i am facing problems with make …
i am using ubuntu 9.10 -32bit
the problem is as follows:-
root@ubuntu:~/NVIDIA_GPU_Computing_SDK/C/src/amit# make
output:-
/usr/include/string.h:43: error: inline function ‘void* memcpy(void*, const void*, size_t)’ cannot be declared weak
/usr/include/string.h:64: error: inline function ‘void* memset(void*, int, size_t)’ cannot be declared weak
/usr/include/bits/string3.h:49: error: inline function ‘void* memcpy(void*, const void*, size_t)’ cannot be declared weak
/usr/include/bits/string3.h:78: error: inline function ‘void* memset(void*, int, size_t)’ cannot be declared weak
/usr/local/cuda/bin/…/include/common_functions.h:59: error: inline function ‘void* memset(void*, int, size_t)’ cannot be declared weak
/usr/local/cuda/bin/…/include/common_functions.h:62: error: inline function ‘void* memcpy(void*, const void*, size_t)’ cannot be declared weak
/usr/local/cuda/bin/…/include/math_functions.h:422: error: inline function ‘int __signbit(double)’ cannot be declared weak
/usr/local/cuda/bin/…/include/math_functions.h:427: error: inline function ‘int __signbitf(float)’ cannot be declared weak
/usr/local/cuda/bin/…/include/math_functions.h:440: error: inline function ‘int __signbitl(long double)’ cannot be declared weak
/usr/include/bits/mathcalls.h:350: error: inline function ‘int __signbit(double)’ cannot be declared weak
/usr/include/bits/mathcalls.h:350: error: inline function ‘int __signbitf(float)’ cannot be declared weak
/usr/include/bits/mathcalls.h:350: error: inline function ‘int __signbitl(long double)’ cannot be declared weak
/usr/include/bits/mathinline.h:36: error: inline function ‘int __signbitf(float)’ cannot be declared weak
/usr/include/bits/mathinline.h:42: error: inline function ‘int __signbit(double)’ cannot be declared weak
/usr/include/bits/mathinline.h:48: error: inline function ‘int __signbitl(long double)’ cannot be declared weak
g++: obj/i386/release/template.cu.o: No such file or directory
make: *** […/…/bin/linux/release/amit] Error 1
i have installed
1.nvidia cudatoolkit 3.0
2.nvidia sdk 3.0
plz help
