Why process killed without no errors
[2019.10.28-05.58.55:717][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ASTC_24x.png' error.
[2019.10.28-05.58.55:717][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ASTC_24x.png
[2019.10.28-05.58.55:717][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-05.58.55:717][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-05.58.55:718][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-05.58.55:718][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-05.58.57:706][ 0]LogShaderCompilers: Display: Shaders left to compile 3895
[2019.10.28-05.59.00:672][ 0]LogShaderCompilers: Display: Shaders left to compile 3885
[2019.10.28-05.59.01:371][ 0]SourceControl: Source control is disabled
[2019.10.28-05.59.01:535][ 0]LogPackageName: SearchForPackageOnDisk took 0.131s to resolve CarterWarehouse_P.
[2019.10.28-05.59.01:752][ 0]Cmd: MAP LOAD FILE="../../../IsaacSimProject/Content/Maps/Warehouse/CarterWarehouse_P.umap" TEMPLATE=0 SHOWPROGRESS=0 FEATURELEVEL=3
[2019.10.28-05.59.01:768][ 0]LightingResults: New page: Lighting Build
[2019.10.28-05.59.02:115][ 0]LoadErrors: New page: Loading map: CarterWarehouse_P.umap
[2019.10.28-05.59.02:117][ 0]MapCheck: New page: Map Check
[2019.10.28-05.59.02:117][ 0]LightingResults: New page: Lighting Build
[2019.10.28-05.59.03:297][ 0]LogShaderCompilers: Display: Shaders left to compile 3875
[2019.10.28-05.59.04:491][ 0]LogShaderCompilers: Display: Shaders left to compile 3865
[2019.10.28-05.59.11:013][ 0]LogShaderCompilers: Display: Shaders left to compile 3855
[2019.10.28-05.59.11:013][ 0]LogShaderCompilers: Display: Shaders left to compile 3845
[2019.10.28-05.59.12:099][ 0]LogShaderCompilers: Display: Shaders left to compile 3835
[2019.10.28-05.59.24:101][ 0]LogTexture: Display: Building textures: cables_albido (AutoDXT, 2048X2048)
[2019.10.28-05.59.24:102][ 0]LogTexture: Display: Building textures: cables_roughness (AutoDXT, 2048X2048)
[2019.10.28-05.59.24:102][ 0]LogTexture: Display: Building textures: T_WhitePlastic_D (AutoDXT, 4096X4096)
[2019.10.28-05.59.24:102][ 0]LogTexture: Display: Building textures: cables_normal (BC5, 2048X2048)
[2019.10.28-05.59.24:102][ 0]LogTexture: Display: Building textures: cables_metallic (AutoDXT, 2048X2048)
[2019.10.28-05.59.24:102][ 0]LogTexture: Display: Building textures: cables_ao (AutoDXT, 2048X2048)
[2019.10.28-05.59.24:102][ 0]LogTexture: Display: Building textures: main_normal (BC5, 4096X4096)
[2019.10.28-05.59.24:102][ 0]LogShaderCompilers: Display: Shaders left to compile 3825
[2019.10.28-05.59.24:102][ 0]LogTexture: Display: Building textures: main_roughness (AutoDXT, 4096X4096)
[2019.10.28-05.59.24:246][ 0]LogStaticMesh: Building static mesh carter_backwheel_caster...
[2019.10.28-05.59.24:813][ 0]LogStaticMesh: Built static mesh [0.59s] /Game/Carter/Geometry/Carter_FixedPivots/carter_backwheel_caster.carter_backwheel_caster
[2019.10.28-05.59.24:945][ 0]LogAnimationCompression: Building Anim DDC data for AnimSequence /NVCharacter/Anim/sol/sol_sitTableToUseLaptop_anim.sol_sitTableToUseLaptop_anim
[2019.10.28-05.59.24:946][ 0]LogAnimationCompression: Recompressing (AnimSequence /NVCharacter/Anim/sol/sol_sitTableToUseLaptop_anim.sol_sitTableToUseLaptop_anim) using current/default (AnimCompress_BitwiseCompressOnly_12) bFirstRecompressUsingCurrentOrDefault(1) bTryAlternateCompressor(0) IsCompressedDataValid(0)
[2019.10.28-05.59.24:952][ 0]LogMaterial: Display: Missing cached shader map for material cables, compiling.
[2019.10.28-05.59.25:061][ 0]LogAnimationCompression: Building Anim DDC data for AnimSequence /NVCharacter/Anim/sol/sol_CellPhStanding.sol_CellPhStanding
[2019.10.28-05.59.25:061][ 0]LogAnimationCompression: Recompressing (AnimSequence /NVCharacter/Anim/sol/sol_CellPhStanding.sol_CellPhStanding) using current/default (AnimCompress_BitwiseCompressOnly_2) bFirstRecompressUsingCurrentOrDefault(1) bTryAlternateCompressor(0) IsCompressedDataValid(0)
[2019.10.28-05.59.25:571][ 0]LogShaderCompilers: Display: Shaders left to compile 3834
[2019.10.28-05.59.25:572][ 0]LogMeshUtilities: Finished distance field build in 0.3s - 8x8x8 distance field, 778 triangles, Range [-0.0, 1.0], carter_backwheel_caster
[2019.10.28-05.59.25:996][ 0]LogStaticMesh: Building static mesh WheelGuard...
[2019.10.28-05.59.26:001][ 0]LogStaticMesh: Built static mesh [0.01s] /Game/Carter/Geometry/WheelGuard.WheelGuard
[2019.10.28-05.59.26:473][ 0]LogMeshUtilities: Finished distance field build in 0.3s - 8x8x8 distance field, 108 triangles, Range [-0.2, 0.3], WheelGuard
[2019.10.28-05.59.26:473][ 0]LogStaticMesh: Building static mesh carter_main...
[2019.10.28-05.59.27:801][ 0]LogTexture: Display: Building textures: main_metallic (AutoDXT, 4096X4096)
[2019.10.28-05.59.27:801][ 0]LogShaderCompilers: Display: Shaders left to compile 3824
[2019.10.28-05.59.27:803][ 0]LogStaticMesh: Built static mesh [1.35s] /Game/Carter/Geometry/Carter_FixedPivots/carter_main.carter_main
[2019.10.28-05.59.28:158][ 0]LogStaticMesh: Building static mesh carter_tray...
[2019.10.28-05.59.28:381][ 0]LogStaticMesh: Built static mesh [0.22s] /Game/Carter/Geometry/Carter_FixedPivots/carter_tray.carter_tray
[2019.10.28-05.59.28:549][ 0]LogStaticMesh: Building static mesh carter_wheel_center...
