Problems with RSE
I’m using cuda 10.2 and when I try to connect to a RSE it gives me:
Failed to connect sshd on "192.168.1.42"
Session.connect: java.io.IOException: End of IO Stream Read
This everything that is generated on the log
!SESSION 2020-04-16 13:15:48.898 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_242
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=es_ES
Command-line arguments:  -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.rse.ui 4 0 2020-04-16 13:25:41.982
!MESSAGE RSEG1066
The conection is working properly using RSA
Debugging the connection from the server, apparently I hit this bug
https://serverfault.com/questions/729033/ssh-dh-gex-group-out-of-range
It was easily solved either removing the KexAlgorithm availability from the server or the client
