Problems with using `sizeof` in `requires` clause
This should compile, but it doesn’t
template <typename... U>
constexpr auto adder(U... u) ->  bool
    requires(sizeof...(U) == 3)
    return true;
bool f()
   return adder<int>(2,34,45);
I talked with engineering who agree that is a compiler issue and we’ve added TPR#33322 to track.
The work around would be to change:
to
return adder<int,int,int>(2,34,45);
Thanks for the report,
Mat
Thanks a for a quick reply. I’ll use the work-around for now.
Hi j.badwaik,
We should have TPR #33322 fixed in our 23.5 release.
% nvc++ --c++20 vpreq.cc -V23.3
"vpreq.cc", line 13: error: no instance of function template "f" matches the argument list
            argument types are: (int, unsigned int, double)
    f<int>(1, 2u, 3.0); // error
"vpreq.cc", line 14: error: no instance of function template "g" matches the argument list
    g<int>(4, 5u, 6.0); // error
2 errors detected in the compilation of "vpreq.cc".
% nvc++ --c++20 vpreq.cc -V23.5
Thanks again for the report,
Mat
Thank you! :-)
Hello, I have tried it out using nvcc version 12.1 and nvc++ version 23.5 and it still does not work on both of them using this example, even with the suggested temporary fix.
#include <concepts>
#include <iostream>
unsigned sum(std::unsigned_integral auto... args) requires (sizeof...(args) > 1)
  return (args + ...);
int main()
  std::cout << sum<unsigned, unsigned, unsigned, unsigned>(1u, 2u, 3u, 6u) << std::endl;
Thanks for the report dejvnayer. This is a similar but unrelated issue.
For this issue, it appears that nvc++ is having issues when a function parameter pack is expanded in a requires clause. I’ve added a problem report, TPR #33824, and sent it to engineering for investigation.
The work around would be to use a template parameter pack:
#include <concepts>
#include <iostream>
template <std::unsigned_integral... Args>
unsigned sum(Args... args) requires (sizeof...(Args) > 1)
int main()
-Mat
Thank you, Mat. I do not know if I explained clearly enough, but this issue is present when using nvcc as well, it is not related only to nvc++. I have tried it out using nvcc and gcc 12.1 and it emmits the same error.
David
Hi David,
nvcc seems to work fine for me when using g++ 12.1 as the host compiler.
Is it the exact same error? If so, my guess is that nvcc is configured to use nvc++ as the host compiler. If it’s a different error, you might be using an older g++ which doesn’t support concepts.
Here’s my output:
% g++ --version
g++ (GCC) 12.1.0
Copyright (C) 2022 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
% nvcc --std=c++20 test2.cpp -ccbin g++
% a.out
12
% nvcc --std=c++20 test2.cpp -ccbin nvc++
"test2.cpp", line 11: error: no instance of function template "sum" matches the argument list
            argument types are: (unsigned int, unsigned int, unsigned int, unsigned int)
1 error detected in the compilation of "test2.cpp".
-Mat
Hi Mat,
the problem in your case is that your file is treated as C++ file. When I rename it to .cpp it works fine as well. Try to rename it to .cu file or run the compilation like:
$ nvcc --std=c++20 -x cu test2.cpp -ccbin g++
Now you should get this error message
$ nvcc -ccbin /usr/bin/g++-12 -std=c++20 -x cu test2.cpp
$ test2.cpp(11): error: no instance of function template "sum" matches the argument list
I tried it out using both GCC 11.3 and 12.1 without success.
David
Thanks, I’m now able to replicate the error. Looks to be coming from the CUDA C++ Front-end compiler (cudafe++). This is a different team in NVIDIA so I don’t have direct insights here.
We have a few options:
You can post the same question over on the CUDA nvcc forum: CUDA NVCC Compiler - NVIDIA Developer Forums
You can submit a NVBug from your https://developer.nvidia.com/ account page.
I can submit a NVBug if you prefer, but you wouldn’t get updates so it’s probably better to submit it yourself.
I looked through NVBugs for similar issues, but didn’t see anything. Though I could have missed it.
I have submitted a bug ID 4165263. Thank you, Mat.