[2019.10.28-05.59.28:655][ 0]LogStaticMesh: Built static mesh [0.11s] /Game/Carter/Geometry/Carter_FixedPivots/carter_wheel_center.carter_wheel_center
[2019.10.28-05.59.28:894][ 0]LogMeshUtilities: Finished distance field build in 0.2s - 8x8x8 distance field, 3972 triangles, Range [-0.0, 0.4], carter_tray
[2019.10.28-05.59.28:894][ 0]LogStaticMesh: Building static mesh carter_wheel_left...
[2019.10.28-05.59.29:061][ 0]LogStaticMesh: Built static mesh [0.17s] /Game/Carter/Geometry/Carter_FixedPivots/carter_wheel_left.carter_wheel_left
[2019.10.28-05.59.29:245][ 0]LogStaticMesh: Building static mesh carter_wheel_right...
[2019.10.28-05.59.29:441][ 0]LogStaticMesh: Built static mesh [0.20s] /Game/Carter/Geometry/Carter_FixedPivots/carter_wheel_right.carter_wheel_right
[2019.10.28-05.59.30:788][ 0]LogMeshUtilities: Finished distance field build in 1.6s - 22x22x8 distance field, 1954 triangles, Range [-0.1, 0.7], carter_wheel_center
[2019.10.28-05.59.30:789][ 0]LogTexture: Display: Building textures: T_WhitePlastic_N (BC5, 4096X4096)
[2019.10.28-05.59.34:459][ 0]LogTexture: Display: Building textures: main_ao (AutoDXT, 4096X4096)
[2019.10.28-05.59.34:459][ 0]LogTexture: Display: Building textures: main_albido (AutoDXT, 4096X4096)
[2019.10.28-05.59.35:781][ 0]LogTexture: Display: Building textures: T_WhitePlastic_R (AutoDXT, 4096X4096)
[2019.10.28-05.59.42:547][ 0]LogTexture: Display: Building textures: T_WhiteSquareTextureHDR (RGBA16F, 32X32)
[2019.10.28-05.59.42:547][ 0]LogTexture: Display: Building textures: arms_Roughness (G8, 4096X4096)
[2019.10.28-05.59.42:547][ 0]LogTexture: Display: Building textures: arms_Normal_DirectX (BC5, 4096X4096)
[2019.10.28-05.59.42:642][ 0]LogMaterial: Display: Missing cached shader map for material M_Master, compiling.
[2019.10.28-05.59.42:800][ 0]LogMaterial: Display: Missing cached shader map for material M_Master, compiling.
[2019.10.28-05.59.45:691][ 0]LogTexture: Display: Building textures: arms_Mixed_AO (G8, 4096X4096)
[2019.10.28-05.59.45:691][ 0]LogTexture: Display: Building textures: hair_RTX_Alpha (BC4, 4096X4096)
[2019.10.28-05.59.51:732][ 0]LogTexture: Display: Building textures: arms_microporedetailMask (AutoDXT, 4096X4096)
[2019.10.28-05.59.51:732][ 0]LogTexture: Display: Building textures: hair_ao (G8, 4096X4096)
[2019.10.28-05.59.54:950][ 0]LogTexture: Display: Building textures: mg_head_Roughness (AutoDXT, 4096X4096)
[2019.10.28-05.59.59:186][ 0]LogShaderCompilers: Display: Shaders left to compile 3946
[2019.10.28-05.59.59:186][ 0]LogShaderCompilers: Display: Shaders left to compile 3936
[2019.10.28-05.59.59:186][ 0]LogTexture: Display: Building textures: mg_head_Normal_DirectX (BC5, 4096X4096)
[2019.10.28-05.59.59:186][ 0]LogTexture: Display: Building textures: hair2_normal (BC5, 4096X4096)
[2019.10.28-06.00.07:031][ 0]LogShaderCompilers: Display: Shaders left to compile 3926
[2019.10.28-06.00.07:106][ 0]LogMaterial: Display: Missing cached shader map for material eyelashes, compiling.
[2019.10.28-06.00.07:492][ 0]LogSkeletalMesh: Building Skeletal Mesh norm_skelMesh_v0004_naked...
[2019.10.28-06.00.09:240][ 0]LogSkeletalMesh: Built Skeletal Mesh [1.75s] /NVCharacter/Characters/male/sol/norm_skelMesh_v0004_naked.norm_skelMesh_v0004_naked
[2019.10.28-06.00.09:407][ 0]LogMaterial: Display: Missing cached shader map for material M_Master, compiling.
[2019.10.28-06.00.09:682][ 0]LogAnimationCompression: Building Anim DDC data for AnimSequence /NVCharacter/Anim/sol/sol_sitting_anim.sol_sitting_anim
[2019.10.28-06.00.09:682][ 0]LogAnimationCompression: Recompressing (AnimSequence /NVCharacter/Anim/sol/sol_sitting_anim.sol_sitting_anim) using current/default (AnimCompress_BitwiseCompressOnly_16) bFirstRecompressUsingCurrentOrDefault(1) bTryAlternateCompressor(0) IsCompressedDataValid(0)
[2019.10.28-06.00.10:177][ 0]LogTexture: Display: Building textures: head_Base_Color_v05 (AutoDXT, 4096X4096)
[2019.10.28-06.00.10:178][ 0]LogStaticMesh: Building static mesh S_ForkliftFork...
[2019.10.28-06.00.12:775][ 0]LogStaticMesh: Built static mesh [2.60s] /Game/Warehouse/Forklift/S_ForkliftFork.S_ForkliftFork
[2019.10.28-06.00.12:871][ 0]LogStaticMesh: Building static mesh S_ForkliftBody...
Ucciso
hp@hp-desktop:~$ ./UnrealEngine-IsaacSim_1.2/Engine/Binaries/Linux/UE4Editor IsaacSimProject CarterWarehouse_P -vulkan -isaac_sim_config_json="/home/hp/isaac/apps/carter/carter_sim/bridge_config/carter_full.json"
Increasing per-process limit of core file size to infinity.
LogInit: Display: Running engine for game: IsaacSimProject
LogPlatformFile: Not using cached read wrapper
LogTaskGraph: Started task graph with 5 named threads and 14 total threads with 3 sets of task threads.
