Upon a reboot of my Jetson TX2 developer kit, my external mouse and keyboard stopped working and seemed to be frozen. At that point, I decided to restart the system. After restarting, the HDMI port no longer worked and has not worked since although the board was clearly powered on. At this point, I decided to reflash with the latest jetpack for the TX2 jetpack 3.3 and was able to ssh into the machine. After the reflash the HDMI port will still not work and when i2cdetect is run for bus 0 none of the preregistered UU devices come up and the detector is very slow. Any suggestions?
HDMI gets its configuration over the DDC wire of the cable. This is i2c protocol. The power to the i2c rails used in that query is not always on (apparently part of energy savings). Any query with the power rail off would result in an error even though the hardware is valid and functional.
Do you see a file listed from this, and if so, the content:
sudo -s
# Does file exist?
find /sys -name edid
# If so, what is the content?
cat `find /sys -name edid`
exit
The presence of an edid file implies the driver exists. Having data in the file implies an i2c query succeeded at some earlier point in boot.
Hey linuxdev,
We actually followed your comment from an earlier post however once we run
we get the output
No EDID
Based on this we are concerned that there might be a problem with that specific i2c bus
I wouldn’t expect i2cdetect to work if the rail isn’t powered, but is the monitor and cable all purely HDMI? If you run “dmesg --follow” and unplug/replug, what messages do you get? Does a replug cause content to show up in the edid file, or is the content still empty?
After running dmesg --follow I get the following output which is extremely long and I am not positive what it all means
[ 4964.478597] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 4964.484181] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800070
[ 4964.490130] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7c
[ 4964.495334] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x0
[ 4964.500688] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x40
[ 4966.512775] tegra-i2c 3160000.i2c: pio timed out addr: 0x40 tlen:16 rlen:0
[ 4966.519740] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 4966.526557] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 4966.531717] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 4966.538424] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 4966.543971] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800070
[ 4966.549824] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7c
[ 4966.555035] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x0
[ 4966.560325] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x40
[ 4968.564757] tegra-i2c 3160000.i2c: pio timed out addr: 0x40 tlen:16 rlen:0
[ 4968.571748] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 4968.578567] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 4968.583726] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 4968.590435] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 4968.596025] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800070
[ 4968.601825] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7c
[ 4968.607004] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x0
[ 4968.612276] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x40
[ 5022.465164] tegra-i2c 3160000.i2c: pio timed out addr: 0x40 tlen:16 rlen:0
[ 5022.472334] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5022.479382] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5022.484665] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5022.491461] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5022.497142] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800070
[ 5022.503036] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7c
[ 5022.508307] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x0
[ 5022.513640] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x40
[ 5024.521076] tegra-i2c 3160000.i2c: pio timed out addr: 0x40 tlen:28 rlen:4
[ 5024.528043] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5024.534873] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5024.540032] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5024.546815] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5024.552400] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800040
[ 5024.558353] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5024.563555] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x0
[ 5024.568902] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x40
[ 5379.143159] tegra-i2c 3160000.i2c: pio timed out addr: 0x3 tlen:12 rlen:4
[ 5379.150040] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5379.156782] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5379.161930] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5379.168732] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5379.174326] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5379.180190] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5379.185501] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5379.190905] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x3
[ 5381.195220] tegra-i2c 3160000.i2c: pio timed out addr: 0x4 tlen:12 rlen:4
[ 5381.202194] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5381.208957] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5381.214076] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5381.220810] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5381.226379] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5381.232210] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5381.237403] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5381.242691] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x4
[ 5383.247181] tegra-i2c 3160000.i2c: pio timed out addr: 0x5 tlen:12 rlen:4
[ 5383.254062] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5383.260918] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5383.266075] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5383.272805] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5383.278402] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5383.284203] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5383.289382] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5383.294690] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x5
[ 5385.299178] tegra-i2c 3160000.i2c: pio timed out addr: 0x6 tlen:12 rlen:4
[ 5385.306054] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5385.312795] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5385.317943] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5385.324738] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5385.330320] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5385.336166] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5385.341397] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5385.346755] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x6
[ 5387.351189] tegra-i2c 3160000.i2c: pio timed out addr: 0x7 tlen:12 rlen:4
[ 5387.358065] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5387.364890] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5387.370051] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5387.376809] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5387.382364] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5387.388247] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5387.393492] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5387.398792] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x7
[ 5389.403222] tegra-i2c 3160000.i2c: pio timed out addr: 0x8 tlen:12 rlen:4
[ 5389.410121] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5389.416943] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5389.422114] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5389.428826] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5389.434387] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5389.440243] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5389.445475] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5389.450790] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x8
[ 5391.455246] tegra-i2c 3160000.i2c: pio timed out addr: 0x9 tlen:12 rlen:4
