0.20.04.2) …
Setting up libnvidia-encode-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Setting up libnvidia-fbc1-525:i386 (525.85.05-0ubuntu0.20.04.1) …
Thanks for the info. Then, please reboot the machine and install 520.
$ sudo reboot
$ nvidia-smi
I rebooted,
Command ‘nvidia-smi’ not found, but can be installed with:
sudo apt install nvidia-utils-435 # version 435.21-0ubuntu7, or
sudo apt install nvidia-utils-440 # version 440.82+really.440.64-0ubuntu6
sudo apt install nvidia-340 # version 340.108-0ubuntu5.20.04.2
sudo apt install nvidia-utils-390 # version 390.157-0ubuntu0.20.04.1
sudo apt install nvidia-utils-450-server # version 450.216.04-0ubuntu0.20.04.1
sudo apt install nvidia-utils-470 # version 470.161.03-0ubuntu0.20.04.1
sudo apt install nvidia-utils-470-server # version 470.161.03-0ubuntu0.20.04.1
sudo apt install nvidia-utils-510 # version 510.108.03-0ubuntu0.20.04.1
sudo apt install nvidia-utils-515 # version 515.86.01-0ubuntu0.20.04.1
sudo apt install nvidia-utils-515-server # version 515.86.01-0ubuntu0.20.04.3
sudo apt install nvidia-utils-525 # version 525.85.05-0ubuntu0.20.04.1
sudo apt install nvidia-utils-525-server # version 525.85.12-0ubuntu0.20.04.1
sudo apt install nvidia-utils-418-server # version 418.226.00-0ubuntu0.20.04.2
there isn’t 520,
Suggested packages:
Fetched 64,9 MB in 12s (5.236 kB/s)
(Reading database … 167332 files and directories currently installed.)
INFO:Enable nvidia
Done.
nvidia.ko:
nvidia-modeset.ko:
nvidia-drm.ko:
nvidia-uvm.ko:
nvidia-peermem.ko:
depmod…
ID 988 398 705 of anydesk
Please run
$docker run hello-world
guille@usuario-pc:~$ docker run hello-world
Unable to find image ‘hello-world:latest’ locally
latest: Pulling from library/hello-world
2db29710123e: Pull complete
Digest: sha256:6e8b6f026e0b9c419ea0fd02d3905dd0952ad1feea67543f525c73a0a790fefb
Status: Downloaded newer image for hello-world:latest
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
  1. The Docker client contacted the Docker daemon.
  2. The Docker daemon pulled the “hello-world” image from the Docker Hub.
    (amd64)
  3. The Docker daemon created a new container from that image which runs the
    executable that produces the output you are currently reading.
  4. The Docker daemon streamed that output to the Docker client, which sent it
    to your terminal.
To try something more ambitious, you can run an Ubuntu container with:
$ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
https://hub.docker.com/
For more examples and ideas, visit:
Overview
guille@usuario-pc:~$ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
nvcr.io/nvidia/tao/tao-toolkit 4.0.0-tf1.15.5 0135932e9c50 2 months ago 13.3GB
hello-world latest feb5d9fea6a5 17 months ago 13.3kB