LogStats: Stats thread started at 4.638007
LogICUInternationalization: Display: ICU TimeZone Detection - Raw Offset: +1:00, Platform Override: ''
LogPluginManager: Mounting plugin AISupport
LogPluginManager: Mounting plugin NetcodeUnitTest
LogPluginManager: Mounting plugin NUTUnrealEngine4
LogPluginManager: Mounting plugin DatasmithContent
LogPluginManager: Mounting plugin GeometryCache
LogPluginManager: Mounting plugin AppleImageUtils
LogPluginManager: Mounting plugin AlembicImporter
LogPluginManager: Mounting plugin HTML5Networking
LogPluginManager: Mounting plugin BackChannel
LogPluginManager: Mounting plugin ProxyLODPlugin
LogPluginManager: Mounting plugin CharacterAI
LogPluginManager: Mounting plugin AppleVision
LogPluginManager: Mounting plugin ImmediatePhysics
LogPluginManager: Mounting plugin AndroidPermission
LogPluginManager: Mounting plugin WindowsMoviePlayer
LogPluginManager: Mounting plugin PhysXVehicles
LogPluginManager: Mounting plugin RuntimePhysXCooking
LogPluginManager: Mounting plugin SteamVR
LogPluginManager: Mounting plugin OculusVR
LogPluginManager: Plugin shader directory ../../../Engine/Plugins/Runtime/Oculus/OculusVR/Shaders found
LogPluginManager: Mapping shader source directory ../../../Engine/Plugins/Runtime/Oculus/OculusVR/Shaders to virtual directory /Plugin/OculusVR
LogPluginManager: Mounting plugin AndroidMoviePlayer
LogPluginManager: Mounting plugin GoogleCloudMessaging
LogPluginManager: Mounting plugin IOSDeviceProfileSelector
LogPluginManager: Mounting plugin EditableMesh
LogPluginManager: Mounting plugin CustomMeshComponent
LogPluginManager: Mounting plugin AppleMoviePlayer
LogPluginManager: Mounting plugin AudioCapture
LogPluginManager: Mounting plugin LocationServicesBPLibrary
LogPluginManager: Mounting plugin CableComponent
LogPluginManager: Mounting plugin ProceduralMeshComponent
LogPluginManager: Mounting plugin ExampleDeviceProfileSelector
LogPluginManager: Mounting plugin MobilePatchingUtils
LogPluginManager: Mounting plugin LinuxDeviceProfileSelector
LogPluginManager: Mounting plugin AndroidDeviceProfileSelector
LogPluginManager: Mounting plugin ArchVisCharacter
LogPluginManager: Mounting plugin UdpMessaging
LogPluginManager: Mounting plugin TcpMessaging
LogPluginManager: Mounting plugin Paper2D
LogPluginManager: Mounting plugin MeshEditor
LogPluginManager: Mounting plugin PluginBrowser
LogPluginManager: Mounting plugin SpeedTreeImporter
LogPluginManager: Mounting plugin FacialAnimation
LogPluginManager: Mounting plugin AssetManagerEditor
LogPluginManager: Mounting plugin MacGraphicsSwitching
LogPluginManager: Mounting plugin DataValidation
LogPluginManager: Mounting plugin CryptoKeys
LogPluginManager: Mounting plugin MobileLauncherProfileWizard
LogPluginManager: Mounting plugin GameplayTagsEditor
LogPluginManager: Mounting plugin LightPropagationVolume
LogPluginManager: Mounting plugin VisualStudioSourceCodeAccess
LogPluginManager: Mounting plugin CLionSourceCodeAccess
LogPluginManager: Mounting plugin CodeLiteSourceCodeAccess
LogPluginManager: Mounting plugin GitSourceControl
LogPluginManager: Mounting plugin XCodeSourceCodeAccess
LogPluginManager: Mounting plugin SubversionSourceControl
LogPluginManager: Mounting plugin KDevelopSourceCodeAccess
LogPluginManager: Mounting plugin UObjectPlugin
LogPluginManager: Mounting plugin PerforceSourceControl
LogPluginManager: Mounting plugin NullSourceCodeAccess
LogPluginManager: Mounting plugin VisualStudioCodeSourceCodeAccess
LogPluginManager: Mounting plugin MagicLeapEmulator
LogPluginManager: Mounting plugin MagicLeapMedia
LogPluginManager: Mounting plugin MatineeToLevelSequence
LogPluginManager: Mounting plugin LevelSequenceEditor
LogPluginManager: Mounting plugin ActorSequence
LogPluginManager: Mounting plugin WmfMedia
LogPluginManager: Mounting plugin AvfMedia
LogPluginManager: Mounting plugin ImgMedia
LogPluginManager: Mounting plugin MediaPlayerEditor
LogPluginManager: Mounting plugin MediaCompositing
LogPluginManager: Mounting plugin LinearTimecode
LogPluginManager: Mounting plugin AndroidMedia
LogPluginManager: Mounting plugin OnlineSubsystemGooglePlay
LogPluginManager: Mounting plugin OnlineSubsystemIOS
LogPluginManager: Mounting plugin OnlineSubsystemUtils
LogPluginManager: Mounting plugin OnlineSubsystemNull
LogPluginManager: Mounting plugin LauncherChunkInstaller
LogPluginManager: Mounting plugin NVCharacter
LogPluginManager: Mounting plugin Substance
LogPluginManager: Mounting plugin DLAnimation
LogPluginManager: Mounting plugin RobotBuilder
LogPluginManager: Mounting plugin IsaacSimUtilities
LogPluginManager: Mounting plugin IsaacPhysics
LogPluginManager: Mounting plugin DomainRandomizationDNN
LogStreaming: Display: Took 1.012s to configure plugins.
