I try to explain that understand
Declare the variable as volatile and initialize
Copy the content of the variable from host to device with cudaMemcpyToSymbolAsync()
But, how use the variable to stop all threads?
This is my Kernel code:
__global__ void brute_force(unsigned char *texto_dev, int lt, unsigned char *clave_dev, unsigned char *descifrado_dev, unsigned char *tid_dev) {
unsigned char alfabeto[56] = {'a','b','c','d','e','f','g','h','i','j','k','l','m','n','o','p','q','r','s','t','u','v','w','x','y','z',
'A','B','C','D','E','F','G','H','I','J','K','L','M','N','O','P','Q','R','S','T','U','V','W','X','Y','Z',' ',',','.','
global void brute_force(unsigned char *texto_dev, int lt, unsigned char *clave_dev, unsigned char *descifrado_dev, unsigned char *tid_dev) {
‘A’,‘B’,‘C’,‘D’,‘E’,‘F’,‘G’,‘H’,‘I’,‘J’,‘K’,‘L’,‘M’,‘N’,‘O’,‘P’,‘Q’,‘R’,‘S’,‘T’,‘U’,‘V’,‘W’,‘X’,‘Y’,‘Z’,’ ‘,’,’,’.’,’\0’};
int y, c1, c2, lc = 5, ii, gen_key = 0, valor;
int id = threadIdx.x;
int N_combinaciones = 10000;
int key_inicial = id * N_combinaciones;
int key_final = key_inicial + N_combinaciones;
/* KEY >> */
for (ii = 0; ii < 5; ii++) {
clave_dev[257 * id + ii] = 'X';
clave_dev[257 * id + 5] = ‘\0’;
/* KEY << */
for (gen_key = key_inicial; gen_key < key_final && !encontrado; gen_key++) {
valor = gen_key;
clave_dev[257 * id + 4 - ii] = '0' + (valor % 10);
valor = valor / 10;
clave_dev[257 * id + lc] = '\0';
rc4_init(id, &clave_dev[257 * id], lc);
for (y = 0; y < lt; y++) {
descifrado_dev[1025 * id + y] = texto_dev[y] ^ rc4_output(id);
for (c1 = 0; c1 < lt; c1++) {
for (c2 = 0; c2 < 56; c2++) {
if (descifrado_dev[1025 * id + c1] == alfabeto[c2]) {
break;
if (c2 == 56) {
break;
if (c1 == (lt-1)) {
tid_dev[0] = (unsigned char) ('0' + id);
encontrado = 1;
break;
//gen_key = 100000;
// tid_dev[0] = (unsigned char) (‘0’ + id);
/* KEY >> */
clave_dev[257 * id + 5] = '
/* KEY >> */
/* KEY << */
valor = gen_key;
valor = valor / 10;
break;
if (c2 == 56) {
break;
if (c1 == (lt-1)) {
encontrado = 1;
break;
//gen_key = 100000;
/* KEY << */
valor = gen_key;
valor = valor / 10;
/* KEY >> */
/* KEY << */
valor = gen_key;
valor = valor / 10;
break;
if (c2 == 56) {
break;
if (c1 == (lt-1)) {
encontrado = 1;
break;
//gen_key = 100000;
break;
if (c2 == 56) {
break;
if (c1 == (lt-1)) {
encontrado = 1;
break;
//gen_key = 100000;
// tid_dev[0] = (unsigned char) ('0' + id);
My variable encontrado (means “found” in english) is that determine if one thread found the key or not, and is my flag to stop the all others threads.
