Problems with Generative AI with Diffusion Models course
I have been having problems with the assesment for Generative AI with Diffusion Models course throwing runtime errors even though the Pre-assessment goes through smoothly with no problems.
assesment_error.txt (5.5 KB)
Welcome to the NVIDIA forums. I am assigning your issue to the DLI team for help. Someone will respond ASAP.
Thanks for your patience,
Tom
Have you received any news from the DLI team?
Hi @leon.pinter,
The team does not work weekends. Please allow for some time for a reply.
If the pre-assessment runs fine, it might be an issue with the environment for the final assessment. Have you checked for version mismatches or APK Spotify Premium GPU availability.
The problem I run into is type mismatching for tensors. I had to cast them in the pre-assesment itself even where it didn’t say “FIX ME” to get the it to work which doesn’t make sense. After casting types to float-32 if I remember correctly pre-assesment compiles and displays an image but the main assesment stops at line 1. It’s strange to me that if I only do the “FIX ME” for the assesment not even the pre-assesment or the actual assesment compile which makes it impossible to complete.
Unable to Run Server. It has been showing “Loading…” for the last 30 minutes.
Help me out.
Attached screenshot.
Hello @vsatyadev,
Due to escalating demand for GPUs, sometimes we are unable to launch labs (especially for courses that use multiple GPUs). If you’re seeing the “We encountered and error. Please try again” message, that just means you should come back a little while later once more GPUs become available.