LogInit: Using libcurl 7.48.0-DEV
LogInit: - built for x86_64-unknown-linux-gnu
LogInit: - supports SSL with OpenSSL/1.0.2h
LogInit: - supports HTTP deflate (compression) using libz 1.2.8
LogInit: - other features:
LogInit: CURL_VERSION_SSL
LogInit: CURL_VERSION_LIBZ
LogInit: CURL_VERSION_IPV6
LogInit: CURL_VERSION_ASYNCHDNS
LogInit: CURL_VERSION_LARGEFILE
LogInit: CURL_VERSION_TLSAUTH_SRP
LogInit: Libcurl: checking if '/etc/pki/tls/certs/ca-bundle.crt' exists
LogInit: Libcurl: checking if '/etc/ssl/certs/ca-certificates.crt' exists
LogInit: CurlRequestOptions (configurable via config and command line):
LogInit: - bVerifyPeer = true - Libcurl will verify peer certificate
LogInit: - bUseHttpProxy = false - Libcurl will NOT use HTTP proxy
LogInit: - bDontReuseConnections = false - Libcurl will reuse connections
LogInit: - CertBundlePath = /etc/ssl/certs/ca-certificates.crt - Libcurl will set CURLOPT_CAINFO to it
LogInit: - MaxHostConnections = 16 - Libcurl will limit the number of connections to a host
LogInit: - LocalHostAddr = Default
LogInit: - BufferSize = 65536
LogInit: Build: ++UE4+Release-4.20-CL-0
LogInit: Engine Version: 4.20.3-0+++UE4+Release-4.20
LogInit: Compatible Engine Version: 4.20.0-0+++UE4+Release-4.20
LogInit: Net CL: 0
LogInit: OS: GenericOSVersionLabel (GenericOSSubVersionLabel), CPU: AMD A8-5500 APU with Radeon(tm) HD Graphics , GPU: GenericGPUBrand
LogInit: Compiled (64-bit): Oct 27 2019 23:47:50
LogInit: Compiled with Clang: 6.0.0 (tags/RELEASE_600/final)
LogInit: Build Configuration: Development
LogInit: Branch Name: ++UE4+Release-4.20
LogInit: Command Line: CarterWarehouse_P -vulkan -isaac_sim_config_json=/home/hp/isaac/apps/carter/carter_sim/bridge_config/carter_full.json
LogInit: Base Directory: /home/hp/UnrealEngine-IsaacSim_1.2/Engine/Binaries/Linux/
LogInit: Installed Engine Build: 0
LogDevObjectVersion: Number of dev versions registered: 20
LogDevObjectVersion: Dev-Blueprints (B0D832E4-1F89-4F0D-ACCF-7EB736FD4AA2): 10
LogDevObjectVersion: Dev-Build (E1C64328-A22C-4D53-A36C-8E866417BD8C): 0
LogDevObjectVersion: Dev-Core (375EC13C-06E4-48FB-B500-84F0262A717E): 2
LogDevObjectVersion: Dev-Editor (E4B068ED-F494-42E9-A231-DA0B2E46BB41): 24
LogDevObjectVersion: Dev-Framework (CFFC743F-43B0-4480-9391-14DF171D2073): 34
LogDevObjectVersion: Dev-Mobile (B02B49B5-BB20-44E9-A304-32B752E40360): 2
LogDevObjectVersion: Dev-Networking (A4E4105C-59A1-49B5-A7C5-40C4547EDFEE): 0
LogDevObjectVersion: Dev-Online (39C831C9-5AE6-47DC-9A44-9C173E1C8E7C): 0
LogDevObjectVersion: Dev-Physics (78F01B33-EBEA-4F98-B9B4-84EACCB95AA2): 0
LogDevObjectVersion: Dev-Platform (6631380F-2D4D-43E0-8009-CF276956A95A): 0
LogDevObjectVersion: Dev-Rendering (12F88B9F-8875-4AFC-A67C-D90C383ABD29): 26
LogDevObjectVersion: Dev-Sequencer (7B5AE74C-D270-4C10-A958-57980B212A5A): 9
LogDevObjectVersion: Dev-VR (D7296918-1DD6-4BDD-9DE2-64A83CC13884): 2
LogDevObjectVersion: Dev-LoadTimes (C2A15278-BFE7-4AFE-6C17-90FF531DF755): 1
LogDevObjectVersion: Private-Geometry (6EACA3D4-40EC-4CC1-B786-8BED09428FC5): 3
LogDevObjectVersion: Dev-AnimPhys (29E575DD-E0A3-4627-9D10-D276232CDCEA): 18
LogDevObjectVersion: Dev-ReflectionCapture (6B266CEC-1EC7-4B8F-A30B-E4D90942FC07): 1
LogDevObjectVersion: Dev-Automation (0DF73D61-A23F-47EA-B727-89E90C41499A): 1
LogDevObjectVersion: FortniteMain (601D1886-AC64-4F84-AA16-D3DE0DEAC7D6): 12
LogDevObjectVersion: Dev-Enterprise (9DFFBCD6-494F-0158-E221-12823C92A888): 1
LogStreaming: Display: Took 0.000s to delete old logs.
LogInit: Presizing for max 8388607 objects, including 0 objects not considered by GC, pre-allocating 0 bytes for permanent pool.
LogInit: Object subsystem initialized
[2019.10.28-06.07.40:428][ 0]LogInit: Initializing SDL.
[2019.10.28-06.07.42:184][ 0]LogInit: Initialized SDL 2.0.5 revision: 11184 (hg-11184:04063928c4a8 with EpicExtensions) (compiled against 2.0.5)
[2019.10.28-06.07.42:184][ 0]LogInit: Using SDL_WINDOW_VULKAN
[2019.10.28-06.07.42:184][ 0]LogInit: Using SDL video driver 'x11'
[2019.10.28-06.07.42:185][ 0]LogInit: Display metrics:
[2019.10.28-06.07.42:185][ 0]LogInit: PrimaryDisplayWidth: 1680
[2019.10.28-06.07.42:185][ 0]LogInit: PrimaryDisplayHeight: 1050
[2019.10.28-06.07.42:185][ 0]LogInit: PrimaryDisplayWorkAreaRect:
[2019.10.28-06.07.42:185][ 0]LogInit: Left=0, Top=25, Right=1680, Bottom=1001
[2019.10.28-06.07.42:185][ 0]LogInit: VirtualDisplayRect:
[2019.10.28-06.07.42:185][ 0]LogInit: TitleSafePaddingSize: X=0.000 Y=0.000 Z=0.000 W=0.000
