I’m trying to process 2-3 rtsp streams on my Jetson but it only can handle up to 1080p.
My project has 5MP cameras an the Jetson heats up and crashes after a while.
Is there a way to run different 2-3 high resolution streams on a Jetson (maybe reduce it by code)?
Do you run gstreamer commands or jetson_multimedia_api samples? Please share the command that you run and hit crash. And the release version you use:
