Problems with USB otg port
We have a custom carrier board, utilizing the AGX Xavier (Industrial) SOM and we want to use a type-c connector to use as an otg port.
Currently we are using TI’s TPS65988 PD-controller and TI’s TUSB1042I redriver for this.
When the port operates in host mode all is fine, but when an external host tries to use the port as a device we often run into problems.
Ánd it seems to be dependent of the type of the external host. When using a Dell Precision 7730, device mode works as a charm, but when using a Dell Latitude 7420 it does not. Unfourtunately most external hosts does not work.
We have no sinking capability, but can provide 5V and 15V, and that also works as a charm. The trouble is when the usb port is supposed to enter device mode.
Attached is a dmesg log with debug printouts when a Dell Latitude 7420 is connected to the port. Also usb dts settings are attached.
I have tried numerous settings for example thw EQ/SSEQ gain settings for the redriver, and nothing seems to help.
We have a custom driver for tps65988 that exposes the extcon cables to the xhci/xudc controller.
Does anybode have any insights in where I should start digging?
dmesg:
[  416.285473] tps65988 0-0020: [typec-port] Cable state:1, cable id:1
[  416.291751] tegra-xudc-new 3550000.xudc: vbus state: 1
[  416.291975] [hold VBUS wakelock]
[  416.292123] tegra-xudc-new 3550000.xudc: exiting ELPG
[  416.292993] tegra-xudc-new 3550000.xudc: exiting ELPG done
[  416.293208] tegra-xudc-new 3550000.xudc: device mode on: 0
[  416.293399] tegra-xudc-new 3550000.xudc: active: 0 => 1
[  416.764797] tps65988 0-0020: [typec-port] Cable state:0, cable id:1
[  416.769187] tegra-xudc-new 3550000.xudc: vbus state: 0
[  416.773331] tegra-xudc-new 3550000.xudc: device mode off: 0
[  416.773591] [drop VBUS wakelock]
[  416.773735] tegra-xudc-new 3550000.xudc: active: 1 => 0
[  416.773926] tegra-xudc-new 3550000.xudc: entering ELPG
[  416.774788] tegra-xudc-new 3550000.xudc: entering ELPG done
[  417.390854] tps65988 0-0020: [typec-port] Cable state:1, cable id:2
[  417.673842] tps65988 0-0020: [typec-port] Cable state:0, cable id:2
[  418.019731] tps65988 0-0020: [typec-port] Cable state:1, cable id:1
[  418.024355] tegra-xudc-new 3550000.xudc: vbus state: 1
[  418.025857] [hold VBUS wakelock]
[  418.026007] tegra-xudc-new 3550000.xudc: exiting ELPG
[  418.028123] tegra-xudc-new 3550000.xudc: exiting ELPG done
[  418.028392] tegra-xudc-new 3550000.xudc: device mode on: 0
[  418.028621] tegra-xudc-new 3550000.xudc: active: 0 => 1
[  418.331841] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2000, lo = 0x1000000, hi = 0x0, status = 0x1000000, control = 0x8801
[  418.336264] tegra-xudc-new 3550000.xudc: CSC, PORTSC = 0x21003
[  418.338808] tegra-xudc-new 3550000.xudc: PORTSC = 0x1003
[  418.340915] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2010, lo = 0x210500, hi = 0x0, status = 0x1000000, control = 0xfc01
[  418.345123] tegra-xudc-new 3550000.xudc: USB_REQ_SET_ADDRESS
[  418.347126] tegra-xudc-new 3550000.xudc: set address: 33
[  418.349295] tegra-xudc-new 3550000.xudc: TRANSFER: ffffff800b101310, lo = 0x0, hi = 0x0, status = 0x0, control = 0x11025
[  418.353354] tegra-xudc-new 3550000.xudc: ring doorbell: 0x0
[  418.355780] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2020, lo = 0xffede310, hi = 0x0, status = 0x1000000, control = 0x8001
[  418.360459] tegra-xudc-new 3550000.xudc: trb_in_request: request ffffff800b101310 -> ffffff800b101310; trb ffffff800b101310
[  418.364482] tegra-xudc-new 3550000.xudc: bytes transferred 0 / 0
[  418.367017] tegra-xudc-new 3550000.xudc: completing request ffffffc6ca09c780 on ep 0 with status 0
[  418.370502] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2030, lo = 0x1000680, hi = 0x120000, status = 0x1000001, control = 0xfc01
[  418.374913] tegra-xudc-new 3550000.xudc: TRANSFER: ffffff800b101320, lo = 0xffe92400, hi = 0x0, status = 0x12, control = 0x10c25
[  418.379281] tegra-xudc-new 3550000.xudc: ring doorbell: 0x10000
[  418.381940] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2040, lo = 0xffede320, hi = 0x0, status = 0x1000000, control = 0x8001
[  418.386519] tegra-xudc-new 3550000.xudc: trb_in_request: request ffffff800b101320 -> ffffff800b101320; trb ffffff800b101320
[  418.396442] tegra-xudc-new 3550000.xudc: bytes transferred 18 / 18
[  418.402988] tegra-xudc-new 3550000.xudc: completing request ffffffc6c43e5480 on ep 0 with status 0
[  418.411970] tegra-xudc-new 3550000.xudc: TRANSFER: ffffff800b101330, lo = 0x0, hi = 0x0, status = 0x0, control = 0x1025
