During the “make” step in the instructions ( GitHub - dusty-nv/jetson-reinforcement: Deep reinforcement learning GPU libraries for NVIDIA Jetson TX1/TX2 with PyTorch, OpenAI Gym, and Gazebo robotics simulator.)
I get this error:
ubuntu@jetson-0420219087068:~/RoboND-DeepRL-Project/build$ make
[ 38%] Built target jetson-utils
[ 40%] Building CXX object CMakeFiles/jetson-reinforcement.dir/c/rlAgent.cpp.o
In file included from /home/ubuntu/RoboND-DeepRL-Project/c/rlAgent.cpp:6:0:
/home/ubuntu/RoboND-DeepRL-Project/c/pyTorch.h:14:19: fatal error: TH/TH.h: No such file or directory
compilation terminated.
CMakeFiles/jetson-reinforcement.dir/build.make:227: recipe for target ‘CMakeFiles/jetson-reinforcement.dir/c/rlAgent.cpp.o’ failed
make[2]: *** [CMakeFiles/jetson-reinforcement.dir/c/rlAgent.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/jetson-reinforcement.dir/all’ failed
make[1]: *** [CMakeFiles/jetson-reinforcement.dir/all] Error 2
Makefile:83: recipe for target ‘all’ failed
make: *** [all] Error 2
It seems that there is a problem with pytorch? Can i just add the missing file TH/TH.h somewhere? Or should I re-install pytorch manually?
Suppose you should get the header file installed when running cmake …/.
Do you meet any error when running the cmake command?
Or could you manually run the CMakePreBuild.sh again?
[url]https://github.com/dusty-nv/jetson-reinforcement/blob/master/CMakePreBuild.sh[/url]
Hi camransyed, note that this project should be running JetPack 3.3 if you are not using that.
Thanks Dusty. I am running Jetpack 3.3.1. It was the option available with the sdkManager
OK yes, that should be able to work. So if there isn’t TH/TH.h found, it probably means that PyTorch build didn’t succeed. Can you try manually running these steps from your jetson-reinforcement/build directory? You may want to rm -r -f build and start fresh.
# PyTorch v0.3 install script from CMakePreBuild.sh
sudo apt-get install python-pip
# upgrade pip
pip --version
pip install --upgrade pip==9.0.1
pip --version # pip 9.0.1 from /home/ubuntu/.local/lib/python2.7/site-packages (python 2.7)
# lock OpenAI Gym before version 10 (breaking changes)
sudo pip install gym==0.9.1
# stuff for OpenAI Gym examples
sudo apt-get install python-tk python-gi-cairo
sudo apt-get install libfreetype6-dev # needed by matplotlib
sudo pip install matplotlib
sudo pip install pyglet==1.3.1 # lock pyglet because we need to patch it
sudo sed -i 's/_have_getprocaddress = True/_have_getprocaddress = False/' /usr/local/lib/python2.7/dist-packages/pyglet/gl/lib_glx.py
# setproctitle extension used by A3G
sudo pip install setproctitle
# install numpy
sudo pip install numpy
# see https://github.com/torch/cutorch/issues/797
# use <= v0.2.0
#export TORCH_NVCC_FLAGS="-D__CUDA_NO_HALF_OPERATORS__"
echo $TORCH_NVCC_FLAGS
# clone pyTorch repo
git clone https://github.com/pytorch/pytorch
cd pytorch
git tag
git checkout v0.3.0
git branch
git submodule update --init
# install prereqs
sudo pip install -U setuptools
sudo pip install -r requirements.txt
# Develop Mode:
python setup.py build_deps
sudo python setup.py develop
cd torch
ln -s _C.so lib_C.so
cd lib
ln -s libATen.so.1 libATen.so
cd ../../
git clone https://github.com/pytorch/examples
sudo pip install -r examples/reinforcement_learning/requirements.txt
git clone -b v0.2.0 https://github.com/pytorch/vision
cd vision
sudo python setup.py install
sudo apt-get install swig
sudo pip install box2D