[ 5391.462123] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5391.468862] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5391.474004] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5391.480815] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5391.486396] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5391.492249] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5391.497444] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5391.502773] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x9
[ 5393.507241] tegra-i2c 3160000.i2c: pio timed out addr: 0xa tlen:12 rlen:4
[ 5393.514364] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5393.521284] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5393.526462] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5393.533200] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5393.538752] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5393.544607] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5393.549824] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5393.555148] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0xa
[ 5395.559262] tegra-i2c 3160000.i2c: pio timed out addr: 0xb tlen:12 rlen:4
[ 5395.566139] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5395.572978] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5395.578140] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5395.584877] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5395.590477] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5395.596276] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5395.601491] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5395.606781] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0xb
[ 5397.611268] tegra-i2c 3160000.i2c: pio timed out addr: 0xc tlen:12 rlen:4
[ 5397.618131] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5397.624974] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5397.630132] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5397.636847] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5397.642426] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5397.648217] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5397.653421] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5397.658770] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0xc
[ 5399.663240] tegra-i2c 3160000.i2c: pio timed out addr: 0xd tlen:12 rlen:4
[ 5399.670139] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5399.676935] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5399.682096] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5399.688813] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5399.694403] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5399.700205] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5399.705417] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5399.710704] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0xd
[ 5401.715284] tegra-i2c 3160000.i2c: pio timed out addr: 0xe tlen:12 rlen:4
[ 5401.722159] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5401.729061] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5401.734215] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5401.740995] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5401.746607] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5401.752548] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5401.757750] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5401.763071] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0xe
[ 5403.767283] tegra-i2c 3160000.i2c: pio timed out addr: 0xf tlen:12 rlen:4
[ 5403.774178] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5403.780912] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5403.786165] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5403.792871] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5403.798450] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5403.804252] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5403.809502] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5403.814773] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0xf
[ 5405.819346] tegra-i2c 3160000.i2c: pio timed out addr: 0x10 tlen:12 rlen:4
[ 5405.826309] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5405.833064] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5405.838213] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5405.845022] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5405.850617] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5405.856474] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5405.861671] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5405.866997] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x10
[ 5407.871386] tegra-i2c 3160000.i2c: pio timed out addr: 0x11 tlen:12 rlen:4
[ 5407.878404] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5407.885543] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5407.891078] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5407.897928] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5407.903502] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5407.909306] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5407.914510] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5407.920771] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x11
[ 5409.927333] tegra-i2c 3160000.i2c: pio timed out addr: 0x12 tlen:12 rlen:4
[ 5409.934313] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5409.941038] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5409.946189] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5409.952981] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5409.958565] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5409.964417] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5409.969618] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5409.974945] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x12
[ 5411.979352] tegra-i2c 3160000.i2c: pio timed out addr: 0x13 tlen:12 rlen:4
[ 5411.986316] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5411.993160] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5411.998316] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5412.005023] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5412.010612] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5412.016408] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5412.021619] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5412.026905] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x13
[ 5414.031352] tegra-i2c 3160000.i2c: pio timed out addr: 0x14 tlen:12 rlen:4
[ 5414.038318] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5414.045158] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5414.050316] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5414.057041] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5414.062649] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5414.068586] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5414.073883] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5414.079234] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x14
[ 5416.083412] tegra-i2c 3160000.i2c: pio timed out addr: 0x15 tlen:12 rlen:4
[ 5416.090378] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5416.097225] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5416.102396] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5416.109116] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5416.114743] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5416.120588] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5416.125811] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5416.131143] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x15
[ 5418.135413] tegra-i2c 3160000.i2c: pio timed out addr: 0x16 tlen:12 rlen:4
[ 5418.142372] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5418.149132] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5418.154386] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5418.161113] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5418.166787] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5418.172655] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5418.177941] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5418.183236] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x16
[ 5420.187407] tegra-i2c 3160000.i2c: pio timed out addr: 0x17 tlen:12 rlen:4
