Process to reinstall cboot after playing with UEFI?
I’ve seen a couple threads about the experimental UEFI firmware but nothing with the process to reinstall the old boot loader. Is that documented somewhere? I suspect it’s using flash.sh with some settings but want to make sure I’ve got the right ones. Thanks!
Please refer to this.
Yeah… that’s what I’ve been trying to do but was getting an error for some reason that the board couldn’t be identified. I ended up running the flash.sh script manually with the same options and that seems to have worked.
What error did you hit? Any log?
Error: probing the target board failed.
I’m not sure why it was failing there… it was like it was timing out or something? Running the exact same command manually worked though. It’s booting now.
