I’m trying to use the PWM in AGX xavier, but it didn’t work.
L4T version : 32.4.4
i checked my board’s PWM & pinmux
/sys/kernel/debug# ll /sys/class/pwm/pwmchip*
/sys/class/pwm/pwmchip0 -> ../../devices/3280000.pwm/pwm/pwmchip0/ -> PWM1
/sys/class/pwm/pwmchip1 -> ../../devices/c340000.pwm/pwm/pwmchip1/
/sys/class/pwm/pwmchip2 -> ../../devices/32c0000.pwm/pwm/pwmchip2/ -> PWM5
/sys/class/pwm/pwmchip3 -> ../../devices/32f0000.pwm/pwm/pwmchip3/ -> PWM8
/sys/class/pwm/pwmchip4 -> ../../devices/39c0000.tachometer/pwm/pwmchip4/
/sys/kernel/debug# cat tegra_pinctrl_reg
Bank: 0 Reg: 0x02440020 Val: 0x00000054 -> soc_gpio54_pn1 ->PWM1 #pin15 in 40pin header
Bank: 0 Reg: 0x02434090 Val: 0x00000054 -> soc_gpio12_ph0 ->PWM5 #pin18 in 40pin header
Bank: 0 Reg: 0x02430040 Val: 0x00000056 -> soc_gpio44_pr0 ->PWM8 #pin13 in 40pin header
pins for pwm are set to gpio in default.
i changed pinmux like this
$ vi jetson-xavier.conf
source "${LDK_DIR}/p2972-0000.conf.common";
PINMUX_CONFIG="tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg";
$ vi bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
pinmux.0x02434090 = 0x00000406;
pinmux.0x02440020 = 0x00000404;
pinmux.0x02430040 = 0x00000404;
$ sudo ./flash.sh -k MB1_BCT jetson-xavier mmcblk0p1
after flashing, i checked tegra_pinctrl_reg, those value updated successfully.
and i tried like this.
$ cd /sys/class/pwm/pwmchip0 #PWM8, pin 13
$ echo 0 > export
$ cd pwm0
$ echo 20000 > period
$ echo 10000 > duty_cycle
$ echo 1 > enable
I tried all of 3 pins like that, but there weren’t any output signal at those pins.
Please advise me what is wrong.
and another question:
I’m trying update pinmux setting like that,
but if I update package in unbuntu on Xavier (apt upgrade command)
after that, pinmux roll back to default value.
and after that, pinmux setting can not updated like those way.
(sudo ./flash.sh -k MB1_BCT jetson-xavier mmcblk0p1 command)
if i try flash, it was printed “success” in the shell, but checked xavier’s “tegra_pinctrl_reg” file, it didn’t update.
the only way to update, it needs hole flashing. but, this way make back to default filesystem.
so, if i try to change pinmux, i can’t update ubuntu package on Xavier.
how can i update pinmux after ubuntu package on Xavier updated?
