Problems with Kissattach
Hello Nvidia team,
I am trying to get a set of apps loaded and configured on my Jetson Nano (4gb version). I am running Ubuntu 18.04-LTS. I have successfully compiled and installed Direwolf and Pat Winlink. I also used the “sudo app-get install” command on ax25-tools and ax25-apps. These commands seem to work fine.
When I attempt to use the “sudo kissattach /tmp/kisstnc wl2k” command I get this error:
“kissattach: Error setting line discipline: TIOSETD invalid argument
Are you sure you have enabled MKISS support in the kernal
or, if you made it a module, is that module loaded?”
Searching the internet for a resolution for this issue led me to some suggestions to add mkiss and ax25 to the “/etc/modules-load.d/modules.conf” file, but this does not seem to resolve my issue.
Thank you in advance for any suggestions you have on what I might try next.
Kind regards,
Mike
We don’t have experience about Kissattach. Would need other users to share experience.
On online search, we see the error is listed in Bugs Fixed in Version 1.4:
Releases · wb2osz/direwolf · GitHub
FYR.
