Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
other
Problems with building cudla models using EngineCapability::kDLA_STANDALONE.
We want to use patterns kDLA_STANDALONE to run the model, but we encounter the following error when compiling the model.
[01/02/1970-22:13:57] [V] [TRT] Original: 97 layers
[01/02/1970-22:13:57] [V] [TRT] After dead-layer removal: 97 layers
[01/02/1970-22:13:58] [E] Error[2]: [foreignNode.cpp::determineCandidateForeignNodes::910] Error Code 2: Internal Error (Safety certified DLA should only have one graph for the whole network.)
[01/02/1970-22:13:58] [E] Error[2]: [builder.cpp::buildSerializedNetwork::636] Error Code 2: Internal Error (Assertion engine != nullptr failed. )
[01/02/1970-22:13:58] [E] Engine could not be created from network
[01/02/1970-22:13:58] [E] Building engine failed
[01/02/1970-22:13:58] [E] Failed to create engine from model or file.
[01/02/1970-22:13:58] [E] Engine set up failed
You can’t go wrong without using mode kDLA_STANDALONE.
I know that normal models do have many foreignNodes, how do we use kDLA_STANDALONE to build models with multiple foreignNodes.
