Hi, we are fixing the docs shortly but we merged a few videos for simplicity. The second video is merged in with the first (intro is the first 3 minutes, data structure is the next 4:23 of that 7:23 video) and the fourth video was merged into the third (behavior data is 2:22 and the rest is categories and options). We will merge the titles and remove the blank videos but you have all the content there to get you going.
For the assets, make sure you have a local nucleus and you can find them in
i believe he’s referring to the two utilities inside the Product Configurator extension. specifically “add option” and “no code ui” option, which were highlighted in the doc and embedded video tutorial. below is a screengrab from one of the videos
i checked the extension manager, and it does seem like the utility extension detail only included 3 tools and not the other two he found missing
This is indeed a misalignment between the docs and what is available in Composer 2023.1.0 and Composer 2023.1.1
The No Code UI and Add Option utility is available in 2023.2 Composer release.