[ 5420.194391] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5420.201118] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5420.206348] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5420.213076] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5420.218668] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5420.224493] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5420.229757] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5420.235040] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x17
[ 5422.239423] tegra-i2c 3160000.i2c: pio timed out addr: 0x18 tlen:12 rlen:4
[ 5422.246383] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5422.253197] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5422.258366] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5422.265101] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5422.270688] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5422.276485] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5422.281660] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5422.286964] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x18
[ 5424.291460] tegra-i2c 3160000.i2c: pio timed out addr: 0x19 tlen:12 rlen:4
[ 5424.298416] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5424.305253] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5424.310417] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5424.317153] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5424.322749] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5424.328568] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5424.333748] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5424.339020] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x19
[ 5426.343426] tegra-i2c 3160000.i2c: pio timed out addr: 0x1a tlen:12 rlen:4
[ 5426.350391] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5426.357233] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5426.362406] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5426.369126] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5426.374676] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5426.380531] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5426.385765] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5426.391096] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x1a
[ 5428.395492] tegra-i2c 3160000.i2c: pio timed out addr: 0x1b tlen:12 rlen:4
[ 5428.402453] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5428.409279] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5428.414434] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5428.421203] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5428.426785] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5428.432721] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5428.437922] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5428.443241] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x1b
[ 5430.447492] tegra-i2c 3160000.i2c: pio timed out addr: 0x1c tlen:12 rlen:4
[ 5430.454455] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5430.461280] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5430.466440] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5430.473147] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5430.478693] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5430.484543] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5430.489757] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5430.495039] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x1c
[ 5432.499481] tegra-i2c 3160000.i2c: pio timed out addr: 0x1d tlen:12 rlen:4
[ 5432.506475] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5432.513200] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5432.518454] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5432.525182] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5432.530776] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5432.536591] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5432.541826] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5432.547096] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x1d
[ 5434.551513] tegra-i2c 3160000.i2c: pio timed out addr: 0x1e tlen:12 rlen:4
[ 5434.558478] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5434.565220] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5434.570364] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5434.577167] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5434.582749] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5434.588599] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5434.593796] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5434.599125] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x1e
[ 5436.603529] tegra-i2c 3160000.i2c: pio timed out addr: 0x1f tlen:12 rlen:4
[ 5436.610492] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5436.617331] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5436.622495] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5436.629216] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5436.634803] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5436.640601] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5436.645815] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5436.651102] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x1f
[ 5438.655523] tegra-i2c 3160000.i2c: pio timed out addr: 0x20 tlen:12 rlen:4
[ 5438.662507] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5438.669336] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5438.674502] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5438.681229] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5438.686772] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5438.692620] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5438.697832] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5438.703132] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x20
[ 5440.707526] tegra-i2c 3160000.i2c: pio timed out addr: 0x21 tlen:12 rlen:4
[ 5440.714483] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5440.721221] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5440.726454] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5440.733195] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5440.738790] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5440.744658] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5440.749900] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5440.755192] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x21
[ 5442.759545] tegra-i2c 3160000.i2c: pio timed out addr: 0x22 tlen:12 rlen:4
[ 5442.766507] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5442.773609] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5442.778851] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5442.785578] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5442.791168] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5442.797018] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5442.802233] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5442.807523] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x22
[ 5444.811547] tegra-i2c 3160000.i2c: pio timed out addr: 0x23 tlen:12 rlen:4
[ 5444.818508] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5444.825333] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5444.830512] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5444.837240] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5444.842835] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5444.848642] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5444.853856] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5444.859145] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x23
[ 5446.863600] tegra-i2c 3160000.i2c: pio timed out addr: 0x24 tlen:12 rlen:4
[ 5446.870562] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5446.877300] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5446.882530] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5446.889270] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5446.894955] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5446.900813] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5446.906078] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5446.911394] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x24
[ 5448.915571] tegra-i2c 3160000.i2c: pio timed out addr: 0x25 tlen:12 rlen:4
[ 5448.922548] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5448.929362] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5448.934551] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5448.941286] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5448.946995] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5448.952818] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5448.958120] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5448.963405] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x25
