We are using the SDK of the Jetson TX2. We’ve made some tests with the Omnivision camera that comes with the SDK and with this other camera: LI-JETSON-KIT-IMX274CS.
I’ve been doing some tests with Gstreamer following the “Accelerated GStreamer user guide” revision 28.2. On the “Camera capture with GStreamer-1.0” section I can find three ways to implement a video loopback with GStreamer:
1.- nvgstcapture: the loopback works.
2.- gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,width=640,height=480,format=(string)I420" ! xvimagesink -e: the loopback doesn't work. I've tried with different resolutions and formats which are supposed to be supported on the camera.
3.- gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1' ! nvoverlaysink -e: I don't have the "nvarguscamerasrc" plugin on my system, so the loopback doesn't work. Also tried with different resolutions and formats.
Finally I make it work with the following Gstreamer chain: gst-launch-1.0 nvcamerasrc sensor-id=0 ! video/x-raw(memory:NVMM),width=3840, height=2160, framerate=20/1, format=(string)I420’ ! nvegltransforrm ! nveglglessink -e
Is there any way to make gst-launch-1.0 work with v4l2src?
The nvgstcapture application and nvcamerasrc plugin are binary files and I can’t change anything on them. How can I add a new sensor (one which is not already supported) without losing the ISP support on the Jetson TX2?
