Problems with nvgstcapture
Trying nvgstcapture with an imx412, I got the following errors:
$ nvgstcapture --camsrc=1 --color-format=1 --sensor-id=0 --sensor-mode=3 --timeout=5 --framerate=30 --mode=2 --video-enc=2 --video-res=4 --cap-dev-node=0
Encoder null, cannot set bitrate!
Encoder Profile = High
Supported resolutions in case of ARGUS Camera
  (2) : 640x480
  (3) : 1280x720
  (4) : 1920x1080
  (5) : 2104x1560
  (6) : 2592x1944
  (7) : 2616x1472
  (8) : 3840x2160
  (9) : 3896x2192
  (10): 4208x3120
  (11): 5632x3168
  (12): 5632x4224
Runtime ARGUS Camera Commands:
  Help : 'h'
  Quit : 'q'
  Set Capture Mode:
      mo:<val>
          (1): image
          (2): video
  Get Capture Mode:
      gmo
  Set sensor orientation:
      so:<val>
          (0): none
          (1): Rotate counter-clockwise 90 degrees
          (2): Rotate 180 degrees
          (3): Rotate clockwise 90 degrees
  Get sensor orientation:
      gso
  Set sensor mode:
      smo:<val> e.g., smo:1
  Get sensor mode:
      gsmo
  Set Whitebalance Mode:
      wb:<val>
          (0): off
          (1): auto
          (2): incandescent
          (3): fluorescent
          (4): warm-fluorescent
          (5): daylight
          (6): cloudy-daylight
          (7): twilight
          (8): shade
          (9): manual
  Get Whitebalance Mode:
      gwb
  Set Saturation (0 to 2):
      st:<val> e.g., st:1.25
  Get Saturation:
      gst
  Set Exposure Compensation (-2 to 2):
      ec:<val> e.g., ec:-2
  Get Exposure Compensation:
      gec
  Set Auto Whitebalance Lock:
      awbl:<val> e.g., awbl:0
  Get Auto Whitebalance Lock:
      awbl
  Set Auto Exposure Lock:
      ael:<val> e.g., ael:0
  Get Auto Exposure Lock:
      gael
  Set TNR Mode:
      tnrm:<val> e.g., tnrm:1
          (0): OFF
          (1): FAST
          (2): HIGH QUALITY
  Get TNR Mode:
      gtnrm
  Set TNR Strength (-1 to 1):
      tnrs:<val> e.g., tnrs:0.5
  Get TNR Strength:
      gtnrs
  Set EE Mode:
      eem:<val> e.g., eem:1
          (0): OFF
          (1): FAST
          (2): HIGH QUALITY
  Get EE Mode:
      geem
  Set EE Strength (-1 to 1):
      ees:<val> e.g., ees:0.5
  Get EE Strength:
      gees
  Set Auto Exposure Anti-Banding (0 to 3):
      aeab:<val> e.g., aeab:2
          (0): OFF
          (1): MODE AUTO
          (2): MODE 50HZ
          (3): MODE 60HZ
  Get Auto Exposure Anti-Banding:
      gaeab
  Set Gain Range:
      gr:<val><space><val> e.g., gr:1 16
  Get Gain Range:
      ggr
  Set Exposure Time Range:
      etr:<val><space><val> e.g., etr:34000 35000
  Get Exposure Time Range:
      getr
  Set ISP Digital Gain Range:
      dgr:<val><space><val> e.g., dgr:2 152
  Get ISP Digital Gain Range:
      gdgr
  Capture: enter 'j' OR
           followed by a timer (e.g., jx5000, capture after 5 seconds) OR
           followed by multishot count (e.g., j:6, capture 6 images)
           timer/multihot values are optional, capture defaults to single shot with timer=0s
  Start Recording : enter '1'
  Stop Recording  : enter '0'
  Video snapshot  : enter '2' (While recording video)
  Get Preview Resolution:
      gpcr
  Get Image Capture Resolution:
      gicr
  Get Video Capture Resolution:
      gvcr
Runtime encoder configuration options:
  Set Encoding Bit-rate(in bytes):
      br:<val> e.g., br:4000000
  Get Encoding Bit-rate(in bytes):
      gbr
  Set Encoding Profile(only for H.264):
      ep:<val> e.g., ep:1
          (0): Baseline
          (1): Main
          (2): High
  Get Encoding Profile(only for H.264):
      gep
  Force IDR Frame on video Encoder(only for H.264):
      Enter 'f'