[2019.10.28-06.07.42:185][ 0]LogInit: ActionSafePaddingSize: X=0.000 Y=0.000 Z=0.000 W=0.000
[2019.10.28-06.07.42:185][ 0]LogInit: Number of monitors: 1
[2019.10.28-06.07.42:185][ 0]LogInit: Monitor 0
[2019.10.28-06.07.42:185][ 0]LogInit: Name: SyncMaster 20"
[2019.10.28-06.07.42:185][ 0]LogInit: ID: display0
[2019.10.28-06.07.42:185][ 0]LogInit: NativeWidth: 1680
[2019.10.28-06.07.42:185][ 0]LogInit: NativeHeight: 1050
[2019.10.28-06.07.42:185][ 0]LogInit: bIsPrimary: true
[2019.10.28-06.07.42:244][ 0]LogLinux: Selected Device Profile: [Linux]
[2019.10.28-06.07.42:244][ 0]LogInit: Applying CVar settings loaded from the selected device profile: [Linux]
[2019.10.28-06.07.42:296][ 0]LogHAL: Display: Platform has ~ 4 GB [8381321216 / 4294967296 / 8], which maps to Smallest [LargestMinGB=32, LargerMinGB=12, DefaultMinGB=8, SmallerMinGB=6, SmallestMinGB=0)
[2019.10.28-06.07.42:296][ 0]LogInit: Going up to parent DeviceProfile []
[2019.10.28-06.07.42:352][ 0]LogInit: Using custom *.sym to symbolicate
[2019.10.28-06.07.42:352][ 0]LogInit: Unix hardware info:
[2019.10.28-06.07.42:352][ 0]LogInit: - we are the first instance of this executable
[2019.10.28-06.07.42:352][ 0]LogInit: - this process' id (pid) is 21732, parent process' id (ppid) is 26812
[2019.10.28-06.07.42:352][ 0]LogInit: - we are not running under debugger
[2019.10.28-06.07.42:352][ 0]LogInit: - machine network name is 'hp-desktop'
[2019.10.28-06.07.42:352][ 0]LogInit: - user name is 'hp' (hp)
[2019.10.28-06.07.42:352][ 0]LogInit: - we're logged in locally
[2019.10.28-06.07.42:352][ 0]LogInit: - we're running with rendering
[2019.10.28-06.07.42:352][ 0]LogInit: - CPU: AuthenticAMD 'AMD A8-5500 APU with Radeon(tm) HD Graphics ' (signature: 0x610F01)
[2019.10.28-06.07.42:352][ 0]LogInit: - Number of physical cores available for the process: 4
[2019.10.28-06.07.42:352][ 0]LogInit: - Number of logical cores available for the process: 4
[2019.10.28-06.07.42:352][ 0]LogInit: - Cache line size: 64
[2019.10.28-06.07.42:352][ 0]LogInit: - Memory allocator used: binned2
[2019.10.28-06.07.42:352][ 0]LogCore: Benchmarking clocks:
[2019.10.28-06.07.42:352][ 0]LogCore: - CLOCK_REALTIME (id=0) can sustain 24035328 (24035K, 24M) calls per second without zero deltas.
[2019.10.28-06.07.42:352][ 0]LogCore: - CLOCK_MONOTONIC (id=1) can sustain 24909260 (24909K, 25M) calls per second without zero deltas.
[2019.10.28-06.07.42:352][ 0]LogCore: - CLOCK_MONOTONIC_RAW (id=4) can sustain 4069349 (4069K, 4M) calls per second without zero deltas.
[2019.10.28-06.07.42:352][ 0]LogCore: - CLOCK_MONOTONIC_COARSE (id=6) can sustain 85268851 (85269K, 85M) calls per second with 99.999696% zero deltas.
[2019.10.28-06.07.42:352][ 0]LogCore: Selected clock_id 1 (CLOCK_MONOTONIC) since it is the fastest support clock without zero deltas.
[2019.10.28-06.07.42:352][ 0]LogInit: Unix-specific commandline switches:
[2019.10.28-06.07.42:352][ 0]LogInit: -nodwarf (currently OFF): suppress parsing of DWARF debug info (callstacks will be generated faster, but won't have line numbers)
[2019.10.28-06.07.42:352][ 0]LogInit: -ansimalloc - use malloc()/free() from libc (useful for tools like valgrind and electric fence)
[2019.10.28-06.07.42:352][ 0]LogInit: -jemalloc - use jemalloc for all memory allocation
[2019.10.28-06.07.42:352][ 0]LogInit: -binnedmalloc - use binned malloc for all memory allocation
[2019.10.28-06.07.42:353][ 0]LogInit: -filemapcachesize=NUMBER - set the size for case-sensitive file mapping cache
[2019.10.28-06.07.42:353][ 0]LogInit: -httpproxy=ADDRESS:PORT - redirects HTTP requests to a proxy (only supported if compiled with libcurl)
[2019.10.28-06.07.42:353][ 0]LogInit: -reuseconn - allow libcurl to reuse HTTP connections (only matters if compiled with libcurl)
[2019.10.28-06.07.42:353][ 0]LogInit: -virtmemkb=NUMBER - sets process virtual memory (address space) limit (overrides VirtualMemoryLimitInKB value from .ini)
[2019.10.28-06.07.42:353][ 0]LogInit: - Physical RAM available (not considering process quota): 8 GB (7993 MB, 8184884 KB, 8381321216 bytes)
[2019.10.28-06.07.43:149][ 0]LogInit: Using OS detected language (it-IT).
[2019.10.28-06.07.43:149][ 0]LogInit: Using OS detected locale (it-IT).
[2019.10.28-06.07.43:211][ 0]LogTextLocalizationManager: No specific localization for 'it-IT' exists, so the 'it' localization will be used.
[2019.10.28-06.07.43:265][ 0]LogStreaming: Display: Took 0.116s to InitEngineTextLocalization.
