problems reported with __ffs()?
I’m working on a CUDA kernel that could really use the __ffs() intrinsic, but I don’t get correct operation. I’d like to do
shift = __ffs(v[0]) - 1;
			if (shift > 31)
				shift = 31;
but instead have to replace with
j = v[0];
			shift = 0;
			if (j == 0) {
				shift = 31;
			else {
				while ((j & 1) == 0) {
					shift++;
					j >>= 1;
Are these two snippets supposed to have the same semantics? shift is unsigned, so the intent is to have a shift amount that tops out at 31. The first snippet does work on a CPU when using linux’s ffs() library function.
Any help appreciated,
jasonp
			if (shift > 31)
				shift = 31;
j = v[0];
			shift = 0;
			if (j == 0) {
				shift = 31;
			else {
					shift++;
					j >>= 1;
jasonp
Is “shift” of type “int” by any chance? If so, if v[0] is 0, then ffs(v[0]) and thus shift is -1 with the first snippet, but 31 with the second snippet.
‘shift’ is an unsigned int so that -1 should become 2^32 - 1. Anyway, v[0] is almost never expected to be exactly zero in this application.
If “shift” is an “unsigned int” I see no reason the code should not work. There are no known issues with __ffs(). If you could post a short, self-contained example application that reproduces the issue you observed, and I would be happy to follow up. Please mention the expected output as well as what you actually observe on the GPU. Thanks!
Does
			if (v[0] == 0)
				shift = 31;
work?
Does
			if (v[0] == 0)
				shift = 31;
work?