bitrate = 14000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
** Message: 16:02:55.927: <main:4674> iterating capture loop ....
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4056 x 3040 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 356.175995; Exposure Range min 7000, max 660000000;
GST_ARGUS: 3840 x 2160 FR = 83.999999 fps Duration = 11904762 ; Analog Gain range min 1.000000, max 356.175995; Exposure Range min 7000, max 660000000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 356.175995; Exposure Range min 7000, max 660000000;
GST_ARGUS: 1920 x 1080 FR = 249.000016 fps Duration = 4016064 ; Analog Gain range min 1.000000, max 356.175995; Exposure Range min 7000, max 660000000;
GST_ARGUS: 4056 x 3040 FR = 44.000001 fps Duration = 22727272 ; Analog Gain range min 1.000000, max 356.175995; Exposure Range min 7000, max 660000000;
GST_ARGUS: 3840 x 2160 FR = 60.999999 fps Duration = 16393443 ; Analog Gain range min 1.000000, max 356.175995; Exposure Range min 7000, max 660000000;
GST_ARGUS: 1280 x 720 FR = 44.000001 fps Duration = 22727272 ; Analog Gain range min 1.000000, max 356.175995; Exposure Range min 7000, max 660000000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 3
   Output Stream W = 1920 H = 1080
   seconds to Run    = 5
   Frame Rate = 249.000016
GST_ARGUS: Setup Complete, Starting captures for 5 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
ERROR on bus: by /GstPipeline:capture_native_pipeline/GstBin:cap_bin/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:capture_native_pipeline/GstBin:cap_bin/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason error (-5)
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
^C** Message: 16:04:27.887: <_intr_handler:4262> User Interrupted..
^C
Normal gstreamer pipelines with nvarguscamerasrc do work, so I wonder what the problem might be.
Could be Xavier don’t support HW encod. Try below configuration.
–video-enc=0
It does work with gstreamer’s nvv4l2h265enc and omxh265enc…
I am using a Jetson AGX Xavier Industrial.
Does not seem to be any difference with --video-enc=0
$ nvgstcapture --camsrc=1 --color-format=1 --sensor-id=0 --sensor-mode=3 --timeout=5 --framerate=30 --mode=2 --video-enc=2 --video-res=4 --cap-dev-node=0 --video-enc=0
  (2) : 640x480
  (3) : 1280x720
  (4) : 1920x1080
  (5) : 2104x1560
  (6) : 2592x1944
  (7) : 2616x1472
  (8) : 3840x2160
  (9) : 3896x2192
  (10): 4208x3120
  (11): 5632x3168
  (12): 5632x4224
  Help : 'h'
  Quit : 'q'
  Set Capture Mode:
      mo:<val>
          (1): image
          (2): video
  Get Capture Mode:
      gmo
      so:<val>
          (0): none
      gso
  Set sensor mode:
  Get sensor mode:
      gsmo
      wb:<val>
          (0): off
          (1): auto
          (2): incandescent
          (3): fluorescent
          (5): daylight
          (7): twilight
          (8): shade
          (9): manual
      gwb
  Get Saturation:
      gst
      gec
      awbl
      gael
  Set TNR Mode:
      tnrm:<val> e.g.,er (e.g., jx5000, capture after 5 seconds) OR
      gpcr
      gicr
      gvcr
      gbr
      ep:<val> e.g., ep:1
          (0): Baseline
          (1): Main
          (2): High
      gep
      Enter 'f'
bitrate = 14000000
** Message: 09:16:44.066: <main:4674> iterating capture loop ....
NvMMLiteOpen : Block : BlockType = 4
NvMMLiteBlockCreate : Block : BlockType = 4
   Camera index = 0
   Camera mode  = 3
   seconds to Run    = 5
debug info:
^C** Message: 09:17:08.743: <_intr_handler:4262> User Interrupted..
^C
Your command have two --video-enc
I don’t see the problem on Xavier with r35.5 no matter --video-enc is 0 or 2
Removed the extra --video-enc, but no change.
