I have a discussion open on Fedora Discussion.
It appears that installing the NVIDIA driver disables other drivers that are used for things such as the in-built display.
Is it possible to load the NVIDIA driver, in addition to other drivers, such as the one for the in-built display?
The installation log is below:
user1@laptop-3:~$ cat /var/log/akmods/akmods.log
2026/07/15 09:47:34 akmods: Checking kmods exist for 7.1.3-101.fc43.x86_64
2026/07/15 09:47:34 akmods: rpm_query -p --qf %{VERSION}-%{RELEASE} /usr/src/akmods/nvidia-kmod.latest
2026/07/15 09:47:34 akmods: Building and installing nvidia-kmod
2026/07/15 09:47:34 akmods: Building RPM using the command '/usr/sbin/akmodsbuild --kernels 7.1.3-101.fc43.x86_64 /usr/src/akmods/nvidia-kmod.latest'
2026/07/15 09:49:52 akmods: Installing newly built rpms
2026/07/15 09:49:52 akmods: DNF detected
2026/07/15 09:50:00 akmods: Successful.
2026/07/15 09:50:00 akmods: Checking kmods exist for 7.1.3-101.fc43.x86_64
2026/07/15 09:50:00 akmods: rpm_query -f /lib/modules/7.1.3-101.fc43.x86_64/extra/nvidia/
2026/07/15 09:50:00 akmods: rpm_query --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n kmod-nvidia-7.1.3-101.fc43.x86_64-580.173.02-1.fc43.x86_64
2026/07/15 09:50:00 akmods: rpm_query -p --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n /usr/src/akmods/nvidia-kmod.latest
2026/07/15 11:50:44 akmods: Checking kmods exist for 7.1.3-101.fc43.x86_64
2026/07/15 11:50:44 akmods: rpm_query -f /lib/modules/7.1.3-101.fc43.x86_64/extra/nvidia/
2026/07/15 11:50:44 akmods: rpm_query --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n kmod-nvidia-7.1.3-101.fc43.x86_64-580.173.02-1.fc43.x86_64
2026/07/15 11:50:44 akmods: rpm_query -p --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n /usr/src/akmods/nvidia-kmod.latest
2026/07/15 13:37:20 akmods: Checking kmods exist for 6.5.6-300.fc39.x86_64
2026/07/15 13:37:20 akmods: Files needed for building modules against kernel
2026/07/15 13:37:20 akmods: 6.5.6-300.fc39.x86_64 could not be found as the following
2026/07/15 13:37:20 akmods: directories are missing:
2026/07/15 13:37:20 akmods: /usr/src/kernels/6.5.6-300.fc39.x86_64/
2026/07/15 13:37:20 akmods: /lib/modules/6.5.6-300.fc39.x86_64/build/
2026/07/15 13:37:20 akmods: Is the correct kernel-devel package installed?
2026/07/15 14:15:48 akmods: Checking kmods exist for 7.1.3-101.fc43.x86_64
2026/07/15 14:15:48 akmods: rpm_query -f /lib/modules/7.1.3-101.fc43.x86_64/extra/nvidia/
2026/07/15 14:15:48 akmods: rpm_query --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n kmod-nvidia-7.1.3-101.fc43.x86_64-580.173.02-1.fc43.x86_64
2026/07/15 14:15:48 akmods: rpm_query -p --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n /usr/src/akmods/nvidia-kmod.latest
2026/07/15 14:37:28 akmods: Checking kmods exist for 7.1.3-100.fc43.x86_64
2026/07/15 14:37:28 akmods: Files needed for building modules against kernel
2026/07/15 14:37:28 akmods: 7.1.3-100.fc43.x86_64 could not be found as the following
2026/07/15 14:37:28 akmods: directories are missing:
2026/07/15 14:37:28 akmods: /usr/src/kernels/7.1.3-100.fc43.x86_64/
2026/07/15 14:37:28 akmods: /lib/modules/7.1.3-100.fc43.x86_64/build/
2026/07/15 14:37:28 akmods: Is the correct kernel-devel package installed?
2026/07/15 20:05:29 akmods: Checking kmods exist for 7.1.3-101.fc43.x86_64
2026/07/15 20:05:29 akmods: rpm_query -f /lib/modules/7.1.3-101.fc43.x86_64/extra/nvidia/
2026/07/15 20:05:29 akmods: rpm_query --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n kmod-nvidia-7.1.3-101.fc43.x86_64-580.173.02-1.fc43.x86_64
2026/07/15 20:05:29 akmods: rpm_query -p --qf %{EPOCH}:%{VERSION}-%{RELEASE}\n /usr/src/akmods/nvidia-kmod.latest
2026/07/15 20:12:18 akmods: Checking kmods exist for 7.1.3-100.fc43.x86_64
2026/07/15 20:12:18 akmods: Files needed for building modules against kernel
2026/07/15 20:12:18 akmods: 7.1.3-100.fc43.x86_64 could not be found as the following
2026/07/15 20:12:18 akmods: directories are missing:
2026/07/15 20:12:18 akmods: /usr/src/kernels/7.1.3-100.fc43.x86_64/
2026/07/15 20:12:18 akmods: /lib/modules/7.1.3-100.fc43.x86_64/build/
2026/07/15 20:12:18 akmods: Is the correct kernel-devel package installed?
2026/07/24 14:28:45 akmods: Checking kmods exist for 7.1.3-100.fc43.x86_64
2026/07/24 14:28:45 akmods: Files needed for building modules against kernel
2026/07/24 14:28:45 akmods: 7.1.3-100.fc43.x86_64 could not be found as the following
2026/07/24 14:28:45 akmods: directories are missing:
2026/07/24 14:28:45 akmods: /usr/src/kernels/7.1.3-100.fc43.x86_64/
2026/07/24 14:28:45 akmods: /lib/modules/7.1.3-100.fc43.x86_64/build/
2026/07/24 14:28:45 akmods: Is the correct kernel-devel package installed?
2026/07/28 14:01:51 akmods: Checking kmods exist for 7.1.3-100.fc43.x86_64
2026/07/28 14:01:51 akmods: Files needed for building modules against kernel
2026/07/28 14:01:51 akmods: 7.1.3-100.fc43.x86_64 could not be found as the following
2026/07/28 14:01:51 akmods: directories are missing:
2026/07/28 14:01:51 akmods: /usr/src/kernels/7.1.3-100.fc43.x86_64/
2026/07/28 14:01:51 akmods: /lib/modules/7.1.3-100.fc43.x86_64/build/
2026/07/28 14:01:51 akmods: Is the correct kernel-devel package installed?
user1@laptop-3:~$