[2019.10.28-06.07.44:823][ 0]LogSlate: New Slate User Created. User Index 0, Is Virtual User: 0
[2019.10.28-06.07.44:823][ 0]LogSlate: Slate User Registered. User Index 0, Is Virtual User: 0
[2019.10.28-06.07.48:085][ 0]LogRHI: Warning: Failed to find entry point for vkGetPhysicalDeviceProperties2KHR
[2019.10.28-06.07.48:086][ 0]LogRHI: Warning: Failed to find entry point for vkGetImageMemoryRequirements2KHR
[2019.10.28-06.07.48:086][ 0]LogRHI: Warning: Failed to find entry point for vkGetBufferMemoryRequirements2KHR
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_GOOGLE_threading
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_GOOGLE_unique_objects
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_KHRONOS_validation
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_api_dump
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_assistant_layer
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_core_validation
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_device_simulation
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_monitor
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_object_tracker
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_parameter_validation
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_screenshot
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_standard_validation
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance layer VK_LAYER_LUNARG_vktrace
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_EXT_acquire_xlib_display
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_EXT_debug_report
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_EXT_debug_utils
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_EXT_direct_mode_display
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_EXT_display_surface_counter
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_EXT_validation_features
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_device_group_creation
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_display
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_external_fence_capabilities
[2019.10.28-06.07.48:630][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_external_memory_capabilities
[2019.10.28-06.07.48:631][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_external_semaphore_capabilities
[2019.10.28-06.07.48:631][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_get_display_properties2
[2019.10.28-06.07.48:631][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_get_physical_device_properties2
[2019.10.28-06.07.48:631][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_get_surface_capabilities2
[2019.10.28-06.07.48:631][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_surface
[2019.10.28-06.07.48:631][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_xcb_surface
[2019.10.28-06.07.48:631][ 0]LogVulkanRHI: Display: - Found instance extension VK_KHR_xlib_surface
Unable to read VR Path Registry from /home/hp/.config/openvr/openvrpaths.vrpath
[2019.10.28-06.07.48:708][ 0]LogHMD: Failed to initialize OpenVR with code 110
[2019.10.28-06.07.48:708][ 0]LogVulkanRHI: Display: Not using instance layers
[2019.10.28-06.07.48:708][ 0]LogVulkanRHI: Display: Using instance extensions
[2019.10.28-06.07.48:708][ 0]LogVulkanRHI: Display: * VK_KHR_surface
[2019.10.28-06.07.48:709][ 0]LogVulkanRHI: Display: * VK_KHR_xlib_surface
[2019.10.28-06.07.48:709][ 0]LogVulkanRHI: Display: * VK_EXT_debug_report
[2019.10.28-06.07.49:423][ 0]LogVulkanRHI: Display: Found 2 device(s)
[2019.10.28-06.07.49:423][ 0]LogVulkanRHI: Display: Initializing Device 0: GeForce GTX 1050 Ti
[2019.10.28-06.07.49:423][ 0]LogVulkanRHI: Display: - API 0x401063 Driver 0x6b868000 VendorId 0x10de
[2019.10.28-06.07.49:423][ 0]LogVulkanRHI: Display: - DeviceID 0x1c82 Type Discrete GPU
[2019.10.28-06.07.49:423][ 0]LogVulkanRHI: Display: - Max Descriptor Sets Bound 32 Timestamps 1
[2019.10.28-06.07.49:424][ 0]LogVulkanRHI: Display: Initializing Device 1: GeForce GTX 1050 Ti
[2019.10.28-06.07.49:424][ 0]LogVulkanRHI: Display: - API 0x401063 Driver 0x6b868000 VendorId 0x10de
[2019.10.28-06.07.49:424][ 0]LogVulkanRHI: Display: - DeviceID 0x1c82 Type Discrete GPU
[2019.10.28-06.07.49:424][ 0]LogVulkanRHI: Display: - Max Descriptor Sets Bound 32 Timestamps 1
[2019.10.28-06.07.49:424][ 0]LogVulkanRHI: Display: Using Device 0: Geometry 1 Tessellation 1
[2019.10.28-06.07.49:424][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_blend_operation_advanced
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_buffer_device_address
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_conditional_rendering
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_conservative_rasterization
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_depth_clip_enable
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_depth_range_unrestricted
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_descriptor_indexing
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_discard_rectangles
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_display_control
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_global_priority
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_host_query_reset
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_inline_uniform_block
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_memory_budget
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_pci_bus_info
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_post_depth_coverage
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_sample_locations
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_sampler_filter_minmax
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_scalar_block_layout
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_shader_subgroup_ballot
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_shader_subgroup_vote
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_shader_viewport_index_layer
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_transform_feedback
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_EXT_vertex_attribute_divisor
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_16bit_storage
[2019.10.28-06.07.49:425][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_8bit_storage
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_bind_memory2
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_create_renderpass2
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_dedicated_allocation
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_depth_stencil_resolve
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_descriptor_update_template
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_device_group
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_draw_indirect_count
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_driver_properties
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_external_fence
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_external_fence_fd
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_external_memory
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_external_memory_fd
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_external_semaphore
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_external_semaphore_fd
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_get_memory_requirements2
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_image_format_list
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_maintenance1
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_maintenance2
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_maintenance3
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_multiview
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_push_descriptor
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_relaxed_block_layout
[2019.10.28-06.07.49:426][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_sampler_mirror_clamp_to_edge
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_sampler_ycbcr_conversion
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_shader_atomic_int64
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_shader_draw_parameters
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_shader_float16_int8
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_shader_float_controls
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_storage_buffer_storage_class
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_swapchain
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_swapchain_mutable_format
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_variable_pointers
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_KHR_vulkan_memory_model
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_clip_space_w_scaling
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_dedicated_allocation
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_dedicated_allocation_image_aliasing
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_device_diagnostic_checkpoints
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_fill_rectangle
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_fragment_coverage_to_color
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_framebuffer_mixed_samples
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_geometry_shader_passthrough
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_sample_mask_override_coverage
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_shader_subgroup_partitioned
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_viewport_array2
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NV_viewport_swizzle
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NVX_device_generated_commands
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: - Found device extension VK_NVX_multiview_per_view_attributes
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: Using device extensions
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: * VK_KHR_swapchain
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: * VK_KHR_maintenance1
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: * VK_KHR_maintenance2
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: * VK_KHR_sampler_mirror_clamp_to_edge
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: Found 3 Queue Families
[2019.10.28-06.07.49:427][ 0]LogVulkanRHI: Display: Initializing Queue Family 0: 16 queues Gfx Compute Xfer Sparse
[2019.10.28-06.07.49:428][ 0]LogVulkanRHI: Display: Initializing Queue Family 1: 2 queues Xfer
[2019.10.28-06.07.49:428][ 0]LogVulkanRHI: Display: Skipping unnecessary Queue Family 2: 8 queues Compute
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 2 Device Memory Heaps; Max memory allocations -1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 0: Flags 0x1 Size 4294967296 (4096.00 MB) GPU
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 1: Flags 0x0 Size 6285990912 (5994.79 MB)
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 11 Device Memory Types (Not unified)
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 0: Flags 0x0 Heap 1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 1: Flags 0x0 Heap 1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 2: Flags 0x0 Heap 1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 3: Flags 0x0 Heap 1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 4: Flags 0x0 Heap 1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 5: Flags 0x0 Heap 1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 6: Flags 0x0 Heap 1
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 7: Flags 0x1 Heap 0 Local
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 8: Flags 0x1 Heap 0 Local
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 9: Flags 0x6 Heap 1 HostVisible HostCoherent
[2019.10.28-06.07.49:757][ 0]LogVulkanRHI: Display: 10: Flags 0xe Heap 1 HostVisible HostCoherent HostCached
[2019.10.28-06.07.49:806][ 0]LogVulkanRHI: Display: Trying pipeline cache file ../../../IsaacSimProject/Saved/VulkanPSO.cache
[2019.10.28-06.07.49:806][ 0]LogVulkanRHI: Warning: Unable to load pipeline cache '../../../IsaacSimProject/Saved/VulkanPSO.cache'
[2019.10.28-06.07.49:806][ 0]LogVulkanRHI: Display: Pipeline cache: No pipeline cache(s) loaded
[2019.10.28-06.07.50:094][ 0]LogRHI: Texture pool is 2723 MB (70% of 3891 MB)
[2019.10.28-06.07.50:129][ 0]LogShaderCompilers: Guid format shader working directory is 14 characters bigger than the processId version (../../../IsaacSimProject/Intermediate/Shaders/WorkingDirectory/21732/).
