Once I was using Firefox browser on Jetson, suddenly I couldn’t refresh the page. So I restarted it, but at this point I couldn’t restart Firefox anymore, and even the other downloaded software couldn’t be launched either. When I re-flashed the Jetson platform, the downloaded software still couldn’t be restarted. I have no idea why. The following picture shows the error message when starting Firefox using the command line.
The jetpack is 6.2.0
The issue you’re experiencing with the Jetson AGX Orin platform, where you can’t restart Firefox or launch other downloaded software, suggests a potential problem with the system’s configuration or software installation. Given the context, let’s break down the information and compare it with similar issues to provide a comprehensive answer.
Boot Issues and Software Problems: The context mentions several boot-related issues and software problems across different Jetson platforms, including the Jetson AGX Orin and Jetson Xavier NX. These issues range from boot failures, security concerns, to problems with launching software. Your experience with Firefox and other software not launching after a restart, and even after reflashing the Jetson platform, indicates a possible software or configuration issue that persists across reboots and even after reinstalling the system.
Comparison with Similar Issues:
- Boot Failed Issues: There are mentions of boot failures on Jetson Xavier NX and Jetson AGX Orin, which might be related to software flashing issues, security settings, or hardware compatibility problems. Your issue, however, seems more related to software launch failures rather than a boot failure.
- Security Issues: The context mentions security issues on both Jetson AGX Orin and Jetson AGX Xavier platforms. While your issue doesn’t directly point to a security problem, it’s possible that a security setting or a recent update could be causing the software launch failures.
- Software and Flashing Issues: The inability to launch software after reflashing the platform suggests that the issue might not be with the software itself but with how the system is configured or how software is installed and managed on the Jetson AGX Orin.
Potential Solutions and Considerations:
- Reinstall Software: Try reinstalling Firefox and other software that fails to launch. This might resolve any issues related to the software installation itself.
- Check System Logs: Inspect system logs for any error messages related to software launch failures. This could provide clues about what’s going wrong.
- Configuration and Permissions: Ensure that the software has the necessary permissions and that there are no configuration issues preventing the software from launching.
- Update and Flashing: If you’ve recently updated or flashed your Jetson AGX Orin, consider checking for any known issues with the current version of the software or flashing process.
- Developer Guides and Support: Refer to the NVIDIA Jetson Linux Developer Guide and other support resources for troubleshooting tips and known issues related to software installation and launch on the Jetson platforms.
Conclusion: The issue you’re facing with the Jetson AGX Orin, where software fails to launch after a restart and even after reflashing the platform, suggests a deeper configuration or software management issue. By comparing your issue with similar problems mentioned in the context, such as boot failures and security issues, and considering potential solutions like reinstalling software, checking system logs, and ensuring proper configuration and permissions, you should be able to troubleshoot and possibly resolve the issue. If the problem persists, seeking support from NVIDIA’s developer community or official support channels might provide more tailored assistance.
