Hi all,
I’d like to ask about your approach to procedural environments. Are you using some external tools or utilize pure Replicator for that?
I’m a 3D Generalist and I’m familiar with Blender’s Geometry Nodes, Unreal’s PCG, but not so much with programming. I used concepts I was familiar with and just translated it to python with LLM. Later when I was doing documenting my work after the project I learned about useful snippets from Replicator that I could use instead of recreating whole collision detection system.
I did whole sequential system spawning required assets. Every stage reads the potential candidate prims positions left behind by the previous one and after spawning required assets, writes new candidates for the next step. So first assembly line was spawned in pre-defined volumes. Then next to it, machines were spawned. Next trolleys and pallets next to those machines. Next crates on spawn points and some obstacles to fill out space. At the very end I used Replicator to pick variants. All previous generation was custom code. So my question is, was it overkill to write it from scratch or it’s the right approach?
I described it in my post-mortem (link to my blog) if someone’s interested in more details. Also pointing out my mistakes will be appreciated.
So does someone want’s to share their approach? If there are any documents about procedural scene generation in OV, I’d gladly take them.
Cheers!
I’ve been doing something similar. In the last 6-9 months, (with supervision) agents have become quite powerful, and can assist in building any system, implement any algorithm, generate assets, combine outputs with generative augmentation, and chain it all together. The foundation of replicator, for generating the annotations, and AOVs is still part of the dataset generation pipeline, but the means of generating and scaling the domain randomizations and assets is much easier - which is great news, because it was one of the biggest bottlenecks for SDG.
Thanks for your perspective. Yeah, I did it like a half year ago, so I had to guide the LLM step by step. It was ChatGPT 5 I suppose. It surely would be easier today with Opus/Astra.
I asked this because I’d like to know if there’s a specific architecture I should use and what I shouldn’t due to differences in performance or limitations etc for such a project. What I get from your response is that you don’t really care about this anymore, and just let agents loose to create freely? No guidance whatsoever, only stating the output goal and close your eyes? :D
So you suggest it’s more beneficial to learn how to operate with agents rather than learning principals of OpenUSD nowadays?
May I also ask what are you using for asset generation? Is it one of the newest Astra/Opus or generators such as tripo.ai / Hunyuan3D? I tested only some opensource models with ComfyUI but still find them useless for real work.
