Processor Ryzen 5-7600 and RTX 4060 - Xubuntu 22.04
Hi. I Tried to install all ways the driver, but I can’t get it. The driver exist, is installed, but not load and nothing is showed in Nvidia settings. The command glxinfo | grep NVIDIA nothing returns. NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running, lsmod | grep nvidia.drm nothing too.
nvidia-xconfig
WARNING: Unable to locate/open X configuration file.
WARNING: Unable to parse X.Org version string.
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing `xorg-server.pc’
to the PKG_CONFIG_PATH environment variable
No package ‘xorg-server’ found
ERROR: Unable to write to directory ‘/etc/X11’.
Is the same in other topics?
Thank you very much.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
