Production mode: unfused. Nvidia jetson nano system cannot be started
When starting nvidia jetson nano 2gb the operating system will not boot.
I have read other answers on this topic, but have not been able to solve the problem
Version: 00.00.2018.01-1210-39562017
My course of action:
I connect the gnd/FC rec jumper, apply power and try to connect via micro usb interface to sdk manager on ubuntu 18.04
The device is not detected
But, when doing the same steps on a working nvidia jetson nano developer kit 4gb I have the device detected in ubuntu 18.04 and sdk manager is ready to flash.
I also failed to flash the jetson 2gb module through the jetson 4gb board.
What should be the micro usb cable? I have a regular data cable that works with my phone for file and photo transfer
What other solutions to the problem can you suggest? Tried many things with no results
If the device cannot evern enter force recovery mode then it’s likely it’s dead.
Do I need to use otg cable to flash via micro usb? Are there any significant differences in performance between the nvidia jetson 4gb/jetson 2gb boards?
I tried to flash the jetson 2gb module through the jetson 4gb board, since the micro usb is broken on the jetson 2gb
logs.txt (24.1 KB)
log files received from the serial port
I don’t know what you mean here.
Can I use a 2GB Jetson Nano with a 4GB carrier board?
No, you cannot.
