I’m trying to run the sample_drivenetNcameras on the Drive px2 AutoChauffeur with
three Sekonix 120 deg camera
three Sekonix 60 deg camera
The sample works well with 4 cameras in a single port, but if I try using another port to add 2 more cameras the output video is blurred and at times with a green tint for the output from the second port.
The first 4 cameras in camera group A remain unaffected.
Even with splitting the cameras 3 to each port the result is same.
Individually all the cameras are working fine.
Camera Details
3 x Sekonix 120 deg, Part Number: SF3324-100, Camera Module: N2.0 RCCB
3 x Sekonix 60 deg, Part Number: SF3325-100, Camera Module: N2.0 RCCB
Camera Group A
0 1 3 are connected with Sekonix 120 deg camera
2 is connected with Sekonix 60 deg
Thanks for the answer. We have some sample codes modified in this version according to our need, didn’t want it to be changed now with the newer version. Is there a way to preserver this and upgrade. Or is there a way to correct the problem without an upgrade.
Dear swetha,
The selector mask is divided based on groups, so it would be AAAABBBBCCCC and it is ordered incrementally like 321032103210. Also, mixing up of different cameras in the same port also causes problem. If possible, please upgrade to DW 0.6. You can take a backup of your project and use it in latest version.
Thank you. I have got the selector mask right. But may be using different camera is the problem, will try with same ones in a port. And as for the upgrade, will the old code be compatible with newer version. In that case I will upgrade it.
We were working with DW 0.6, but we could not make it work with ROS using cross-compile. So for the new Drive PX2 we decided to not upgrade and work with the old version since we were able to work with ROS in DW 0.3 for the other PX2 before we upgraded it to DW 0.6.
But now I guess we will have to upgrade it and make it work.