[  418.423044] tegra-xudc-new 3550000.xudc: ring doorbell: 0x10000
[  418.429033] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2050, lo = 0xffede330, hi = 0x0, status = 0x1000000, control = 0x8001
[  418.440592] tegra-xudc-new 3550000.xudc: trb_in_request: request ffffff800b101330 -> ffffff800b101330; trb ffffff800b101330
[  418.451608] tegra-xudc-new 3550000.xudc: bytes transferred 0 / 0
[  418.457815] tegra-xudc-new 3550000.xudc: completing request ffffffc6ca09c780 on ep 0 with status 0
[  418.466931] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2060, lo = 0x2000680, hi = 0xff0000, status = 0x1000002, control = 0xfc01
[  418.478598] tegra-xudc-new 3550000.xudc: TRANSFER: ffffff800b101340, lo = 0xffe92400, hi = 0x0, status = 0xff, control = 0x10c25
[  418.490124] tegra-xudc-new 3550000.xudc: ring doorbell: 0x20000
[  418.496242] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2070, lo = 0xffede340, hi = 0x0, status = 0x1000000, control = 0x8001
[  418.508018] tegra-xudc-new 3550000.xudc: trb_in_request: request ffffff800b101340 -> ffffff800b101340; trb ffffff800b101340
[  418.519194] tegra-xudc-new 3550000.xudc: bytes transferred 255 / 255
[  418.525504] tegra-xudc-new 3550000.xudc: completing request ffffffc6c43e5480 on ep 0 with status 0
[  418.534579] tegra-xudc-new 3550000.xudc: TRANSFER: ffffff800b101350, lo = 0x0, hi = 0x0, status = 0x0, control = 0x1025
[  418.545541] tegra-xudc-new 3550000.xudc: ring doorbell: 0x20000
[  418.551948] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2080, lo = 0xffede350, hi = 0x0, status = 0x1000000, control = 0x8001
[  418.563121] tegra-xudc-new 3550000.xudc: trb_in_request: request ffffff800b101350 -> ffffff800b101350; trb ffffff800b101350
[  418.574571] tegra-xudc-new 3550000.xudc: bytes transferred 0 / 0
[  418.580606] tegra-xudc-new 3550000.xudc: completing request ffffffc6ca09c780 on ep 0 with status 0
[  418.589457] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e2090, lo = 0x2000680, hi = 0x13b0000, status = 0x1000003, control = 0xfc01
[  418.601722] tegra-xudc-new 3550000.xudc: TRANSFER: ffffff800b101360, lo = 0xffe92400, hi = 0x0, status = 0x13b, control = 0x10c25
[  418.613335] tegra-xudc-new 3550000.xudc: ring doorbell: 0x30000
[  418.620088] android_work: sent uevent USB_STATE=CONNECTED
[  418.687635] tegra-xudc-new 3550000.xudc: EVENT: ffffff800d1e20a0, lo = 0x1000000, hi = 0x0, status = 0x1000000, control = 0x8801
[  418.688932] tegra-xudc-new 3550000.xudc: CSC, PORTSC = 0x20080
[  418.689593] tegra-xudc-new 3550000.xudc: completing request ffffffc6c43e5480 on ep 0 with status -108
[  418.690707] tegra-xudc-new 3550000.xudc: PORTSC = 0x80
[  418.691615] android_work: sent uevent USB_STATE=DISCONNECTED
dts:
	xusb_padctl: xusb_padctl@3520000 {
		status = "okay";
		pads {
			usb2 {
				lanes {
					usb2-0 {
						nvidia,function = "xusb";
						status = "disabled";
					usb2-1 {
						status = "okay";
					usb2-2 {
					usb2-3 {
						status = "okay";
			usb3 {
				lanes {
					usb3-0 {
					usb3-2 {
					usb3-3 {
						status = "okay";
		ports {
			usb2-0 {
				mode = "host";
				vbus-supply = <&battery_reg>;
			usb2-1 {
				mode = "otg";
				status = "okay";
			usb2-2 {
				mode = "host";
			usb2-3 {
				mode = "host";
				status = "okay";
			usb3-0 {
				nvidia,usb2-companion = <0x02>;
			usb3-2 {
				nvidia,usb2-companion = <0x00>;
			usb3-3 {
				nvidia,usb2-companion = <0x01>;
				status = "okay";
	tegra_xudc: xudc@3550000 {
		extcon-cables = <&typec_port_1 0>;
		extcon-cable-names = "vbus";
		#extcon-cells = <1>;
		phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
			<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-3}>;
		phy-names = "usb2-1", "usb3-3";
		nvidia,xusb-padctl = <&xusb_padctl>;
		nvidia,boost_cpu_freq = <1200>;
		status = "okay";
	tegra_xhci: xhci@3610000 {
		extcon-cables = <&typec_port_1 1>;
		extcon-cable-names = "id";
			<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-3}>,
		phy-names = "usb2-1", "usb2-3", "usb3-3";
		status = "okay";
USB issue always need schematic. Sharing few lines and few device tree won’t be sufficient to debug.
Nevermind, I found out what the problem was. The vSafe5V PDO in the Source_Capabilities Message from the tps65988 device did not set bit 26 (USB Communications Capable). Apparently some devices do not check this and establishes connection anyway, while most devices disconnects. So it was the other end that performed the disconnection. A correction of the application code for the tps65988 device corrected the problem.
