I’m experiencing problems when trying to record a 10s capture from nvarguscamerasrc into a bgr file. I’m using the devkit and its standard OV5693 based onboard camera module.
I first made sure I had enough disk space and boosted my tx2 (R28.2.1):
df -H .
Filesystem Size Used Avail Use% Mounted on
/dev/root 64G 6.4G 54G 11% /
sudo nvpmodel -m0
sudo /home/nvidia/jetson_clocks.sh
While with videotestsrc everything works fine with num-buffers option:
for curLoop in `seq 1 20`; do gst-launch-1.0 videotestsrc num-buffers=300 ! 'video/x-raw, width=1920, height=1080, format=BGR, framerate=30/1' ! queue ! filesink location=video.bgr | grep -A10 "(Argus)"; ls -l video.bgr; done
-rw-rw-r-- 1 nvidia nvidia 1866240000 Feb 16 12:40 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1866240000 Feb 16 12:41 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1866240000 Feb 16 12:42 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1866240000 Feb 16 12:43 video.bgr
With nvarguscamerasrc, with num-buffers option the size is ok but sometimes is stalls.
I use one extra terminal monitoring the file size with:
watch -n1 ls -l video.bgr
and another extra one for kernel messages:
dmesg --follow
Now, running the capture succeeded 5 times, but got stuck in 6th loop, so I issued a Ctrl-C in the terminal, that produced a translation fault in argus_deamon:
for curLoop in `seq 1 20`; do gst-launch-1.0 -e nvarguscamerasrc num-buffers=300 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1' ! nvvidconv ! 'video/x-raw, format=BGRx' ! videoconvert ! 'video/x-raw, format=BGR' ! queue ! filesink location=video.bgr | grep -A10 "Argus"; ls -l video.bgr; done
-rw-rw-r-- 1 nvidia nvidia 1866240000 Feb 16 13:14 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1866240000 Feb 16 13:15 video.bgr
^C-rw-rw-r-- 1 nvidia nvidia 1181952000 Feb 16 13:15 video.bgr
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 214)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 289)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 306)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 317)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 149)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 101)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 101)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:358 Failed to create CameraProvider
^C-rw-rw-r-- 1 nvidia nvidia 0 Feb 16 13:16 video.bgr
^C-rw-rw-r-- 1 nvidia nvidia 1860019200 Feb 16 13:16 video.bgr
^C^C
Note the 7th loop produced a smaller file.
Fault details:
[45646.868814] argus_daemon[19969]: unhandled level 2 translation fault (11) at 0x00000060, esr 0x92000006
[45646.878277] pgd = ffffffc18119f000
[45646.881705] [00000060] *pgd=0000000242a12003, *pud=0000000242a12003, *pmd=0000000000000000
[45646.891569] CPU: 3 PID: 19969 Comm: argus_daemon Tainted: G O 4.4.38-tegra #1
[45646.899847] Hardware name: quill (DT)
[45646.903526] task: ffffffc1ea90f080 ti: ffffffc117ab0000 task.ti: ffffffc117ab0000
[45646.911073] PC is at 0x7f7d0133c0
[45646.914408] LR is at 0x7f7d0133b8
[45646.917734] pc : [<0000007f7d0133c0>] lr : [<0000007f7d0133b8>] pstate: 80000000
[45646.925175] sp : 0000007f4a7fe450
[45646.928500] x29: 0000007f4a7fe9d0 x28: 0000007f4a7ff1e0
[45646.933876] x27: 0000007f8ee87f48 x26: 000000000043b560
[45646.939302] x25: 0000007f4a7fe938 x24: 0000000000000065
[45646.944660] x23: 0000007f8dfde000 x22: 0000000000000000
[45646.950031] x21: 0000000000000001 x20: 0000007f18d49a60
[45646.955378] x19: 0000000000000001 x18: 0000000000000a03
[45646.960722] x17: 0000007f8e9b92c0 x16: 0000007f7d982ef8
[45646.966086] x15: 0000007f8ef27000 x14: 0000007f8e5a79f8
[45646.971433] x13: 0000007f8e5a798c x12: 0000007f8e5a793c
[45646.976785] x11: 0000007f8e5a78e0 x10: 0000007f8e5a7874
[45646.982148] x9 : 0000007f8e5a781c x8 : 0000000000000018
[45646.987500] x7 : 0000000000004e01 x6 : 0000000000000000
[45646.992844] x5 : 0000007f8c242d10 x4 : 0000007f7da61bd8
[45646.998203] x3 : 0000000000000000 x2 : 0000000000000018
[45647.003551] x1 : 000000000000001b x0 : 0000000000000000
[45647.010441] Library at 0x7f7d0133c0: 0x7f7c0d0000 /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.28.2.1
[45647.020457] Library at 0x7f7d0133b8: 0x7f7c0d0000 /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.28.2.1
[45647.030491] vdso base = 0x7f8ef26000
Then I’ve tried to use nvarguscamerasrc option timeout. It doesn’t stuck, but produces very random sizes:
for curLoop in `seq 1 20`; do gst-launch-1.0 -e nvarguscamerasrc timeout=10 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1' ! nvvidconv ! 'video/x-raw, format=BGRx' ! videoconvert ! 'video/x-raw, format=BGR' ! queue ! filesink location=video.bgr | grep -A10 "Argus"; ls -l video.bgr; done
-rw-rw-r-- 1 nvidia nvidia 1841356800 Feb 16 13:17 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1144627200 Feb 16 13:17 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1847577600 Feb 16 13:18 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1841356800 Feb 16 13:18 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1841356800 Feb 16 13:19 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1847577600 Feb 16 13:19 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1013990400 Feb 16 13:19 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1847577600 Feb 16 13:20 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1841356800 Feb 16 13:20 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1007769600 Feb 16 13:20 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1847577600 Feb 16 13:21 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1026432000 Feb 16 13:21 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1841356800 Feb 16 13:21 video.bgr
-rw-rw-r-- 1 nvidia nvidia 1007769600 Feb 16 13:22 video.bgr
Am I missing something ?