[2019.10.28-06.07.50:130][ 0]LogShaderCompilers: Cleaned the shader compiler working directory '../../../IsaacSimProject/Intermediate/Shaders/tmp/00033D9508D75B758B3926F024285BCE/'.
[2019.10.28-06.07.50:130][ 0]LogShaderCompilers: Display: Using Local Shader Compiler.
[2019.10.28-06.07.58:395][ 0]LogTemp: Display: Loaded TP AllDesktopTargetPlatform
[2019.10.28-06.07.58:866][ 0]LogTemp: Display: Loaded TP AndroidTargetPlatform
[2019.10.28-06.07.59:315][ 0]LogTemp: Display: Loaded TP HTML5TargetPlatform
[2019.10.28-06.07.59:714][ 0]LogTemp: Display: Loaded TP LinuxClientTargetPlatform
[2019.10.28-06.08.00:104][ 0]LogTemp: Display: Loaded TP LinuxNoEditorTargetPlatform
[2019.10.28-06.08.00:455][ 0]LogTemp: Display: Loaded TP LinuxServerTargetPlatform
[2019.10.28-06.08.00:876][ 0]LogTemp: Display: Loaded TP LinuxTargetPlatform
[2019.10.28-06.08.00:888][ 0]LogTargetPlatformManager: Display: Building Assets For Linux
[2019.10.28-06.08.02:973][ 0]LogDerivedDataCache: Display: Max Cache Size: 512 MB
[2019.10.28-06.08.05:510][ 0]LogDerivedDataCache: Loaded boot cache 2.51s 102MB ../../../IsaacSimProject/DerivedDataCache/Boot.ddc.
[2019.10.28-06.08.05:511][ 0]LogDerivedDataCache: Display: Loaded Boot cache: ../../../IsaacSimProject/DerivedDataCache/Boot.ddc
[2019.10.28-06.08.05:511][ 0]LogDerivedDataCache: FDerivedDataBackendGraph: Pak pak cache file ../../../IsaacSimProject/DerivedDataCache/DDC.ddp not found, will not use a pak cache.
[2019.10.28-06.08.05:511][ 0]LogDerivedDataCache: Unable to find inner node Pak for hierarchical cache Hierarchy.
[2019.10.28-06.08.05:545][ 0]LogDerivedDataCache: FDerivedDataBackendGraph: EnginePak pak cache file ../../../Engine/DerivedDataCache/DDC.ddp not found, will not use a pak cache.
[2019.10.28-06.08.05:545][ 0]LogDerivedDataCache: Unable to find inner node EnginePak for hierarchical cache Hierarchy.
[2019.10.28-06.08.05:554][ 0]LogDerivedDataCache: Using Local data cache path ../../../Engine/DerivedDataCache: Writable
[2019.10.28-06.08.05:554][ 0]LogDerivedDataCache: Shared data cache path not found in *engine.ini, will not use an Shared cache.
[2019.10.28-06.08.05:554][ 0]LogDerivedDataCache: Unable to find inner node Shared for hierarchical cache Hierarchy.
[2019.10.28-06.08.05:645][ 0]LogMaterial: Verifying Global Shaders for SF_VULKAN_SM5
[2019.10.28-06.08.05:678][ 0]LogSlate: Using FreeType 2.6.0
[2019.10.28-06.08.05:727][ 0]LogSlate: SlateFontServices - WITH_FREETYPE: 1, WITH_HARFBUZZ: 0
[2019.10.28-06.08.07:021][ 0]LogAssetRegistry: FAssetRegistry took 0.0058 seconds to start up
[2019.10.28-06.08.12:595][ 0]LogLinux: Selected Device Profile: [Linux]
[2019.10.28-06.08.13:544][ 0]LogMaterial: Display: Missing cached shader map for material MatineeCam_mat, compiling.
[2019.10.28-06.08.15:309][ 0]LogShaderCompilers: Display: Shaders left to compile 19
[2019.10.28-06.08.15:309][ 0]LogShaderCompilers: Display: Shaders left to compile 9
[2019.10.28-06.08.15:309][ 0]LogMeshReduction: Using QuadricMeshReduction for automatic static mesh reduction
[2019.10.28-06.08.15:309][ 0]LogMeshReduction: No automatic skeletal mesh reduction module available
[2019.10.28-06.08.15:309][ 0]LogMeshReduction: No automatic mesh merging module available
[2019.10.28-06.08.15:309][ 0]LogMeshReduction: No distributed automatic mesh merging module available
[2019.10.28-06.08.15:310][ 0]LogMeshMerging: No automatic mesh merging module available
[2019.10.28-06.08.15:310][ 0]LogMeshMerging: No distributed automatic mesh merging module available
[2019.10.28-06.08.16:028][ 0]LogMeshUtilities: Finished distance field build in 0.4s - 14x8x8 distance field, 4528 triangles, Range [-0.1, 0.6], MatineeCam_SM
[2019.10.28-06.08.16:028][ 0]LogNetVersion: IsaacSimProject 1.0.0, NetCL: 0, EngineNetVer: 5, GameNetVer: 0 (Checksum: 528379804)
[2019.10.28-06.08.16:682][ 0]LogMaterial: Display: Missing cached shader map for material HelpActorMaterial, compiling.
[2019.10.28-06.08.17:850][ 0]LogShaderCompilers: Display: Shaders left to compile 39
[2019.10.28-06.08.17:850][ 0]LogMaterial: Display: Missing cached shader map for material DefaultTextMaterialOpaque, compiling.
[2019.10.28-06.08.18:130][ 0]LogMaterial: Display: Missing cached shader map for material BaseFlattenMaterial, compiling.
[2019.10.28-06.08.19:376][ 0]LogMaterial: Display: Missing cached shader map for material LandscapeGizmo_Mat, compiling.
[2019.10.28-06.08.19:502][ 0]LogMaterial: Display: Missing cached shader map for material LandscapeGizmoHeight_Mat, compiling.
[2019.10.28-06.08.19:692][ 0]LogMaterial: Display: Missing cached shader map for material SplineEditorMeshMat, compiling.
[2019.10.28-06.08.19:827][ 0]LogMaterial: Display: Missing cached shader map for material CineMat, compiling.
