Hi, after a while I wanted to restart using my xavier NX to make same vide analyses with opencv. I tried to build a python programm, using python 3.9.25, and opencv 4.12.0. I have raspi cam’s on both sockets, but none of them seems to return a frame.
my code is rather simple
import cv2
print(cv2.__version__)
cam1Set = 'nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=3264, geight=2464, framerate=21/1, format=NV12 ! nvvidconv flip-method=2 ! video/x-raw, width=800, height=600, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink'
cam1=cv2.VideoCapture(cam1Set)
while True:
_, frame1 = cam1.read()
cv2.imshow('cam1', frame1)
cv2.moveWindow('cam',0,0)
if cv2.waitKey(1) == ord('q'):
break
cam1.release()
cv2.destroyAllWindows()
but i get the following error :
File "/home/marc/Development/Python/pypro/initial.py", line 10, in <module>
cv2.error: OpenCV(4.12.0) /io/opencv/modules/highgui/src/window.cpp:973: error: (-215:Assertion failed) size.width>0 && size.height>0 in function 'imshow'
my jetpack version :
Package: nvidia-jetpack
Version: 5.1.1-b56
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 5.1.1-b56), nvidia-jetpack-dev (= 5.1.1-b56)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_5.1.1-b56_arm64.deb
SHA256: 7b6c8c6cb16028dcd141144b6b0bbaa762616d0a47aafa3c3b720cb02b2c8430
SHA1: 387e4e47133c4235666176032af0f2ec86461dbb
MD5sum: 0a8692031bf35cc46f7a498e2937bda9
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
cv2.getBuildInformation() returns :
General configuration for OpenCV 4.12.0 =====================================
Version control: 4.12.0-dirty
Extra modules:
Location (extra): /io/opencv_contrib/modules
Version control (extra): 4.12.0
Platform:
Timestamp: 2025-07-04T17:00:56Z
Host: Linux 6.8.0-51-generic aarch64
CMake: 4.0.3
CMake generator: Unix Makefiles
CMake build tool: /bin/gmake
Configuration: Release
Algorithm Hint: ALGO_HINT_ACCURATE
CPU/HW features:
Baseline: NEON FP16
requested: DETECT
Dispatched code generation: NEON_DOTPROD NEON_FP16 NEON_BF16
requested: NEON_FP16 NEON_BF16 NEON_DOTPROD
NEON_DOTPROD (2 files): + NEON_DOTPROD
NEON_FP16 (2 files): + NEON_FP16
NEON_BF16 (0 files): + NEON_BF16
C/C++:
Built as dynamic libs?: NO
C++ standard: 11
C++ Compiler: /opt/rh/devtoolset-10/root/usr/bin/c++ (ver 10.2.1)
C++ flags (Release): -Wl,-strip-all -fsigned-char -W -Wall -Wreturn-type -Wnon-virtual-dtor -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -Wl,-strip-all -fsigned-char -W -Wall -Wreturn-type -Wnon-virtual-dtor -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /opt/rh/devtoolset-10/root/usr/bin/cc
C flags (Release): -Wl,-strip-all -fsigned-char -W -Wall -Wreturn-type -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -Wl,-strip-all -fsigned-char -W -Wall -Wreturn-type -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release): -L/ffmpeg_build/lib -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined
Linker flags (Debug): -L/ffmpeg_build/lib -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined
ccache: YES
Precompiled headers: NO
Extra dependencies: /usr/lib64/libopenblas.so Qt5::Test Qt5::Concurrent avif /usr/local/lib/libpng.so /usr/lib64/libz.so Qt5::Core Qt5::Gui Qt5::Widgets Iconv::Iconv dl m pthread rt
3rdparty dependencies: libprotobuf ade ittnotify libjpeg-turbo libwebp libtiff libopenjp2 IlmImf tegra_hal
OpenCV modules:
To be built: aruco bgsegm bioinspired calib3d ccalib core cvv datasets dnn dnn_objdetect dnn_superres dpm face features2d flann fuzzy gapi hfs highgui img_hash imgcodecs imgproc intensity_transform line_descriptor mcc ml objdetect optflow phase_unwrapping photo plot python3 quality rapid reg rgbd saliency shape signal stereo stitching structured_light superres surface_matching text tracking video videoio videostab wechat_qrcode xfeatures2d ximgproc xobjdetect xphoto
Disabled: world
Disabled by dependency: -
Unavailable: alphamat cannops cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev fastcv freetype hdf java julia matlab ovis python2 sfm ts viz
Applications: -
Documentation: NO
Non-free algorithms: NO
GUI: QT5
QT: YES (ver 5.15.16 )
QT OpenGL support: NO
GTK+: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib64/libz.so (ver 1.2.7)
JPEG: build-libjpeg-turbo (ver 3.1.0-70)
SIMD Support Request: YES
SIMD Support: YES
WEBP: build (ver decoder: 0x0209, encoder: 0x020f, demux: 0x0107)
AVIF: avif (ver 1.3.0)
PNG: /usr/local/lib/libpng.so (ver 1.6.48)
TIFF: build (ver 42 - 4.6.0)
JPEG 2000: build (ver 2.5.3)
OpenEXR: build (ver 2.3.0)
GIF: YES
HDR: YES
SUNRASTER: YES
PXM: YES
PFM: YES
Video I/O:
FFMPEG: YES
avcodec: YES (59.37.100)
avformat: YES (59.27.100)
avutil: YES (57.28.100)
swscale: YES (6.7.100)
avresample: NO
GStreamer: NO
v4l/v4l2: YES (linux/videodev2.h)
Parallel framework: pthreads
Trace: YES (with Intel ITT(3.25.4))
Other third-party libraries:
Lapack: YES (/usr/lib64/libopenblas.so)
Eigen: NO
Custom HAL: YES (carotene (ver 0.0.1))
Protobuf: build (3.19.1)
Flatbuffers: builtin/3rdparty (23.5.9)
OpenCL: YES (no extra features)
Include path: /io/opencv/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python 3:
Interpreter: /opt/python/cp39-cp39/bin/python3.9 (ver 3.9.23)
Libraries: libpython3.9m.a (ver 3.9.23)
Limited API: YES (ver 0x03060000)
numpy: /home/ci/.local/lib/python3.9/site-packages/numpy/_core/include (ver 2.0.2)
install path: python/cv2/python-3
Python (for build): /opt/python/cp39-cp39/bin/python3.9
Java:
ant: NO
Java: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Install to: /io/_skbuild/linux-aarch64-3.9/cmake-install
every help, getting me up and running would be highly appreciated
