I am trying to compile a finite element library (DEAL.II) using pgcc/pgCC version 6.2 on 64bit linux.
But it seems that there are many compiling warnings and link warnings when I compile the shared library file. When I compile the example files in this library I got the following errors:
pgCC-Warning-Unknown switch: -rdynamic
/scratch/xub/dealii/lib/libdeal_II_2d.g.so: undefined reference to `__builtin_expect’
After that, I add a compiler option -shared , this time I can compile the example file, but I got a run-time error:
[xub@matrix step-1]$ ./step-1
Segmentation fault
However, I can compile this library sucessfully with gcc/g++ compiler.
Could anyone help me ??
The deal.ii library can be downloaded from : http://www.dealii.org/
__builtin_expect is a GCC extension to tell the compiler what you expect a branch result to be. I have had this problem when using pthreads.h. It looks like there are only a couple source files that have it, so you can use something like the following
You may also write the maintainer of that source code and suggest he change the test for __builtin_expect to AC_TRY_LINK instead of AC_TRY_COMPILE. PGI C++ compiler will compile the code, but linking fails.
Another work-around is to comment out line 203 of “base/include/base/config.h”
/*#define HAVE_BUILTIN_EXPECT 1*/
I was able to build and run the examples when I made this change. A few of the examples didn’t run becasuse I didn’t build PetSC. Also, step-4 aborts with a runtime error which I’ll need to investigate further.
I commentd the followings:
/#define HAVE_BUILTIN_EXPECT 1/
It works except for step-4…:)
Now, I will trying to link it with petsc using pgcc/pgCC to see what happens…
By the way, did you notice the link warnings:
I still got the compile warning when bulid deal.II by pgCC/pgcc:
Do you know how to correct it??
type qualifier on return type is meaningless
operator const Mat () const;
“/scratch/xub/dealii/lac/include/lac/petsc_precondition.h”, line 74: warning #815-D:
=====lac==============debug========== petsc_sparse_matrix.cc
“/scratch/xub/dealii/lac/include/lac/petsc_matrix_base.h”, line 766: warning #815-D:
The warning is correct, but can be safely ignored. Type qualifiers, such as const, have no meaning and thus ignored when applied to function return types.
When I link dealii with petsc, which is also compiled with pgcc/pgf90, the compilation is successful. But when I run example files, I got runtime errors: ./step-1
C++ runtime abort: internal error: static object marked for destruction more than once
Aborted
Originally, if I did not link dealii with petsc, I can run ./step-1.
By the way, there are three library on my system I will use:
HP-MPI (set up by PGI compilers)
Petsc (compiled by mpicc/mpiCC/mpif90)
Deal.II (I want to compile with mpicc/mpiCC/mpif90, but still have problems!!)
