I understand that I am running the Tesla K80 not in its preferred environment, but I have seen regular consumers use this product successfully so I tried it myself
I followed this, with an bit more up to date ubuntu version (Ubuntu 22.04.2 LTS) and the driver from the ubuntu additional drivers section(Nvidia server 470 driver), but the graphics cards memory is unassigned
/sbin/lspci -d "10de:*" -v -xxx
03:00.0 3D controller: NVIDIA Corporation GK210GL [Tesla K80] (rev a1)
Subsystem: NVIDIA Corporation Device 106c
Flags: fast devsel, IRQ 16
Memory at <unassigned> (64-bit, prefetchable) [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel modules: nouveau, nvidia_drm, nvidia
4G is enabled and secure boot disabled, but I had the feeling the above 4G decoding did not quite work so I added
pci=nocrs
After that the memory looked fine
/usr/bin/lspci -d “10de:*” -v -xxx
Subsystem: NVIDIA Corporation GK210GL [Tesla K80]
Memory at 400000000 (64-bit, prefetchable) [size=16G]
Memory at 800000000 (64-bit, prefetchable) [size=32M]
Capabilities: [900] Secondary PCI Express
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
bug-report-without-realloc.log.gz (880.7 KB)
But the problem NVIDIA-persistant still did not work and there was no nvidia* in /dev/
and nvidia-smi could not find any device.
In the logs it told me to enable pci=realloc so I did but this did not solve my problem. The nvidia* devices appeared in /dev/, but the memory was messy again.
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f0000000 (32-bit, non-prefetchable) [size=16M]
Kernel driver in use: nvidia
nvidia-bug-report-with-realloc.log.gz (888.4 KB)
The only other graphics driver I have installed are the i915, but since the Tesla K80 does not have a graphics output I prefer them enabled.