[ 5450.967609] tegra-i2c 3160000.i2c: pio timed out addr: 0x26 tlen:12 rlen:4
[ 5450.974589] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5450.981375] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5450.986524] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5450.993244] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5450.998873] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5451.004719] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5451.009947] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5451.015272] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x26
[ 5453.019595] tegra-i2c 3160000.i2c: pio timed out addr: 0x27 tlen:12 rlen:4
[ 5453.026554] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5453.033376] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5453.038535] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5453.045280] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5453.050826] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5453.056675] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5453.061889] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5453.067171] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x27
[ 5455.071613] tegra-i2c 3160000.i2c: pio timed out addr: 0x28 tlen:12 rlen:4
[ 5455.078594] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5455.085408] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5455.090575] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5455.097292] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5455.102836] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5455.108689] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5455.113903] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5455.119188] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x28
[ 5457.123670] tegra-i2c 3160000.i2c: pio timed out addr: 0x29 tlen:12 rlen:4
[ 5457.130630] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5457.137467] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5457.142630] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5457.149346] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5457.154894] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5457.160745] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5457.165957] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5457.171239] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x29
[ 5459.175652] tegra-i2c 3160000.i2c: pio timed out addr: 0x2a tlen:12 rlen:4
[ 5459.182652] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5459.189474] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5459.194648] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5459.201380] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5459.206971] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5459.212786] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5459.217997] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5459.223287] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x2a
[ 5461.227657] tegra-i2c 3160000.i2c: pio timed out addr: 0x2b tlen:12 rlen:4
[ 5461.234620] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5461.241448] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5461.246619] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5461.253353] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5461.258948] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5461.264802] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5461.270014] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5461.275316] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x2b
[ 5463.279706] tegra-i2c 3160000.i2c: pio timed out addr: 0x2c tlen:12 rlen:4
[ 5463.286666] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5463.293491] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5463.298660] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5463.305443] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5463.311040] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5463.316991] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5463.322204] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5463.327535] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x2c
[ 5465.331686] tegra-i2c 3160000.i2c: pio timed out addr: 0x2d tlen:12 rlen:4
[ 5465.338677] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5465.345496] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5465.350653] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5465.357366] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5465.362922] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5465.368780] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5465.374020] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5465.379331] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x2d
[ 5467.383703] tegra-i2c 3160000.i2c: pio timed out addr: 0x2e tlen:12 rlen:4
[ 5467.390666] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5467.397510] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5467.402662] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5467.409366] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5467.414915] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5467.420758] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5467.425968] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5467.431244] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x2e
[ 5469.435701] tegra-i2c 3160000.i2c: pio timed out addr: 0x2f tlen:12 rlen:4
[ 5469.442702] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5469.449507] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5469.454668] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5469.461377] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5469.466922] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5469.472775] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5469.477988] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5469.483271] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x2f
[ 5471.487772] tegra-i2c 3160000.i2c: pio timed out addr: 0x30 tlen:12 rlen:4
[ 5471.494748] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5471.501573] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5471.506739] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5471.513445] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5471.519040] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5471.524823] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5471.530009] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5471.535272] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x30
[ 5473.539727] tegra-i2c 3160000.i2c: pio timed out addr: 0x31 tlen:12 rlen:4
[ 5473.546679] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5473.553522] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5473.558676] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5473.565458] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5473.571044] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5473.576929] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5473.582151] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5473.587439] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x31
[ 5475.591777] tegra-i2c 3160000.i2c: pio timed out addr: 0x32 tlen:12 rlen:4
[ 5475.598741] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5475.605653] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5475.610905] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5475.617709] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5475.623309] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5475.629175] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5475.634427] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5475.639760] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x32
[ 5477.643788] tegra-i2c 3160000.i2c: pio timed out addr: 0x33 tlen:12 rlen:4
[ 5477.650751] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5477.657489] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5477.662634] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5477.669421] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5477.675002] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5477.680850] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5477.686045] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5477.691373] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x33
