Problems running deepstream application at boot
• Hardware Platform (Jetson / GPU): Jetson Nano
• DeepStream Version: 5.0
• JetPack Version (valid for Jetson only): 4.4 [L4T 32.4.3]
Hello everyone, I am writing because I have the following query. What is the proper way to run a deepstream application at boot time?
The application I want to run is on a remote device (Jetson Nano), which reads two sources (RTSP streams) of video, and then performs the sequence pgie-> tracker-> analytics. Finally it publishes the results of “LineCrossing” of the analytics plugin, in an AWS IoT Core (MQTT) topic. In parallel to the publication of messages, in a second sink, a streaming (RTSP) of the processed video is performed.
The results obtained are the following:
  • If I manually run the application: It runs correctly, publishing messages at intervals of 10 seconds (every 250 frames).
  • If I manually run the service (sudo systemctl start deepstream.service): The service runs, however from what I can see, the frequency of sending published messages is not the desired one (app every 16 seconds). I have also been able to observe some messages published twice.
  • When the service tries to start after booting, it generates a series of errors that can be seen below.
I have seen that when I run the application and the input source is a video file (not RTSP source), apparently the service manages to start correctly after booting. The configured service file is as follows:
[Unit]
Description=Deepstream Service
After=network.target
[Service]
Type=simple
ExecStart=<Path to Application + Args>
User=nano
WorkingDirectory=<Path to Application>
Restart=on-failure
StandardOutput=syslog
StandardError=syslog
[Install]
WantedBy=multi-user.target
Has anyone had similar problems or have any idea that it may be generating errors?
I haven’t seen your exact errors but I don’t believe you have a guaranteed internet connection with this After=network.target.
What I do is use a python wrapper program for my deepstream app. The python wrapper program is configured as a systemd service.
In the python wrapper program it polls for a real internet connection (there are many ways but here’s an example: networking - How can I see if there's an available and active network connection in Python? - Stack Overflow).
Only after we have internet do I start communicating with AWS IoT and start my deepstream app (see the subprocess module).
Thank you very much for your answer @jasonpgf2a, the approach you mention is interesting and should work. I read that one of the “official” deploy mechanisms is through docker, but I haven’t been able to do it yet.
See 3.1 APPLICATIONS MAY BE DEPLOYED IN A DOCKER CONTAINER
Yes thats correct you can use docker but you will still have the issue of starting your service at boot of course. ;-)
Thank you very much, it worked. Being 22:45 in Chile, I can go to sleep peacefully.