[2019.10.28-06.08.20:169][ 0]LogMaterial: Display: Missing cached shader map for material M_SimpleOpaque, compiling.
[2019.10.28-06.08.20:388][ 0]LogMaterial: Display: Missing cached shader map for material M_SimpleTranslucent, compiling.
[2019.10.28-06.08.21:315][ 0]LogMaterial: Display: Missing cached shader map for material TranslucentTransformGizmoMaterial, compiling.
[2019.10.28-06.08.21:338][ 0]LogMaterial: Display: Missing cached shader map for material TransformGizmoMaterial, compiling.
[2019.10.28-06.08.21:718][ 0]LogMaterial: Display: Missing cached shader map for material Xray, compiling.
[2019.10.28-06.08.21:758][ 0]LogMaterial: Display: Missing cached shader map for material Main, compiling.
[2019.10.28-06.08.22:986][ 0]LogMaterial: Display: Missing cached shader map for material SkySphereMaterial, compiling.
[2019.10.28-06.08.23:144][ 0]LogMaterial: Display: Missing cached shader map for material FloorPlaneMaterial, compiling.
[2019.10.28-06.08.23:663][ 0]LogMaterial: Display: Missing cached shader map for material Widget3DPassThrough, compiling.
[2019.10.28-06.08.23:688][ 0]LogMaterial: Display: Missing cached shader map for material Widget3DPassThrough, compiling.
[2019.10.28-06.08.23:749][ 0]LogMaterial: Display: Missing cached shader map for material Widget3DPassThrough, compiling.
[2019.10.28-06.08.23:788][ 0]LogMaterial: Display: Missing cached shader map for material Widget3DPassThrough, compiling.
[2019.10.28-06.08.23:823][ 0]LogMaterial: Display: Missing cached shader map for material Widget3DPassThrough, compiling.
[2019.10.28-06.08.23:890][ 0]LogMaterial: Display: Missing cached shader map for material Widget3DPassThrough, compiling.
[2019.10.28-06.08.24:979][ 0]LogPackageLocalizationCache: Processed 18 localized package path(s) for 2 prioritized culture(s) in 0.960613 seconds
[2019.10.28-06.08.25:030][ 0]LogUObjectArray: 39636 objects as part of root set at end of initial load.
[2019.10.28-06.08.25:030][ 0]LogUObjectAllocator: 7010328 out of 0 bytes used by permanent object pool.
[2019.10.28-06.08.25:030][ 0]LogUObjectArray: CloseDisregardForGC: 0/0 objects in disregard for GC pool
[2019.10.28-06.08.25:820][ 0]LogHAL: Linux SourceCodeAccessSettings: NullSourceCodeAccessor
[2019.10.28-06.08.35:431][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png' error.
[2019.10.28-06.08.35:431][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png
[2019.10.28-06.08.35:431][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png' error.
[2019.10.28-06.08.35:431][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png
[2019.10.28-06.08.35:432][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png' error.
[2019.10.28-06.08.35:432][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png
[2019.10.28-06.08.35:432][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png' error.
[2019.10.28-06.08.35:432][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png
[2019.10.28-06.08.35:433][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png' error.
[2019.10.28-06.08.35:433][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png
[2019.10.28-06.08.35:433][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png' error.
[2019.10.28-06.08.35:433][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png
[2019.10.28-06.08.35:434][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png' error.
[2019.10.28-06.08.35:434][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png
[2019.10.28-06.08.35:434][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png' error.
[2019.10.28-06.08.35:435][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_24x.png
[2019.10.28-06.08.35:435][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png' error.
[2019.10.28-06.08.35:435][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Mac/Platform_Mac_128x.png
[2019.10.28-06.08.35:461][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png' error.
[2019.10.28-06.08.35:461][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png
[2019.10.28-06.08.35:461][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:461][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:462][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:462][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:462][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png' error.
[2019.10.28-06.08.35:462][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png
[2019.10.28-06.08.35:463][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:463][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:464][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:464][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:464][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ATC_24x.png' error.
[2019.10.28-06.08.35:464][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ATC_24x.png
[2019.10.28-06.08.35:465][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:465][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:466][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:466][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_DXT_24x.png' error.
[2019.10.28-06.08.35:466][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_DXT_24x.png
[2019.10.28-06.08.35:466][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:467][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:467][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:467][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ETC1_24x.png' error.
[2019.10.28-06.08.35:467][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ETC1_24x.png
[2019.10.28-06.08.35:468][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:468][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:469][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ETC1_24x.png' error.
[2019.10.28-06.08.35:469][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ETC1_24x.png
[2019.10.28-06.08.35:469][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:472][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:472][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:473][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:473][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ETC2_24x.png' error.
[2019.10.28-06.08.35:473][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ETC2_24x.png
[2019.10.28-06.08.35:473][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:474][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:474][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:475][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_PVRTC_24x.png' error.
[2019.10.28-06.08.35:475][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_PVRTC_24x.png
[2019.10.28-06.08.35:475][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:475][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:476][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:476][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:476][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ASTC_24x.png' error.
[2019.10.28-06.08.35:476][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ASTC_24x.png
[2019.10.28-06.08.35:477][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:477][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:478][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:478][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:479][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png' error.
[2019.10.28-06.08.35:479][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png
[2019.10.28-06.08.35:480][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:480][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:480][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png' error.
[2019.10.28-06.08.35:480][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_24x.png
[2019.10.28-06.08.35:481][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:481][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:482][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ATC_24x.png' error.
[2019.10.28-06.08.35:482][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_ATC_24x.png
[2019.10.28-06.08.35:482][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:482][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:483][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[2019.10.28-06.08.35:483][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:483][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_DXT_24x.png' error.
[2019.10.28-06.08.35:483][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_DXT_24x.png
[2019.10.28-06.08.35:484][ 0]LogSlate: Could not find file for Slate resource: ../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.08.35:484][ 0]LogStreaming: Warning: Failed to read file '../../../Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png' error.
[code][code][2019.10.28-06.10.13:209][ 0]LogSlate: Could not find file for Slate resource: …/…/…/Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.10.13:210][ 0]LogStreaming: Warning: Failed to read file ‘…/…/…/Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png’ error.
[2019.10.28-06.10.13:210][ 0]LogSlate: Could not find file for Slate resource: …/…/…/Engine/Content/Editor/Slate/Launcher/Android/Platform_Android_128x.png
[2019.10.28-06.10.13:211][ 0]LogStreaming: Warning: Failed to read file '…/…/…/Engine/Content/Editor/Slate/Launcher/Android/Plat