[ 5479.695801] tegra-i2c 3160000.i2c: pio timed out addr: 0x50 tlen:28 rlen:4
[ 5479.702765] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5479.709503] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5479.714745] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5479.721683] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5479.727276] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800040
[ 5479.733097] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5479.738292] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x0
[ 5479.743583] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x50
[ 5479.750421] tegra-i2c c240000.i2c: no acknowledge from address 0x50
[ 5479.757502] tegra-i2c 3180000.i2c: no acknowledge from address 0x50
[ 5481.747785] tegra-i2c 3160000.i2c: pio timed out addr: 0x34 tlen:12 rlen:4
[ 5481.754751] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5481.761580] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5481.766740] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5481.767733] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:4
[ 5481.767740] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 5481.767748] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 5481.767755] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5481.767761] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5481.767768] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 5481.767775] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 5481.767782] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 5481.767791] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 5481.818566] i2c i2c-4: tegra_bpmp_i2c_req ret -5
[ 5481.818573] i2c i2c-4: --- message dump for debugging ---
[ 5481.818581] i2c i2c-4: addr 0x50 flags 0x0 len 1 data:
[ 5481.818587] i2c i2c-4: 00
[ 5481.818593] i2c i2c-4:
[ 5481.818600] i2c i2c-4: addr 0x50 flags 0x1 len 1 data:
[ 5481.818606] i2c i2c-4: 10
[ 5481.818610] i2c i2c-4:
[ 5481.857555] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5481.863160] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5481.868957] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5481.874186] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5481.879468] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x34
[ 5483.815795] tegra-i2c 31b0000.i2c: pio timed out addr: 0x50 tlen:28 rlen:4
[ 5483.822781] tegra-i2c 31b0000.i2c: --- register dump for debugging ----
[ 5483.829510] tegra-i2c 31b0000.i2c: I2C_CNFG - 0x22c00
[ 5483.834678] tegra-i2c 31b0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5483.841349] tegra-i2c 31b0000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5483.846903] tegra-i2c 31b0000.i2c: I2C_FIFO_STATUS - 0x800040
[ 5483.852714] tegra-i2c 31b0000.i2c: I2C_INT_MASK - 0x7d
[ 5483.857909] tegra-i2c 31b0000.i2c: I2C_INT_STATUS - 0x0
[ 5483.863179] tegra-i2c 31b0000.i2c: i2c transfer timed out addr: 0x50
[ 5483.870308] tegra-i2c 31c0000.i2c: no acknowledge from address 0x50
[ 5483.877439] tegra-i2c 31e0000.i2c: no acknowledge from address 0x50
[ 5483.883734] tegra-i2c 3160000.i2c: pio timed out addr: 0x35 tlen:12 rlen:4
[ 5483.890653] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5483.897425] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5483.902570] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5483.909224] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5483.914745] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5483.920531] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5483.925698] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5483.930993] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x35
[ 5485.935820] tegra-i2c 3160000.i2c: pio timed out addr: 0x36 tlen:12 rlen:4
[ 5485.942800] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5485.949524] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5485.954807] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5485.961542] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5485.967124] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5485.972943] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5485.978174] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5485.983451] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x36
[ 5487.987848] tegra-i2c 3160000.i2c: pio timed out addr: 0x37 tlen:12 rlen:4
[ 5487.994833] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5488.001746] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5488.006922] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5488.013671] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5488.019233] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5488.025062] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5488.030241] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5488.035541] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x37
[ 5490.039894] tegra-i2c 3160000.i2c: pio timed out addr: 0x38 tlen:12 rlen:4
[ 5490.046899] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5490.053724] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5490.058879] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5490.065546] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5490.071086] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5490.076895] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5490.082096] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5490.087364] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x38
[ 5492.091845] tegra-i2c 3160000.i2c: pio timed out addr: 0x39 tlen:12 rlen:4
[ 5492.098831] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5492.105641] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5492.110812] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5492.117533] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5492.123081] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5492.128928] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5492.134142] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5492.139432] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x39
[ 5494.143890] tegra-i2c 3160000.i2c: pio timed out addr: 0x3a tlen:12 rlen:4
[ 5494.150853] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5494.157594] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5494.162743] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5494.169545] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5494.175141] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5494.181001] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5494.186238] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5494.191545] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x3a
[ 5496.195896] tegra-i2c 3160000.i2c: pio timed out addr: 0x3b tlen:12 rlen:4
[ 5496.202846] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5496.209681] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5496.214854] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5496.221608] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5496.227201] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5496.232999] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5496.238217] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5496.243512] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x3b
[ 5498.247908] tegra-i2c 3160000.i2c: pio timed out addr: 0x3c tlen:12 rlen:4
[ 5498.254971] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5498.261738] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5498.266893] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5498.273581] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5498.279197] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5498.284992] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5498.290227] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5498.295523] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x3c
[ 5500.299908] tegra-i2c 3160000.i2c: pio timed out addr: 0x3d tlen:12 rlen:4
[ 5500.306866] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5500.313686] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5500.318868] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5500.325606] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5500.331208] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5500.337003] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5500.342182] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5500.347466] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x3d
