Process eating CPU
Hi.
I don’t know if it’s normal, I wrote a little program to test OpenMp in
a Linux machine (RH 7.1 2.96-98, Intel Xeon 2.8GHz, two CPUs).
program testeOpenMP
implicit none
integer,dimension(1000,2) :: board
integer :: i,j,k
integer::omp_get_thread_num
call omp_set_dynamic(.FALSE.)
call omp_set_num_threads(2)
!$OMP PARALLEL DO PRIVATE(j)
do i=1,1000
j = omp_get_thread_num()+ 1
board(i,j)=i+j
enddo
read(,) k
END
Then I made de executable.
pgf90 -O2 -mp -o testeOpenMP testeOpenMP.f90
Well, when I use top command (program is waiting the keyboard
input (read(,))), its shows me 3 processes, and one eating CPU without doing anything useful, at least for me. In a IRIX machine this
don’t occur.
CPU0 states: 0.1% user, 0.3% system, 0.0% nice, 99.1% idle
CPU1 states: 100.0% user, 0.0% system, 0.0% nice, 0.0% idle
Mem: 2061776K av, 1979060K used, 82716K free, 0K shrd, 129864K
buff
Swap: 8193104K av, 1381520K used, 6811584K free 1445708K
cached
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME COMMAND
14608 s099 16 0 692 692 496 R 99.9 0.0 49:41 testeOpenMP
14606 s099 9 0 692 692 496 S 0.0 0.0 0:00 testeOpenMP
14607 s099 9 0 692 692 496 R 0.0 0.0 0:00 testeOpenMP
Is it normal? Am I doing anything wrong?
Thanks, bye.
Anselmo
Hi Anselmo,
This is normal behavior. Our OpenMP runtime only creates each thread once and then attached and detaches to the threads as needed. When not in use, the threads are in a ‘sched_yield’ state, meaning that while they may be using CPU time, if another process needs that CPU, the thread will yield.
  • Mat
Hi Mat.
First of all I would like to thank you for your attention. I read in another forum (Programming and Compiling-OpenMP high system usage) a similar problem and, in the last message, you suggested to set the number of threads to one after de parallel region. I did this and the top command shows me now only two threads sleeeping.
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME CMD
27248 s099 9 0 736 732 528 S 0.0 0.0 0:10 testeOpenMP
27249 s099 8 0 736 732 528 S 0.0 0.0 0:00 testeOpenMP
As my application will have few parallel regions, I think that thil will solve my concern.
Thank you again.
Bye
Anselmo