$ nvgstcapture --camsrc=1 --color-format=1 --sensor-id=0 --sensor-mode=3 --timeout=5 --framerate=30 --mode=2 --video-enc=0 --video-res=4 --cap-dev-node=0
  (2) : 640x480
  (3) : 1280x720
  (4) : 1920x1080
  (5) : 2104x1560
  (6) : 2592x1944
  (7) : 2616x1472
  (8) : 3840x2160
  (9) : 3896x2192
  (10): 4208x3120
  (11): 5632x3168
  (12): 5632x4224
  Help : 'h'
  Quit : 'q'
  Set Capture Mode:
      mo:<val>
          (1): image
          (2): video
  Get Capture Mode:
      gmo
      so:<val>
          (0): none
      gso
  Set sensor mode:
  Get sensor mode:
      gsmo
      wb:<val>
          (0): off
          (1): auto
          (2): incandescent
          (3): fluorescent
          (5): daylight
          (7): twilight
          (8): shade
          (9): manual
      gwb
  Get Saturation:
      gst
      gec
      awbl
  Set     getr
      gdgr
      gpcr
      gicr
      gvcr
      gbr
      ep:<val> e.g., ep:1
          (0): Baseline
          (1): Main
          (2): High
      gep
      Enter 'f'
bitrate = 14000000
** Message: 09:16:55.248: <main:4674> iterating capture loop ....
   Camera index = 0
   Camera mode  = 3
   seconds to Run    = 5
debug info:
^C** Message: 09:17:02.359: <_intr_handler:4262> User Interrupted..
^C
I am using R32.7.1
By the way, thos nvgstcapture needs a display? As our carrier does not have one.
Ok, I was check on r35.x without problem.
Something on this?
Don’t need display. But need headless setup to initialize GPU driver.
Jetson Nano Headless Rendering - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
Please try other sensor mode. It looks like 1920x1080 249fps mode is picked and the TV may not support this mode. Please try 44 fps or 60 fps modes.
I do choose --framerate=30, the 249 is the maximum framerate.
Is there a better way to select the framerate? I’ll see if there are modes that keep the max framerate a bit lower.
Suppose the --framerate didn’t limit the frame to 30fps but use for select sensor mode. Please verify by --sensor_mode=6 for 720p@44
Right, used all the above, and still I get the same errors:
$ echo $DISPLAY
$ startx -- :0 &
[1] 7592
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.15.0-163-generic aarch64 Ubuntu
Current Operating System: Linux vpm626i4 4.9.253-tegra #1 SMP PREEMPT Thu Apr 4 14:24:29 BST 2024 aarch64
Kernel command line: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1    quiet root=PARTUUID=1edb9f47-fd83-472f-ab28-8057f9c34580 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
Build Date: 14 December 2021  04:14:51PM
xorg-server 2:1.19.6-1ubuntu4.10 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.34.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Dec 10 09:31:24 2021
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
$ DISPLAY=:0.0 xhost +
access control disabled, clients can connect from any host
$ export DISPLAY=:0.0
$ nvgstcapture --camsrc=1 --color-format=1 --sensor-id=0 --sensor-mode=6 --timeout=5 --framerate=30 --mode=2 --video-enc=0 --video-res=3 --cap-dev-node=0
  (2) : 640x480
  (3) : 1280x720
  (4) : 1920x1080
  (5) : 2104x1560
  (6) : 2592x1944
  (7) : 2616x1472
  (8) : 3840x2160
  (9) : 3896x2192
  (10): 4208x3120
  (11): 5632x3168
  (12): 5632x4224
  Help : 'h'
  Quit : 'q'
  Set Capture Mode:
      mo:<val>
          (1): image
          (2): video
  Get Capture Mode:
      gmo
      so:<val>
          (0): none
      gso
  Set sensor mode:
  Get sensor mode:
      gsmo
      wb:<val>
          (0): off
          (1): auto
          (2): incandescent
          (3): fluorescent
          (5): daylight
          (7): twilight
          (8): shade
          (9): manual
      gwb
  Get Saturation:
      gst
      gec
      awbl
      gael
  Set TNR Mlowed by a timer (e.g., jx5000, capture after 5 seconds) OR
      gpcr
      gicr
      gvcr
      gbr
      ep:<val> e.g., ep:1
          (0): Baseline
          (1): Main
          (2): High
      gep
      Enter 'f'
bitrate = 8000000
** Message: 09:36:19.539: <main:4674> iterating capture loop ....
   Camera index = 0
   Camera mode  = 6
   Output Stream W = 1280 H = 720
   seconds to Run    = 5
   Frame Rate = 44.000001
debug info:
^C** Message: 09:36:25.450: <_intr_handler:4262> User Interrupted..
^C