[ 5502.351943] tegra-i2c 3160000.i2c: pio timed out addr: 0x3e tlen:12 rlen:4
[ 5502.358901] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5502.365727] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5502.370894] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5502.377623] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5502.383169] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5502.389045] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5502.394288] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5502.399573] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x3e
[ 5504.403968] tegra-i2c 3160000.i2c: pio timed out addr: 0x3f tlen:12 rlen:4
[ 5504.410929] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5504.417783] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5504.422952] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5504.429673] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5504.435261] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5504.441083] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5504.446302] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5504.451586] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x3f
[ 5506.455951] tegra-i2c 3160000.i2c: pio timed out addr: 0x40 tlen:12 rlen:4
[ 5506.462912] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5506.469756] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5506.474914] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5506.481635] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5506.487266] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5506.493114] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5506.498413] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5506.503753] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x40
[ 5508.507954] tegra-i2c 3160000.i2c: pio timed out addr: 0x41 tlen:12 rlen:4
[ 5508.514916] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5508.521737] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5508.526889] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5508.533612] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5508.539160] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5508.545012] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5508.550243] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5508.555525] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x41
[ 5510.559973] tegra-i2c 3160000.i2c: pio timed out addr: 0x42 tlen:12 rlen:4
[ 5510.566969] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5510.573688] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5510.578843] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5510.585642] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5510.591220] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5510.597101] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5510.602298] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5510.607628] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x42
[ 5512.611986] tegra-i2c 3160000.i2c: pio timed out addr: 0x43 tlen:12 rlen:4
[ 5512.618977] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5512.625784] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5512.630939] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5512.637663] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5512.643287] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5512.649125] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5512.654347] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5512.659665] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x43
[ 5514.663989] tegra-i2c 3160000.i2c: pio timed out addr: 0x44 tlen:12 rlen:4
[ 5514.670950] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5514.677790] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5514.682953] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5514.689714] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5514.695426] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5514.701311] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5514.706612] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5514.711916] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x44
[ 5516.716018] tegra-i2c 3160000.i2c: pio timed out addr: 0x45 tlen:12 rlen:4
[ 5516.723049] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5516.729852] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5516.735012] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5516.741720] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5516.747347] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5516.753191] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5516.758416] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5516.763786] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x45
[ 5518.768056] tegra-i2c 3160000.i2c: pio timed out addr: 0x46 tlen:12 rlen:4
[ 5518.775016] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5518.781750] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5518.786897] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5518.793692] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5518.799277] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5518.805119] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5518.810315] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5518.815641] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x46
[ 5520.820041] tegra-i2c 3160000.i2c: pio timed out addr: 0x47 tlen:12 rlen:4
[ 5520.827007] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5520.833803] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5520.838954] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5520.845753] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5520.851330] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5520.857177] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5520.862373] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5520.867704] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x47
[ 5522.872071] tegra-i2c 3160000.i2c: pio timed out addr: 0x48 tlen:12 rlen:4
[ 5522.879030] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5522.885767] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5522.890898] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5522.897666] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5522.903240] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5522.909045] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5522.914239] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5522.919522] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x48
[ 5524.924085] tegra-i2c 3160000.i2c: pio timed out addr: 0x49 tlen:12 rlen:4
[ 5524.931086] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5524.937894] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5524.943058] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 5524.949774] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 5524.955405] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 5524.961261] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 5524.966579] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 5524.972095] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x49
[ 5526.976084] tegra-i2c 3160000.i2c: pio timed out addr: 0x4a tlen:12 rlen:4
[ 5526.983067] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 5526.989869] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 5526.995030] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
I had to cut this a little short due to a character limit however i hope this helps
After running
I still get the error stating ‘No EDID’
For i2c, this is more like a hardware issue to me, but I am not sure why usb is not working. This is not common on TX2.
Could you share full dmesg with only USB activity? For example, plug mouse and keyboard on board, boot up and then share the log.
After we unplugged the usb device and ran
dmesg --follow
I have attached a file which shows the dmesg output. We are really stuck at this moment and are unsure of what to try to make forward progress.
Thank you for the help
dmesg.txt (84.3 KB)
According to log, I saw IO-expander pca953x is down. If you are using original Jetpack to flash, I think it is time to RMA this device.
