This program work as intended here, i.e. it prints “1”. It’s good practice to check the error codes from all API functions. I suspect that CUDA failed to initialize on your system. This can happen for a number of reasons (e.g. a driver mismatch). Below is a version of the code that includes return code checking.
Thank you for your answer.
There is an error:
Cuda error in ‘testsafe.cu’ in line 27 : unspecified driver error.
Line 27 is: CUDA_SAFE_CALL (cudaMemcpy2D(&b, pitch, &a, nsizeof(int), nsizeof(int), m, cudaMemcpyHostToDevice));
I know now that the configuration is wrong an not the code.
There is an error:
