I cannot seem to start the license manager for the trial version of PGI. It says the following as output:
18:58:29 (lmgrd) FlexNet Licensing (v11.11.0.0 build 106800 x64_lsb) started on login4.stampede.tacc.utexas.edu (linux) (1/31/2014)
18:58:29 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
18:58:29 (lmgrd) World Wide Web: http://www.flexerasoftware.com
18:58:29 (lmgrd) License file(s): /work/02741/mkt58/pgi/license.dat
18:58:29 (lmgrd) lmgrd tcp-port 27000
18:58:29 (lmgrd) The license server manager has found no vendor daemons to start
18:58:29 (lmgrd) (There are no VENDOR (or DAEMON) lines in the license file),
lmgrd exiting.
(Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: login4.stampede.tacc.utexas.edu
License path: /work/02741/mkt58/pgi/license.dat:
FLEXnet Licensing error:-15,570. System Error: 115 “Operation now in progress”
For further information, refer to the FLEXnet Licensing documentation,
available at “www.flexerasoftware.com”.)
