I followed the camera calibration tutorial in a 4 camera setup of a car. After doing the tutorial the rig file has some strange values and the validation images give bad results.
Any idea in what we may be doing wrong? I will share with you the folder of the calibration.
Kind regards.
https://drive.google.com/open?id=1p2zEUCUFf5c1e4YbWdsAi1Kih73kd5Ll
Dear mgarcia333,
Could you file a bug for for this issue with all setup deatils. Please login to https://developer.nvidia.com/drive with your credentials. Please check MyAccount->MyBugs->Submit a new bug to file bug.
Please share ID here to follow up. Thanks
Hi mgarcia333,
I am struggling with huge re-projection error problem with the camera external. I saw your directory structure for the camera calibration and I found this problem there too. The only thing that is different is the mode of operation of your camera. Is there a reason why you shot each image in manual mode ? I could not prevent this error even though the setup on my end looks drastically similar to yours.
The other thing that I wanted to ask is that is it a bug on the Nvidia end ?
Did you find out how to make it work ?
Thank you.
