I am having problems running the TensorRT example sampleMNIST on the Jetson Nano.
First, I am unble to build samples as described in GitHub - NVIDIA/TensorRT at release/6.0, “Building the TensorRT Components”, this requires CMake version 3.13 or later, but the version provided with the SD image is only 3.10.2 which is the latest available via ‘apt install’.
I was able to create my own Makefile in order to build sampleMNIST, but this generates a segmentation fault when trying create the builder config on line 156 of sampleMNIST.cpp
auto config = SampleUniquePtr<nvinfer1::IBuilderConfig>(builder->createBuilderConfig());
Similarly, if I follow the instructions from https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#import_caffe_c, I also get a seg fault when calling createBuilderConfig().
