When using a pixel/vertex buffer object to copy data between CUDA and GL, it seems, that glBufferData should not be called with a NULL pointer for the data parameter, or the following cudaGLRegisterBuffer command will cause an access violation.
I solved the problem by temporarily allocating a buffer, to pass to glBufferData. Anyone experienced the same thing? Or maybe someone who called cudaGLRegisterBuffer successfully after a call to glBufferData with NULL argument?
Thanks in advance!
weigo
