Problems with build custom driver under Jetson TX2
Hi
I have avc8000nano, Jetson TX2 and L4T 32.2. So, I try to compile driver avc8000nano-118 and next error occured:
WARNING: "videobuf_to_dma" [/home/ubuntu/avc8000nano-118/driver/avc8000.ko] undefined!
WARNING: "videobuf_dma_unmap" [/home/ubuntu/avc8000nano-118/driver/avc8000.ko] undefined!
WARNING: "videobuf_queue_sg_init" [/home/ubuntu/avc8000nano-118/driver/avc8000.ko] undefined!
WARNING: "videobuf_dma_free" [/home/ubuntu/avc8000nano-118/driver/avc8000.ko] undefined!
lspci:
02:00.0 Multimedia controller: Intersil Techwell Device 6869 (rev 01)
I try to compile default tw686x driver, but Jetson hangs after command:
insmod tw686x.ko
dmesg:
[   47.543693] tw6869: PCI 0000:02:00.0, IRQ 381, MMIO 0x40200000 (memcpy mode)
[   47.543791] tw686x 0000:02:00.0: enabling device (0000 -> 0002)
[   48.172078] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x00000000, fsynr=0x1, cb=21, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   48.185283] mc-err: (255) csr_afir: EMEM address decode error
[   48.191178] mc-err:   status = 0x2032700e; addr = 0x3ffffffc0
[   48.197036] mc-err:   secure: yes, access-type: read
[   48.202104] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000200, hubc_int_status=0x00000000
[   48.212712] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000200, hubc_int_status=0x00000000
[   48.223314] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000200, hubc_int_status=0x00000000
[   48.233914] mc-err: Too many MC errors; throttling prints
[   52.858925] CPU4: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000102, esr=bf40c000
How we can fix it? Thanks.
hello smarttowel0,
I am not sure what’s modification you had done,
instead of inserting the kernel module, could you please download L4T Sources.
please include your changes and compile the kernel image for verification.
thanks
few packages needs to be enabled while building kernel in make menuconfig,
packages like :- V4L2
configs like :- VIDEOBUF2_DMA_SG VIDEOBUF EM2MEM
just search VIDEOBUF in make menuconfig and enable related things
then build kernel
